Frame delamination - rear leaf springs mount area. Worth selling or try to fix?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Buckwheatthedawg, Apr 4, 2021.
  1. Apr 4, 2021 at 1:35 PM
    ajpagosa
    ajpagosa Well-Known Member
    SW Colorado
    2005 Access Cab TRD Off Road 6-speed manual
    No nothing like that. Just surface rust. Just thinking out loud, maybe someone towed a lot (or too heavy), does it have the factory tow package? Hard to believe a major rear-end collision could get past Carfax etc but who knows. The issue with frames was not bad engineering per se, just poor metallurgy at the supplier level. Maybe a lot of tongue weight on the hitch could do that? Have no idea. I go thru periods of towing a lot (firewood and trailers full of motorcycles) but have not seen that.
  2. Apr 4, 2021 at 1:39 PM
    ajpagosa
    SW Colorado
  3. Apr 4, 2021 at 1:41 PM
    Buckwheatthedawg
    Buckwheatthedawg [OP] Active Member
    2008 Tacoma TRD sport
    2 inch lift
    Hey thanks for that. I actually got it from a private seller. Clean carfax - they bought the car here in Colorado and had it in AZ as well. I am the second owner
  4. Apr 4, 2021 at 1:42 PM
    ajpagosa
    SW Colorado
    No problem, let us know if you find out anything.
  5. Apr 4, 2021 at 1:44 PM
    Buckwheatthedawg
    2 inch lift
    I am pretty certain this is a rust issue from the frame recall and the previous owner never took advantage of the recall. My mechanic royally dropped the ball during the pre-purchase inspection. In my opinion, they are the ones liable, but they've claimed "we aren't a frame shop - if you wanted the frame inspected, you should have taken it to a frame shop". No one takes their car to a frame shop to get inspected..
  6. Apr 4, 2021 at 2:00 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    That sucks! Especially since all it takes is a good visual on the frame. He just didn’t have a clue as a mechanic, especially since he was getting paid to look this over.
  7. Apr 4, 2021 at 2:03 PM
    Buckwheatthedawg
    2 inch lift
    It does suck - I talked with a lawyer who said I have grounds to sue, but I'm a young dude and am not made of money. In fact, the only reason I got this truck was to replace my Rav4 that was totaled by a semi-truck... Been an absolutely shitty month!
    Does anyone have any advice on what type of recourse I should be seeking here? I don't think insurance covers this but I'm hoping to pursue their insurance to get the truck bought out. I think it's a long shot.
  8. Apr 4, 2021 at 2:05 PM
    spitdog
    How much did you pay for the truck?
  9. Apr 4, 2021 at 2:12 PM
    Buckwheatthedawg
    2 inch lift
    I paid 16k
  10. Apr 4, 2021 at 2:16 PM
    spitdog
    I think it would be wise to take it to a chassis repair shop and get an expert opinion and estimate.
    Just make sure he writes you up a detailed estimate.
    SR-71A likes this.
  11. Apr 4, 2021 at 2:20 PM
    Buckwheatthedawg
    2 inch lift
    I actually got an estimate at a good repair shop. They quoted $5,600 parts/labor to get it back to factory specs. However, when I brought it to them, they didn't think that type of job was totally necessary. They just said, "here's the price if you care enough to fix it."
  12. Apr 4, 2021 at 3:24 PM
    Buckwheatthedawg
    2 inch lift
    Also, Toyota offered me a trade-in value of 11,250. That would be a big loss obviously. Confused as to what I should do now
  13. Apr 4, 2021 at 8:55 PM
    Buckwheatthedawg
    2 inch lift
    Does anyone have any other suggestions?
  14. Apr 5, 2021 at 6:43 AM
    Buckwheatthedawg
    2 inch lift
    I was quoted 5,600 to fix the frame at a body shop.. Toyota offered me 11,250 for the truck. I just paid 16 last month for it. What do you think I should do?
  15. Apr 5, 2021 at 6:53 AM
    #35
    JeffreyB
    JeffreyB Well-Known Member
    Jeff
    2015 Access Cab 2.7 5 Speed 4X4
    Is it causing you any problems? I'd probably not fix it and carry on as usual, but keep an eye on it.
    spitdog, DES2009 and Lawfarin like this.
  16. Apr 5, 2021 at 6:58 AM
    #36
    Buckwheatthedawg
    2 inch lift
    Well, it isn’t causing problems yet - though it only gets worse as there’s no way I can stop rust. The frame panels have been expanding apart from each other right over the leaf spring shackle. It feels like that’s a bad place for that to happen.
    Once it does get really bad, I will have less options. It will be difficult to impossible to sell with welded frame caps put on and if I did do a professional job, that’d be a huge expense (plus it may damage the title of the truck).
    I really am at a loss because it’s not something that will be easy to repair. It’s very much a ticking time bomb.
  17. Apr 5, 2021 at 7:00 AM
    #37
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Get in there and try and clean it out the best you can with something abrasive. Then spray some primer in there, let it dry, then coat it with something. Then I would spray some fluid film or something in there to coat it and not worry about it for a while. Then every so often do touch ups. It’ll be fine
    DES2009 likes this.
  18. Apr 5, 2021 at 7:03 AM
    #38
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Yup.
    OP this is not a rust issue imo. That frame looks really good otherwise. I mean it still has paint on it ffs.
    Does the truck drive fine and track straight? If so Id be inclined to not worry about it. Maybe give it a good pressure wash, and then spray some Fluid Film in those waves to prevent any future rust
  19. Apr 5, 2021 at 7:06 AM
    #39
    Buckwheatthedawg
    2 inch lift
    Thank you for chiming in. I definitely need all the advice I can get on this! Horrible feeling.
    What makes you say that it’s not a rust issue? I actually found it while applying fluid film. The frame rails are rotting inside and pushing the panels outward. If that’s normal then I’ll keep driving it, but many people have said that used to qualify for the frame replacement.
    At this point I’m worried that if (when) it gets worse, I’ll be out of reasonable options for it.
  20. Apr 5, 2021 at 7:08 AM
    #40
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    If you’re really worried about it clean it out, clamp the shit out of the frame and weld the seam up
