Frame problems, need help guys
Discussion in '1st Gen. Tacomas (1995-2004)' started by Camdg2010, Nov 12, 2017.
  1. Nov 12, 2017 at 5:47 PM
    Camdg2010
    Camdg2010 [OP] Well-Known Member
    Hey guys, i got a 2002 tacoma, it was a tow call that owner didnt pay for and come back for.. well it runs and drives tit! the problem is, the frame.... :( some (moron) put in a 3 inch lift kit... well the frame behind the cab is cracked in 3 spots, the guys that had it must think they are engineers or something. ive seen dog poop that looks better than these welds. i had a solution to fix the back half so i kept on pecking away, got out the wire wheel on the grinder, noticed factory paint on frame rails under cab and was pretty satisfied... then i got to the right front. they must have either broke or cut and lowered the springpurch, its same as the rear. scabbed over with plate steel, and looks like trash. i cant find the time to do a frame swap. i love tacoma's and ive always wanted one, now i have one and its no good. im kinda heart broke... im at a loss. hopefully the pictures go through so you can have a look. other than junking the truck, whats your ideas? i live in vt so finding a non rotted frame for an 02 is going to be next to impossible.
  2. Nov 12, 2017 at 6:05 PM
    Camdg2010
    heres a question. i was just looking online at frames, for about 3500 i can have a frame.. but i can also but the rotted sections and replace them... why cant i do that? stick rectangular tubing inside frame rails, weld it and weld replacement section back on. so it supports both halfs? weld it so it looks factory? the back half would be easy.. the front on the other hand with motor mounts and stuff... not sure if its even worht messing with, but a free tacoma that runs and drives!?!?!? never hear of a tacoma for much less than 5-7 grand even beat to h**l and back...
  3. Nov 12, 2017 at 7:30 PM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    Your frame looks very rusty.... I'd thoroughly bang it with a hammer to see what is still good and what is rusted through. Then you'll have a better idea of all the repair work that will have to be done.
    Then give this a look:
    They make repair patches for tacoma frames
    https://www.autorust.com/product-category/toyota-tacoma/
  4. Nov 12, 2017 at 7:58 PM
    tony2018
    tony2018 Well-Known Member
    part it out,
  5. Nov 12, 2017 at 8:13 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    ^ this is a valid option if you have the skills. you could make enough to put it towards a better one.
    otherwise it seems you have the skills to fix. what about the VIN, did you see if it was taken in to Toyota for the rust campaign? it's only a month left but probably not
  6. Nov 12, 2017 at 9:11 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Were are you located? I can get good Arizona rust free frames for around $1200-$1500 complete. Also sections of frames.
    Navelfunk, Jcyr and T4RFTMFW like this.
  7. Nov 13, 2017 at 3:05 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    OP is in Vermont From AZ to Vermont would tend to be expensive transportation costs
    Unless you have a sweet Deal set up with a carrier !
    Nothing there on your Truck that can`t be fixed if you have the skills and the time.
    Think about what you can afford in real world numbers then figure out what to do.
  8. Nov 13, 2017 at 4:48 AM
    Camdg2010
    thats the thing, i drive tow truck and im on the road 6 days a week all day. Once i saw rust, i grabbed my ball peen hammer and went to town on it.. the center sections look and feel to be intact. ive towed in several wrecked tacomas and even insurance companies want over 1000 for them and i have somewhat of a small budget... apparently these have gold in them somewhere... obviously not the frame! lol. i was watching online and they sell weld on replacement sections. not sure how that would look. ive done frame work on a 1ton before but wasnt happy with it. it seems to be cab back thats ruined, cab forward seems to be ok. i picked up some Rustoleum rust converter, black primer and black paint and black rubberized undercoat. I was planning on doing a frame splice then sandblasting the frame or something then rust converting it, priming then painting frame rails. and i know that looks bad (the center sections) to most, but remember, i live in Vermont and they go spreader happy with the road salt. it seems to be just surface rust from what i can tell. and i dont think anyone would buy many parts out of it.. then i have a dead carcass in the garage to deal with.
    do i fix it? put a new power steering pump and alt in it or ship it?
  9. Nov 13, 2017 at 1:15 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Why would it look bad if you know what your doing !!
    It all comes down to having the time to do the job
  10. Nov 13, 2017 at 1:31 PM
    JoeK
    JoeK Well-Known Member
    NC
    15 MGM TRD Sport DCLB
  11. Nov 13, 2017 at 4:16 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    it's a 2002, at best a month left. "if" it was taken in, which judging by the amount of so-called "poop welds" was probably not.
  12. Nov 13, 2017 at 4:23 PM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    You said you can get a new frame for $3,500? Why not do that? Seems like a small investment in money for a solid foundation that you will not have to keep pecking away at with repairs. Your big investment will be in time to do the swap but it would probably even out with the time you'd spend repairing it.
  13. Nov 13, 2017 at 5:07 PM
    Camdg2010
    i would just buy a new frame for 3500... if i had 3500 to spend on it right now. i will in a few more months but then i have to find somewhere to tear this one down and store the frame until i can swap it. if i did the weld on replacements, is that legal to be inspected? i know some places wont inspect if they see ANY frame patch or mods, thats why i want to cut the rear half off, insert a section of rectangular tube inside the truck frame rail and weld on the back half of a good frame. if i do it right, take my time then it "should" look factory. the only spots i know i would need those replacement weld-on's is in the front near suspension because they welded a single 2x3 plate on both left and right sides
  14. Nov 13, 2017 at 5:12 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    inspect the top of the frame really well. it looks to be peeling a little in most pics. salt will sit up there too as you know.
  15. Nov 13, 2017 at 5:14 PM
    Camdg2010
    well.. as luck would have it, my buddy just totaled his 02 about 45 mins ago, im praying i can buy it off him. his was frame swapped! fingers crossed!
  16. Nov 13, 2017 at 5:24 PM
    ScrapmanIndustries
    ScrapmanIndustries Well-Known Member
    98 reg. cab tacoma, 17 access cab tacoma
    thanks for sharing. I may be in need of their mid frame kits for my 98. I was just about to ask if anyone made a kit but i guess that question was answered before it was asked.
    onakat[QUOTED] likes this.
  17. Nov 13, 2017 at 6:55 PM
    Camdg2010
    well guys, good news. its mine! he just had the frame swapped 3 months ago. put in a new lift kit and new mud tires a few weeks ago. i just got it for 300 buck! im pulling my cab and bed and putting it on this. both are extra cab and 5 speed. hopefully his motor is good but if not i have mine still.
    Dalandser and GHOST SHIP like this.
  18. Nov 13, 2017 at 7:01 PM
    Camdg2010
    even if its bent which it looks like it is, looks like the bed is out more than the cab but that may be cab damage idk. i havent seen it yet. but for 300 buck i think its worth straighten it if its not to bad
  19. Nov 13, 2017 at 7:47 PM
    BossFoss
    BossFoss If your over 40 feet back, you ain't suspicious.
    Wyoming
    01 DC Tacoma
    I had one where the back half was rusted and the front was good. Chopped the frame behind the cab and welded on another one from a parts truck I had. Could be easier than tearing two trucks all the way down. Got it pretty close, within a 1/16-1/8 and it doesn't drive any different.
    cruxofthebisquit and Dalandser like this.
  20. Nov 14, 2017 at 1:18 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    As to safety inspection that would be a State by State thing Here in Pa it seems to be no Big deal.
    Might also be at the whim of who is doing the inspection I ran into that a Few times when I sent Mom or female friends
    After building New and Repairing Frames on most all makes .
    I am sure the quality of the work might come into play
    I hope your friend was not Hurt That looks like a pretty good Hit!!!
    Dalandser likes this.
