frame plating
Discussion in 'Technical Chat' started by Bearskill, Sep 29, 2009.
  1. Sep 29, 2009 at 11:52 PM
    Bearskill
    Bearskill [OP] Well-Known Member
    Sac
    06 Access cab PreRunner Sport
    FlowMaster 40 duals out the back, T-Rex grill, Color matched TRD Nerf bars, Icon coilovers set at 2'', 2.75" OME Dakars spring packs, OME Nitro-Charger extended rear shocks, Carrier bearing drop kit, Wheeler's Extended break Lines, Total Chaos UCAs, Mojave Teflons and 31 1/2" Toyo Open Country A/Ts, Pioneer single din unit, Yakima roof rack, Malone roof basket with X2 KC 130w long range Slimmlights mounted to it, Garmin 255w nav, Fire bottle mod, Air Force standard First Aid kit mod, Hidden Muchette mod (don't ask), and 1 huge OCD about my truck.
    I have read a crap load of posts about plating the frames of older Tacomas, but has anyone renforced the frame on a 2005+ Tacoma? I did see the one post about that bad ass SAS, but other than that.
    Just wondering.
  2. Nov 16, 2009 at 4:28 PM
    S-M-R-T
    S-M-R-T Well-Known Member
    Plating is usually done to fix a weak area (rust) or for adding strength to withstand stresses that it wasn't designed for, as in custom steering or and suspension. It is not something that you should need to worry about unless your truck sees some extreme use. There were a few '05s that had weak motor mounts that needed some plating but that was fixed in the '06+ years.
  3. Nov 16, 2009 at 4:37 PM
    Crom
    Crom Outside
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    X2
