Frame inspection passed.. anything else supposed to happen
Discussion in '1st Gen. Tacomas (1995-2004)' started by smbundy13, Aug 26, 2010.
  1. Aug 26, 2010 at 9:19 AM
    smbundy13
    smbundy13 [OP] Well-Known Member
    Scott
    Birmingham
    so, I got my frame inspected last weekend and the dealership said that it looked good.
    were they supposed to anything else? I have read somewhere that they were supposed to coat it?
    thanks alot.
  2. Aug 26, 2010 at 9:20 AM
    HeadlampRevamp
    HeadlampRevamp Well-Known Member
    Jacob
    Buckner, ky
    03 Tacoma SR5 TRD
    yes, you are supposed to get an under coating. At least around here thats the procedure since I'm in the salt belt. Not sure about AL.
  3. Aug 26, 2010 at 12:07 PM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    Pretty sure only the approved states get the undercoating. I didn't get it either, so I just did it myself with some 3m undercoating spray on the outside and http://www.eastwood.com/internal-frame-coating-w-spray-nozzle.html on the inside.
    I used about 1.5 cans for my frame when I did it, but I've been thinking I probably ought to put on a 2nd coat one of these days (although the instructions doesn't say it needs it). When I did it, I felt like I was putting it on fairly thick, but it being in the tube, it makes it hard to judge. The paint seems really thin to me (probably on purpose to help get under the existing rust), and dripped out the frame any place there were manufacturing holes. The tube they include is quite cool and makes applying it inside the frame pretty easy.
    If rust is a major concern on the outside, I'd probably suggest going with something a bit more rust prevention on the outside than the 3m stuff I used.
    From what I understand, the stuff the dealer puts on isn't that fantastic and ends up falling off the outside within a year, so you'd be better off just putting your own stuff on anyway.
  4. Aug 26, 2010 at 2:49 PM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
  5. Aug 26, 2010 at 8:27 PM
    96er
    96er Sport Rally'er
    MA
    '96 Tacoma XCab 4x4 SR5
    Use POR 15 it is a rubberized undercoating which is real, real thick stuff.
  6. Aug 27, 2010 at 9:25 AM
    HeadlampRevamp
    Jacob
    Buckner, ky
    03 Tacoma SR5 TRD
    Yea the stuff sucks. Mine is already falling off after 6 months. I'm just going to let it all fall off so the frame will fail inspection.
