Frame PLugs (04002-07104)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rtadams89, Jun 6, 2020.
  1. Jun 6, 2020 at 8:34 PM
    rtadams89
    rtadams89 [OP] Well-Known Member
    Phoenix, AZ
    2017 Tacoma Limited
    I saw a post that referenced the "Toyota Plug Kit 04002-07104" which apparently plugs up a bunch of the holes in the frame. Are these plugs supposed to be installed by the factory, or are they an add-on after? Is there a diagram that shows where the plugs in the kit go? My frame has some holes plugged, but there are some open on the frame; I'm trying to figure out if those plugs got lost and if this kit would have the replacements in it, or if there never were any plugs in those holes by design...
  2. Jun 7, 2020 at 2:11 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Try google search, I have seen it somewhere before. If you have a Tacoma and no front air dam spoiler like the OR and the Pro and its a 2017 I think, then you should be good to go. I could be wrong on the year. I have an 18, pull off the spoiler and no issues. Mine had some plugs, however I bought some from the dealership and put in a plug on each side, I followed the tsb and the pics to make sure I got the correct hole, careful not to do the lowest hole as water can get trapped in and rust. Looking now for the link.
  3. Jun 7, 2020 at 2:18 AM
    rtadams89
    Phoenix, AZ
    2017 Tacoma Limited
  4. Jun 7, 2020 at 2:46 AM
    VaToy
    Parts Unknown
    Gotcha.Thought you were talking about holes that were causing whistling sounds as air getting trapped in the cross members. Your question is a new one to me.
  5. Jun 7, 2020 at 3:04 AM
    TacoTheTaco
    TacoTheTaco Well-Known Member
    DC
    2018 TRD Sport 4x4 DBL Cab
  6. Jun 7, 2020 at 5:07 PM
    rtadams89
    Phoenix, AZ
    2017 Tacoma Limited
    Hum, seems even more confusion around what plugs are needed and where they go...
