frame just replaced, now there's some red fluid on my garage floor
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomaPrime, Feb 4, 2015.
  1. Feb 4, 2015 at 8:09 AM
    TacomaPrime
    TacomaPrime [OP] Cybertronian Tacoma
    Gregory
    Illinois
    14 TRD sport 4x4 Barcelona Red
    Weathertech front floor liners, window vent visors. Custom bedside decals. OEM bed mat, tonneau covrew. Added D rings to bed.
    Pulled my truck halfway out of my garage last night to reroute my engine block heater cord, since it wasn't located where I had it before the frame was replaced. When I pulled the truck out and looked on my garage floor, I had some red fluid on the floor. I have never had any leaks, oil or tranny fluid, or any fluid for that matter. In fact when they called me to tell me the status of my truck, that they were taking it apart, they said they found no leaks either. So I am a little worried. I called the dealer and they said to bring it in , so I am bringing it in today after work. I hope to god I don't all of a sudden have a tranny leak.
    Is it possible they just overfilled it and it's just coming out some overflow plug or something?
  2. Feb 4, 2015 at 8:36 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
  3. Feb 4, 2015 at 8:39 AM
    TacomaPrime
    Gregory
    Illinois
    I didn't take one cause I didn't have my phone on me at the time. :mad:
  4. Feb 4, 2015 at 8:43 AM
    OICU812
    OICU812 Well-Known Member
    Why not just crawl under it and look around???
  5. Feb 4, 2015 at 8:44 AM
    TacomaPrime
    Gregory
    Illinois
    I just figured that since it was fine when I took it in, I should take it back so they don't try to blame it on me.
  6. Feb 4, 2015 at 8:45 AM
    Clearwater Bill
    Billy
    Largo Florida
    I'll make guesses, cause that's all we can do on the internet with things like this...........
    1) It will be transmission fluid
    2) It will be from a cooling line fitting that they didn't replace properly
    3) It will be simple and of course free
  7. Feb 4, 2015 at 8:45 AM
    Flowin
    Flowin Well-Known Member
    Acworth, Georgia
    2014 DCSB TRD OFF ROAD
    OME 3" lift, 265/75/16 KO2s, 35% tint
    they won't blame you for looking where it's coming from, but it "sounds" like transmission fluid
  8. Feb 4, 2015 at 8:52 AM
    TacomaPrime
    Gregory
    Illinois
    I hope to god that is the case.
  9. Feb 4, 2015 at 8:52 AM
    TacomaPrime
    Gregory
    Illinois
    I'm sure it is. I could look but I'm at work, so I don't have that ability to look before I take it in.
  10. Feb 4, 2015 at 9:01 AM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    power steering fluid will leak red.
  11. Feb 4, 2015 at 9:03 AM
    TacomaPrime
    Gregory
    Illinois
    hmmm. well it's one of those two then cause it was definitely red. not sure 100% sure where it was coming from but yeah.
  12. Feb 4, 2015 at 9:04 AM
    Shauncho
    Shauncho Embrace your inner Bro-ness
    Shaun
    Parts Unknown...
    none
    it just had it's period...buy it some tampons or something.
  13. Feb 4, 2015 at 9:07 AM
    Shauncho
    Shaun
    Parts Unknown...
    none
    :rofl:
  14. Feb 4, 2015 at 9:07 AM
    TrdSurgie
    TrdSurgie revised
    Oahu
    I bet its this. Hooking up the power steering rack can be messy.
  15. Feb 4, 2015 at 9:08 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    does it mix with water or not ?
    yes, coolant
    no, tranny fluid
  16. Feb 4, 2015 at 9:10 AM
    Tacomanator
    Clam Slammer
    Southern Cali
    Yeah, i'm betting it's ps fluid.
  17. Feb 4, 2015 at 4:39 PM
    TacomaPrime
    Gregory
    Illinois
    so I took it in tonight and they said all the cooling lines, transmission lines looked fine, and the power steering fluid was full. They said there was some fluid on the skidplate and frame from when they removed the engine and transmission, and they cleaned it off. I said ok, and left. When I got home I put cardboard where the fluid was from yesterday, went out and snowblowed the driveway, and when I came back in, there was more fluid on the cardboard, so I got up under there and took this pic....
    What is that, why is it leaking?
    Also, I will not be paying to fix this. I had absolutely no leaks when I dropped the truck off, so I expect to get it back the same way.
  18. Feb 4, 2015 at 5:00 PM
    Burnwithin
    Burnwithin Member
    CJ
    monroe
    10 tacoma
    thats the output shaft seal on the transmission i cant see the dealership covering this it is a wear part and probably what happened is the seal is old and when the tech removed the drive shaft it finally started leaking when it went back in on the install its a simple cheap fix good luck
  19. Feb 4, 2015 at 5:12 PM
    TacomaPrime
    Gregory
    Illinois
    Well fuck. At least it's cheap and simple.
  20. Feb 4, 2015 at 5:15 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    Yeah, all you need to do is replace the seal. No damage done.
