Frame Failure AFTER Dealer Inspection?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by WhiteDog, Jun 20, 2018.
  1. Jun 20, 2018 at 1:43 PM
    WhiteDog
    WhiteDog [OP] King of the Brittanys
    Brian
    Central Indiana
    hello
    During my oil change I saw this:
    My frame was inspected two years ago and coated by the dealer. Am I hosed from qualifying for a replacement?
    Not sure what the rules are after treatment.
  2. Jun 20, 2018 at 1:55 PM
    WhiteDog
    Brian
    Central Indiana
    Jeff
    Dealer has a record of the work performed. Why I didn’t notice it before was this time I pressed the corroded area with my thumb and it broke through. Just using my fingers I could break away frame.
  3. Jun 20, 2018 at 1:57 PM
    WSW3
    WSW3 @willwitecki
    Will
    Connecticut
    '08 Tacoma DCSB TRD Sport
    Scratches, dents, and a lot of miles
    That's effed dude. What year is your truck?
  4. Jun 20, 2018 at 1:59 PM
    WhiteDog
    Brian
    Central Indiana
    2006 is the model year. Heck the frame was inspected and the rust at that area was no different than any other area on the frame. Just this time I decided to inspect this location based on what I read here!
  5. Jun 20, 2018 at 2:02 PM
    kirkofwimbo
    kirkofwimbo Well-Known Member
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    I know with the 1st gens, having it coated extended the amount of time warranty would cover it.
  6. Jun 20, 2018 at 2:02 PM
    WSW3
    WSW3 @willwitecki
    Will
    Connecticut
    Oof, I hope you have a record of the frame inspection somewhere. I think I heard the cutoff is 12 years for a frame replacement. The frame was probably pretty bad when they coated it, but for whatever reason they did it anyway. I'd definitely work hard to get a new frame though.
  7. Jun 20, 2018 at 2:06 PM
    high n mighty
    high n mighty Well-Known Member
    Oshawa Ontario
    01 camo taco
    15 year warranty from in service date after dealer inspection and rustproofing
    You will get a new frame
  8. Jun 20, 2018 at 4:14 PM
    WhiteDog
    Brian
    Central Indiana
    High’n’mighty
    Good news, is the 15yr warranty extended warranty spelled out in settlement web page? My recall notice does not mention it. FYI. The frame was inspected and treated with CRC on 9 Jan 2015. “No rust” found....
  9. Jun 20, 2018 at 4:34 PM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    So I’m pretty sure the states only get 12 yrs. But if you had been coated you must have qualified earlier. So you have 1 year from the class action suit that settled earlier this year. I’d say you are gonna get a new frame. Had to be purchased by a certain date also.
  10. Jun 20, 2018 at 4:44 PM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    I had mine inspected last year. No rusty found, but no CRC offered either :notsure:
  11. Jun 20, 2018 at 4:49 PM
    Dennisi01
    Dennisi01 Well-Known Member
    Dennis
    Forks, PA
    '10 SR5 4x4
    None
    What state do you live in?
  12. Jun 20, 2018 at 5:05 PM
    replica9000
    2019 T4R ORP
    RI, bought in MA. Brought my recall notice when I went for the inspection.
  13. Jun 20, 2018 at 5:25 PM
    Dennisi01
    Dennis
    Forks, PA
    '10 SR5 4x4
    None
    Crazy, you should get crc..
  14. Jun 20, 2018 at 7:18 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    I think it’s 15 years from in service date. I had a 2000 x-tra cab that Toyota bought back from me in 2010. I know my notice said 15 years at that time.
  15. Jun 20, 2018 at 7:24 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    It's pretty obvious the dealer missed something on the first look.
    Take it back, they should give you a frame
    buckhuntin-tacoma likes this.
  16. Jun 21, 2018 at 6:21 AM
    WhiteDog
    Brian
    Central Indiana
    Dealer agrees the hole meets the 10 mm dia .
    Just waiting on corporate preapproval to start the process. Quoted me 3-4 months for frame
    Claims it is safe to drive.
  17. Jun 21, 2018 at 7:03 AM
    Dennisi01
    Dennis
    Forks, PA
    '10 SR5 4x4
    None
    Lo
    Looks like you win! Check to see if you need to replace any suspension stuff and buy it cheaper and have them replace for free. Also give the truck a thorough, thorough inspection before leaving the lot. If i ever get a new frame id earmark an hour to drive around the lot, check fluids, brakes, all electronics and check engine bay and underneath as best you can to look for loose connections, bolts and screws. A lot of these techs do these frames a lot but it breeds hubris and complacency. Enjoy your mostly new truck for the fall!
  18. Jun 21, 2018 at 8:07 AM
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    IT should be covered under the Warranty Enhancement Program even if previously given the eyewash treatment...
  19. Jun 21, 2018 at 8:35 AM
    WhiteDog
    Brian
    Central Indiana
    Yeah happy that Toyota man’ed up
    But one thing bothers me. I sort of peeked into the inspection process while my Taco was on the lift. Not once did the Mechanic use a tool to test rust patches to see how firm or loose the base metal was along the frame. I know I have other spots that likely are bad but didn’t inspect them once the first spot broke through. Maybe that was his approach too.
    The failure was found using finger pressure, not visual.
    Not whining but owners beware!
  20. Jun 21, 2018 at 8:46 AM
    Armyhater458
    Armyhater458 Well-Known Member
    Clarion, PA
    2012 TX Pro
    OME 887, LR UCA, Dakar 095 (medium duty), Dick Cepek Extreme Country 255/85/16
    Does anyone know where i can find the frame recall info? I am trying to determine if it is only 05-11, or if it was extended to 12-15 as well. My frame is just minor surface rust, but living in the rust belt I want to make sure that i at least get it inspected and documented.
