Frame protection
Discussion in '1st Gen. Tacomas (1995-2004)' started by Flamingskull, Sep 20, 2022.
  1. Sep 20, 2022 at 8:56 PM
    Flamingskull
    Flamingskull [OP] Well-Known Member
    Jeff
    2002 Toyota Tacoma 2.7
    I get my truck frame oil sprayed every year.
    But now I have my bed removed and I was wondering if it would be a good idea to clean the oil off and put Rust-Oleum on the frame. Then after the Rust-Oleum dries get it oil sprayed over the Rust-Oleum
  2. Sep 20, 2022 at 9:12 PM
    vtwoodchuck
    vtwoodchuck Well-Known Member
    New England
    2001 Reg Cab 4wd
    Good idea. Degrease well and put the time in prep. I like POR 15. It’s lasted longer then all the other stuff. Once hardened then you can spay you perfected juice.
  3. Sep 22, 2022 at 9:11 AM
    gzig5
    gzig5 Well-Known Member
    Mequon, WI
    2002 Tacoma PreRunner 2WD
    That's going to be a royal PITA to properly degrease so that the paint sticks everywhere it should. Seams and corners are going to be really hard to get all the oil out and the paint won't stick. Might be better than no paint but if you are already doing the oil, the paint isn't near as critical IMO.
  4. Sep 22, 2022 at 2:05 PM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    I'd take care of that frame as best as u can.
    We see more frame failures here than engine....
