Frame Preventive Maintenance
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tepidy, Mar 14, 2011.
  1. Mar 14, 2011 at 4:12 PM
    Tepidy
    Tepidy [OP] Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    Good to crawl under you truck especially if its new or fairly new to check on any rust turning up. I spray Rustoleum Bedliner everytime I see some rust. Easy to do maintenance check once a week. I have done this will all my trucks that I have owned over my lifetime and never had any issues. Plus it keeps the undercarraige looking great.
  2. Mar 14, 2011 at 4:18 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Yeah I use the Rustoleum undercoating twice a year. I just hit my frame rail with a wire wheel and removed all the rust and sprayed a fresh coat of undercoating and it looks like a new frame now.
  3. Mar 14, 2011 at 5:23 PM
    TUVAI
    TUVAI Active Member
    Polynesia
    07 DC TRD
    MBRP
    I painted the hole frame took all tires off, skid plates, an hit it with the wire brush an painted it with rustolem hammered black it looks good
  4. Mar 14, 2011 at 5:32 PM
    bowhunter11199
    bowhunter11199 Well-Known Member
    ya same here but i usually do it 10+ times a years but i think por-15 works gerat too. and its a do it once and never again. kinda like rhino bedliner.(but i've never used it...yet)
    but anyways i looked up my taco on the toyota website and it shows that there was no recalls for my 98:confused:. i thought there was... anyone know anything about this?
  5. Mar 14, 2011 at 5:42 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    I get under my truck a few times a year with rustolem paint and a small brush. The only places I've had to touch up so far are just around the welds.
  6. Mar 14, 2011 at 6:16 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Why rustoleum ? :confused:
    It does not do much. You need to to hit the frame with solid primer (something with rust inhibitors) then with decent paint to seal the primer and frame.
    Rustoleum is for touch up and even at that fails.
  7. Mar 14, 2011 at 7:46 PM
    Tepidy
    Ted
    upstate NY
    11 tacoma 4x4
    Not true bro. Rustoleum has rust inhibitors in it and if you have ever seen the bed liner line its thick and really good.
  8. Mar 15, 2011 at 4:47 PM
    Uncelou1980
    Uncelou1980 Active Member
    New Jersey
    2006 Toyota Tacoma Pre-runner 2WD Double Cab
    So what will be the best option for my truck ( FRAME) , the Rustoleum undercoating or the Bed Lines line ???????
  9. Mar 15, 2011 at 4:51 PM
    thebottomline
    thebottomline Well-Known Member
    Pac NW
    11 sport
    doesn't the undercoating stuff have a textured plastic like appearance?
    I saw it at walmart the other day but it said it was a rough look...
  10. Mar 15, 2011 at 5:01 PM
    DocCisco
    DocCisco Well-Known Member
    David
    Utah County, UT
    LB TRD Sport 4x4
    That's where I got mine. You really should wire off any rust first, wipe it dry then spray on the Rustoleum.
  11. Mar 15, 2011 at 5:02 PM
    Skymech
    Skymech Member
    Randy
    Indiana
    2008 Tacoma TRD Sport 4x4
    Bilstein 5100 front and back w/OME 884 Coils Front AAL back, ToyTec 1" Diff Drop, Back to the stock exhaust (flowmaster's muffler rusted apart) AFE Cool Box Intake, Bestop Supertop bedcover, LED Light Mod on all external & inside dome and map , Kenwood eXcelon+ JL Audio Stereo w/XM and iPod interface. AMSOIL through out
    I have been using KBS Rust Shield then hit it with VHT Epoxy Frame Paint.
    All i can say is that rust NEVER comes back to the same spot even after 3 years and over 81,000 miles of midwestern weather it looks almost showroom new.
  12. Mar 15, 2011 at 5:08 PM
    WTtoolman
    WTtoolman Facial bones colapse as I crack your skull in half
    William
    Omaha, NE
    2006 Access Cab 4x4 TRD SWB
    5100s at 0, eibachs, 2" toytec AAL,, Moto Metal 951b, BFG A/T
    What is this VHT Epoxy Frame Paint and where do you get it?
  13. Mar 15, 2011 at 5:13 PM
    HomeGrown
    HomeGrown Well-Known Member
    Bill
    South Bend, IN
    2014 Reg Cab 4WD
    I wish Toyota had an option for a stainless steel frame.
  14. Mar 15, 2011 at 5:19 PM
    Rook
    Rook Active Member
    Morristown, NJ
    Nissan Titerra
    800lbs of armor, 35's, 5"SL 2" BL, Shrock Rear Bumper, TAG front Bumper
    u guys ever try Por15. it's amazing stuff. it dries so hard you cannot chip it with a screwdriver. I painted the frame of my rig with it 2 years ago and it still looks like new...
    check it out :)
    http://www.por15.com/POR-15-Rust-Preventive-Paint/products/1/
    it's a little like Krown...but i think its a bit better. I plan on painting my floors with it this summer. :)
    that would be freaking awesome....but unfortunately stainless steel is much weaker than regular steel :)
  15. Mar 15, 2011 at 5:39 PM
    thebottomline
    Pac NW
    11 sport
    Thanks for the link, it looks promising.
  16. Mar 15, 2011 at 11:05 PM
    Skymech
    Skymech Member
    Randy
    Indiana
    VHT Epoxy Paint is a 1-step epoxy coating that does not require the use of a primer.
    It has been formulated to give the appearance and durability of a baked-on finish I.E. Powder Coating.
    It provides a porcelain-like finish that is chemical, corrosion, rust and salt resistant.
    I found it at Advanced Auto Parts for $6.99 a can
    http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_Epoxy-Paint-VHT-Paint_7141585-P_N3587_T|GRP2050____#fragment-1
    This is the link for KBS. http://www.kbs-coatings.com/
