Frame Dimensions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by blake5995, Feb 17, 2013.
  1. Feb 17, 2013 at 11:25 PM
    blake5995
    blake5995 [OP] Well-Known Member
    Blake
    Truckee, CA
    98 Tacoma SR5 4x4 2.7L
    Does anyone know were i can find all the dimensions for a second gen double cab frame?
  2. Feb 18, 2013 at 12:26 AM
    DoorDing
    DoorDing Intentionally obtuse
    Bodie, CA
    2017 RC Off-Road 3.5WD
    yes
    Before anyone asks why, he isn't telling. :spy:
    That covers a lot of ground. Did you need a particular measurement? If you want a lot of exact numbers, a frame or body shop may be able to help. I'll dig around in the FSR later.
    Update: You can try rooting around here, but I didn't find much. You may have better luck searching TIS for frame specs.
  3. Feb 18, 2013 at 2:24 AM
    blake5995
    Blake
    Truckee, CA
    Yea i am not telling anyone what i am doing it is all a secret :spy:
    i need to know where all 4 cab mount holes need to be and the width of the frame under the cab. Basically all the measurement that are under the cab.
  4. Feb 18, 2013 at 2:29 AM
    blake5995
    Blake
    Truckee, CA
    didnt find any info on frame on that link. I will call up my friend at the toyota dealership see if he has any info and maybe a friend that works at a body shop i dont want to buy the cab yet would rather start working on other stuff first.
  5. Feb 18, 2013 at 6:28 AM
    DoorDing
    Bodie, CA
    yes
    You probably need more information than will be easity found by me crawling under my truck. Maybe a trip to a salvage yard would help. Good luck with your NSA build.
