Fram Oil Filters
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TACOMA TRD, Jun 3, 2010.
  1. Aug 29, 2014 at 4:13 PM
    #121
    hetkind
    hetkind Well-Known Member
    Howard
    Johnson City
    2011 SR5 Access Cab, white with Leer Cap
    bilstein set at 1.75, Racho 5000 rear with 4 leaf kit, floor mats, high lift jack, pull hook in hitch, bed rail corner braces, severe duty brake pads and devil horns on the grill....
    One thing you forgot on longevity is fuel injection over carbs, this avoided the fuel wash down on cold engines and eventual dilution of the oil. I think they MOPAR engines were a bit ahead of their times with hardened valve seats and forged cranks on all engines long before GM and FOMOCO.
  2. Aug 30, 2014 at 4:27 AM
    #122
    Tommiet
    Tommiet Well-Known Member
    Tom
    Charlotte Area
    PreRunner
    Sounds like the TV commercials....
    Do yourself a favor and open up Fram filter up and see what your paying for. Or just Google it for plenty of video's showing the insides and then you make the decision.
    It's not going to kill your engine, but IMO you can do better with almost any other filter, including the cheap Walmart one.
    If Fram filters are soooo good, why can't they get any contracts to supply them for ANY automaker? Think about it.......
    Note: I do not work for or endorse any type of oil filter. Use Fram filters at your own risk.
  3. Aug 30, 2014 at 7:52 AM
    #123
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Hate to tell you this but there are a lot of Fram filters in the OEM market Honda is the first that comes to mind. Honda's seem to hold together OK. Their biggest selling market is aftermarket. I'm not a filter junky I will buy most any filter it all depends on where I am when I buy oil but bashing a product with no documented facts is BS. "I put a Fram filter on my truck and 10 miles later it blew up" (never mind it had a rod knock before the oil was changed). There is absolutely no sense losing sleep over an oil filter they all do what they were designed to do otherwise they would have long been out of business.
  4. Aug 30, 2014 at 8:13 AM
    #124
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
  5. Aug 30, 2014 at 8:19 AM
    #125
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  6. Aug 30, 2014 at 8:21 AM
    #126
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  7. Aug 30, 2014 at 8:23 AM
    #127
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  8. Aug 30, 2014 at 8:23 AM
    #128
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  9. Aug 30, 2014 at 8:24 AM
    #129
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  10. Aug 30, 2014 at 8:50 AM
    #130
    TrdSurgie
    TrdSurgie revised
    Oahu
    I don't think the Whipper is going to reply to you. But if he did it would be along the lines of derp.
    I used fram a alot in the past. I always thought it was a quality filter. I guess I fell for the isles being packed with orange boxes. Now I just use oem because I can but a box of 10 for $40 and I don't ever have to worry about some tool bag switching filters in the box with a cheaper or wrong filter because they wanted to save a dollar or two.
  11. Aug 30, 2014 at 10:50 AM
    #131
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    The first exploding filters I ever saw were AC Delco back in the 60's guess what it was from exactly the same thing that happened to the exploding Fram excessive oil pressure. The guy sure did mash that filter when he took it apart you may want to have a look at the oil not only was it black it was full of sludge. The MB filter was damaged when it was installed it was not seated in the bottom before they tightened the cap I have seen exactly the same thing with a Mann filter and on VW TDI's also. Oil filters do not produce sludge engines do, no wonder his oil pressure sucked the filter was trapping the junk the engine was producing the owner should try changing his oil a little more often. Sorry nothing conclusive there. Try and see if you can find any class action cases if they were all that bad they will be out there.
  12. Aug 30, 2014 at 11:35 AM
    #132
    TrdSurgie
    TrdSurgie revised
    Oahu
    But its so easy to to a poorly maintained engine, change the oil and filter and blame either the new oil or filter for anything.
    I don't think there is anything wrong with fram filters and would hesitate to use one. Are there better filters? Yup. But I dont think fram is as shitty as k & n products.
  13. Aug 31, 2014 at 5:34 AM
    #133
    Tommiet
    Tom
    Charlotte Area
    PreRunner
    Alot = honda?
    Note: Google search shows that Honda users multiple companies in multiple countries. If you find a Honda filter made in Japan, that is NOT a Fram filter. Find a Honda filter made in KOREA, you have a Fram. Who know, maybe Honda used Fram on its low end cars.
    Fram does not make all Honda oil filters...... Google is your friend.
    But if you like using an oil filter with a cardboard pressure valve, go for it!.
    It'a america and you have a choice.
  14. Aug 31, 2014 at 8:31 AM
    #134
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    I use only Purolator PureOne spin-ons for the Taco. But the wife's RAV4 has the AR 2.5L, which uses a cartridge filter. I've been using the Fram Extra Guard #HC9972 for several OC's with no issues. But I will say that a cartridge filter is very different from the traditional spin-on. The element is wide open for all to see. I've seen no problems, no collaping and the 2 o-rings are of good quality. They're not expensive and are readily available at Meijer....that's the main reason I use them.
    That said...with the spin-ons? I'll stick with my PureOne. ;)
  15. Aug 31, 2014 at 8:36 AM
    #135
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    that's a great observation
  16. Aug 31, 2014 at 8:50 AM
    #136
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Yep. The Toyota filters for our trucks are made by Denso (it says so right on the canister). Interestingly, the Denso-branded aftermarket filters have a different construction:
  17. Aug 31, 2014 at 3:06 PM
    #137
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    How about a picture of a "cardboard " valve.
  18. Aug 31, 2014 at 3:13 PM
    #138
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Honda filters A01 = Filtech, A02 = Fram pretty simple.
  19. Sep 1, 2014 at 5:22 AM
    #139
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Fram's parent company is Honeywell they are often branded as such in an OEM situation such as Subaru who's filters are Honeywell Canada. Fram shows up in the Acura's I don't believe that to be a "low end car" Fram is the number one aftermarket filter this of course means that any bozo that decides to change their own oil most likely is using a Fram filter that leaves a lot of room for stupid things to happen. WalMart has the cheapest oil I have found any where I can buy oil there for a lot less than I can from NAPA even with my commercial account I grab the oil and often a Fram filter how many 10's of thousands of people do you think do the same thing?
  20. Sep 1, 2014 at 1:14 PM
    #140
    evile
    evile Well-Known Member
    Orlando, Fl
    2006 DoubleCab TRD OffRoad PreRunner
    Bug shield vent visors Westin Chrome bull bar K&N Airfilter Pioneer CD/MP3/Ipod/DVD head unit KC Daylighters, LED map and dome lights, secondary airfilter removed. Black tube steps, 110v outlet in cab
    IVe always used mobil 1 filters and oil in my taco
