Frame Corrosion - Warranty Enhancement Notification for 2nd Gen (2005-2010)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by buffalotaco90, Sep 20, 2017.
  1. Sep 20, 2017 at 9:11 PM
    buffalotaco90
    buffalotaco90 [OP] Well-Known Member
    Portland
    ‘21 DCSB OR | ‘06 DCSB Sport (Sold)
    Did everyone that owns a 2nd Gen get a warranty enhancement notification from Toyota recently?
    "Toyota would like to advise you of an enhancement to portions of your Toyota New Vehicle Limited Warranty as part of a finally approved and implemented class action settlement.
    Toyota has received reports regarding frame corrosion on 2005-2010 model year Tacoma vehicles."
    Blah blah blah....
    "If perforation of the frame from rust corrosion meets or exceed the Rust Perforation Standard, the frame will be replaced at no cost under the terms of this Warranty..."
  2. Sep 20, 2017 at 10:27 PM
    Edwinc357
    Edwinc357 Well-Known Member
    Edwin
    2006 Toyota Tacoma
    I'm getting my truck back tomorrow with a brand new frame done under this new warranty program. If you have not gotten a new frame or think you have rust issues take your truck for an inspection.
  3. Sep 20, 2017 at 10:29 PM
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    What is the "rust perforation standard" how rusty does it need to be?
  4. Sep 21, 2017 at 2:55 AM
    vram74
    vram74 Well-Known Member
    05 Prerunner SR5
    Is this new from the limited service campaign thats been going for months?
  5. Sep 21, 2017 at 7:51 AM
    Edwinc357
    Edwin
    2006 Toyota Tacoma
    10mm hole or bigger will get you a new frame. If you don't have one then you only get a crc.
  6. Sep 21, 2017 at 3:10 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Look around esp by cats & mufflers - the heat plus road salt = holes in frame. Mine was hidden by muffler - tech found it - experience counts - the only rust I had because I took care of the frame - couldn't be happier - got a new frame, new brake lines, new brake fluid, new antifreeze etc, etc.
    buffalotaco90[OP] likes this.
  7. Sep 21, 2017 at 9:43 PM
    buffalotaco90
    Portland
    Ill be taking a look this weekend, only owned the truck since January and it was in Arizona and Vegas for 10 years before that so not going to be much road salt but we'll see
  8. Sep 22, 2017 at 7:47 PM
    Blueshound24
    Blueshound24 New Member
    2006 Toyota Tacoma
    I was told by our local dealer it must have a hole all the way through the metal from rust.
    Edwinc357 likes this.
  9. Sep 22, 2017 at 7:49 PM
    Oreo Cat
    Now I wait..
  10. Nov 16, 2017 at 9:14 AM
    QChawks
    QChawks Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
    I received the letter yesterday, but it doesn't show Iowa listed in the cold weather state section?
    WTF?
  11. Nov 16, 2017 at 9:36 AM
    supermagic
    supermagic Active Member
    2007 Black Taco Base Access Cab 4x4 V6 Manual
    I think the "Cold Climate State" list is really "Cold Climate Where They Salt the F Outta The Roads". The North-East U.S. is especially egregious in this respect.
    Does Iowa use road salt in the winter? Once upon a time, I lived in a place where they never salted the roads but instead used pumice or some other ground-up volcanic rock on the roads when it snowed (there was a nice volcanic field to the north east, so that was convenient). Made vehicles really dirty, but didn't rot them out either. Also, didn't work too terribly well unless you repeated frequently. But you win some and lose some.
  12. Nov 16, 2017 at 9:51 AM
    VanTheTacoMan
    VanTheTacoMan New Member
    Van
    2010, 4 CYL, 4x4, MAN, SR5 CREW
    I'm in the process of buying a private sale, 2010 in NY with some rust but nothing too serious and definitely no holes as far as I can tell. If I bring it in for inspection is there a guarantee that they'll do the CRC or does it have to meet a certain requirement to get the CRC as well? Also, if I get the CRC do they grind out the current rust before coating it or should I do that before I bring it in?
  13. Nov 16, 2017 at 1:07 PM
    QChawks
    Davenport, IA
    2009 TRD Sport DCLB
    Heck ya they salt the roads in Iowa. I don't understand why they list OH, IN and IL but not IOWA?
    I guess I just need to call me local dealer and have them look my 2010 over.
  14. Nov 20, 2017 at 3:58 PM
    wikallen
    wikallen New Member
    I just got the letter. Iowa uses salt, sand, salt-water brine. It eats everything from steel to aluminium. I am curious as well why Iowa is not listed as a cold climate state. But I think I rather it not be coated at this point as not to cover up and hide suspect areas of rust on welds.
