Frame Question Re: Offroad
Discussion in 'Off-Roading & Trails' started by jspadaro, Jul 11, 2011.
  1. Jul 11, 2011 at 2:43 PM
    jspadaro
    jspadaro [OP] Well-Known Member
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    If I got a little air on a rough section of trail in my truck and needed an alignment afterwards, I probably still didn't do enough to bend my frame, right? And if I had, I'd know? (Drives fine post-alignment). I was going maybe 20mph.
  2. Jul 11, 2011 at 3:49 PM
    Joels98taco
    Joels98taco Well-Known Member
    joel
    chino hills
    98 5 lug tacoma
    fabtech 3" spindles, icon aal, 10" bilstein 7100 rear shocks, daystar coil spacers, AFE Pro Dry-s drop in filter, sony head unit, 2 12" pioneer subs, pioneer 6.5s all around, custom 1.25 lift shackles, custom lower ball joint brackets fabbed by me
    i think you should be fine man. its a tacoma it can handle it :D
  3. Jul 11, 2011 at 4:05 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    33's,armor,crawler,dents, ect
    OME lift CBI sliders, front bumper homemade rear bumper 33x12.50 m/t Gears Aussie locker inchworm crawlbox Homemade flat belly
    Does the frame look bent? Was it a very hard landing?
  4. Jul 11, 2011 at 5:32 PM
    Mxpatriot
    Mxpatriot Well-Known Member
    Chase
    North Pole, Alaska
    '06 4x4 AP LT and Locked
    Money pit.
    You're more likely to bend upper control arm mounts, lower control arm mounts, spindles, or break a motor mount up front then you are to bend the frame. The rear is a different story...you'll know it's bent when your cab no longer aligns with your bed.
    Having bent spindles, LCA's, and broken a motor mount; my advice is if ain't broke don't fix it. Lift the front end off the ground and check for excessive play and visible damage. If you see nothing wrong and it drives fine then you're good to go.
  5. Jul 11, 2011 at 6:57 PM
    jspadaro
    Jim
    Knoxville, TN
    Former Tacoma Owner
    Blue Oval Mod
    Thanks! :thumbsup:
    I did already check, didn't notice anything wrong. The thread about Raptors just got me thinking... although those guys went 125mph!
  6. Jul 11, 2011 at 7:45 PM
    Mxpatriot
    Chase
    North Pole, Alaska
    Money pit.
    I've bent shot at 2 MPH and at 50 MPH. If you push it, it will break - that is the definition of pushing it.
    The raptor guys are delusional and think their 6000 pound full size, mid travel trucks are trophy trucks. That's why they break shit.
  7. Jul 12, 2011 at 1:35 PM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    just check all your bolts on all suspension parts.
  8. Jul 14, 2011 at 3:40 PM
    NakedTacoma
    NakedTacoma Well-Known Member
    West Covina
    Mid travel front Long travel rear
    not true !! i bent my rack and tie rods and bent my frame ....... LCA UCA were perfect lol
