Frame recall - Canada
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kel Varnsen, Aug 9, 2014.
  1. Aug 22, 2014 at 6:42 AM
    #41
    Stuligan
    Stuligan Well-Known Member
    Ontario, Canada
    05 TRD OR 4L V6 6spd
    Billy 5100 level lift (0.85" front) White/Amber DRL/Signal Kit GTA Car kit for AUX/IPod Satoshi Grill 2x 20" LED Light bars behind grill HID headlights LED Taillgihts LED interior lights.
    You make a valid point, I had not thought of that. This recall is likely the only time the truck will ever be in a shop, I do most of the work on it myself. I am still cautious to sub-contracting out, I've seen a lot of crap work done by so-called "specialists". I would want to stay in the loop with who they are having do it, which I think is a fair request to make. I am hoping to hear back in the 10 or so days from Toyota Canada about whether or not I will get a frame. As I've stated before the dealer is fully expecting I will, but need the green light from HQ.
    I am seriously curious about if they provide loaners, and what all they replace though/extra costs. I haven't been able to find all that in other threads, but I will admit that I don't spend a lot of time looking. Only breifly on quick breaks or my lunch while I work.
  2. Aug 25, 2014 at 12:48 PM
    #42
    T1landry
    T1landry New Member
    Tim
    Halifax, Nova Scotia
    08 TRD, 6spd
    Just got the call for the inspection on my 08' down here in NS. Very accommodating, although the frame looks good I do not expect to have it replaced. Giving me a rental car until the issue is resolved.
  3. Aug 25, 2014 at 12:59 PM
    #43
    TYetti
    TYetti 4cylinders of awesomeness
    Mat
    Abbotsford, BC, Canada
    09 Tacoma AC 2.7L 5spd 4x4
    A friend of mine has an 07 he just got it back from the dealer they did the undercoat on his, wow that shut is super thick, and they sprayed the hell out of it smells bad too lol probably just flashing off as I cures, seems similar to a por-15 or cold tar coating I'm tempted to pay to have my 09 done
  4. Aug 27, 2014 at 7:51 AM
    #44
    Stuligan
    Ontario, Canada
    Toyota just did the check last night to make sure the truck was in my name before I had it inspected and that it was on the road as well. They said that was pretty much the last bit of paperwork before they got the go ahead to put a frame on order and they now fully expect it to happen. Apparently the dealer in Brantford, Ont has 2 or 3 frames already on order for other people and they are backordered quite a bit. But it should happen sometime in the next couple months that I'll get a new frame.
  5. Aug 27, 2014 at 2:34 PM
    #45
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    And people wonder why the Tacoma hasn't been updated. Their budget for a new Tacoma is getting eaten up by all these frame problems both US and Canada. I think they got some money back from the frame manufacturer, but as we all know the lawyers take about 35% of any successful lawsuit so Toyota is paying out a lot of money for these frame issues with the Tacoma and the Tundra.
    I've seen pictures of semi loads of frames being shipped to dealers in the rust belt. That's a lot of money to buy and like said above 45 hours of work to install. Even the CRC is an 8 hour job if done correctly. An eight hour job costs the dealer about $800 when you factor in all the costs. Multiply that by a million trucks if you include both Tundra and Tacoma. All the administrative costs to handle claims, it was a massive f-up.
    In the arid west we don't see those problems, the dry air sucks the moisture out of everything including sandwich frames. I saw a 2005 Tundra for sale on a Toyota dealer lot in PA and that frame was rotted so bad I was surprised they had the balls to put it on the lot. Somebody had black painted over the frame rot in the visible areas like the rear wheel wells. Beautiful low-mileage truck on the outside and interior, look underneath and it looked worse than a 1924 Ford tractor abandoned in a field.
  6. Aug 27, 2014 at 6:12 PM
    #46
    cheeseit
    cheeseit Well-Known Member
    Vancouver B.C.
    2005 SR5/TRD OR Tacoma
    3 inch toytec lift
    So I took my truck in a few days ago. They did the spiral cable/Access cab seat belt recalls but they would not do the frame coating. I did get them to inspect the frame and all they found was "very minor surface rust".
    The reason they would not cover it was because the factory where the truck was built may have not had the same issue as where the other ones were built. This sounds like complete BS though so I'll just wait until my truck is under the recall.
  7. Aug 27, 2014 at 6:32 PM
    #47
    asuchemist
    asuchemist My Hamstrings Hurt!
    South South Dirty Gilbert
    11' TRD Sport V6, 23' TRD Pro 4Runner, 23' Tacoma TRD Pro
    NONE
    They probably don't have a qualified person at that location.
  8. Aug 27, 2014 at 9:20 PM
    #48
    ImplicitlyAlberta
    ImplicitlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
    Where is the dealer gonna spray?
    They don't have the resources.
    I worked at Custom Truck Parts for a bit and they had contracts with all sorts of dealerships for bedlining and tinting which CTP would also outsource. This explains why going through the dealer is Sooo much more expensive.
  9. Aug 27, 2014 at 9:51 PM
    #49
    Rosscopeeko
    Rosscopeeko Well-Known Member
    BC
    08 DC LB 4x4 sport
    My truck is going in approximately a month. I'm hoping they do a clean and thorough job. My frame has a lot of surface rust.
  10. Aug 29, 2014 at 8:31 PM
    #50
    iiman65
    iiman65 Member
    Greg
    Morton, PA
    2005 Tacoma Crewcab
    Bilstien 2.5 Lift, Borla Catback, ProComp 7028 wheels with 33" Toyo MT's
    Hey Guys I'm new to this forum and wasn't sure where to post this. My 2005 Tacoma is rotting away and I'm hoping for a recall in PA
    http://youtu.be/-vIfiwZJ-Gg
    Just trying to get the word out.
  11. Aug 30, 2014 at 7:02 PM
    #51
    99coma
    99coma Well-Known Member
    alberta
    2005 tacoma TRD OffRoad
    Has any one in canada had a bad frame replaced yet? im just wondering what all they replace? did toyota offer a buy out at all?
    one guy said pretty much every thing under the truck was replaced in the US IE. frame control arms brake lines leafs ect. mine goes in tuesday to fail :)
  12. Sep 2, 2014 at 4:54 AM
    #52
    davet
    davet Member
    dave
    king city, ontario
    05 indigoink tacoma trd sport DCLB
    Just got it. Stock ..for now
    Can someone tell me how to "quote" someone's post? Lol .... Anyways. That video is really bad. Probably the worst I've seen yet. I took my 2005 in about 1 week ago and it failed. My rust holes near the front cats were about the size of a marble. Nothing like that. I can fit my foot through yours haha. But anyway good luck with the recall out your ways. Waiting on a call from Toyota when my new fram comes in!!
  13. Sep 2, 2014 at 7:14 AM
    #53
    tammikm
    tammikm Well-Known Member
    canada
    06 DC 4x4 SR5 AUTO
    n/a
    took my 06 in a few weeks ago, said frame was solid, applied the crc coating, looks like new lol are any of you applying rust block or oil under coating on top of this as well, this black stuff they put on gets hard as rock after a few days....
  14. Sep 2, 2014 at 7:29 AM
    #54
    cleung
    cleung Well-Known Member
    Saskatchewan Canada
    07 TRD offroad DCSB
    Bilstein 5100, 265/75/16 tires, Extang solid fold
    Anyone out there with an imported Tacoma have any luck with getting this campaign? I have a 07 that was imported to Sask back in 08 from Arizona, I've contacted toyota Canada and have not heard anything back yet.
  15. Sep 2, 2014 at 8:47 PM
    #55
    99coma
    alberta
    Took my tacoma in today, and told them if you pass the frame do NOT do the under coating because i know it is bad and will fail so ill be taking it to a government shop. the guy was really good about it all and said they do offer a buy back Buuuut if the pay out is over some where around 18000 then they will just replace the frame, good in my case since i only paid 10,000 for my truck :) also he said if a frame does pass and they do the under coating then the frame will be warranted for another 10 years. that shocked me so if any one else is told that for there truck get it in writing!
    should know more tomorrow and will post then!
  16. Sep 3, 2014 at 5:57 AM
    #56
    Stuligan
    Ontario, Canada
    What I was told by toyota was that they cancelled the buy back program a while ago. My truck would be worth more than $18000 to them regardless because they buy back at 1.5x the market value.
    I'm frame number 4 on order at Toyota in Brantford, at least that's what I'm told. They've done several undercoatings though. It's up in the air when I will get the frame though, apparently they are on serious back order.
  17. Sep 3, 2014 at 5:57 AM
    #57
    Stuligan
    Ontario, Canada
    It's the little quote button in the bottom right corner of the persons post.
  18. Sep 3, 2014 at 4:38 PM
    #58
    99coma
    alberta
    Just got the call from my dealer. they said the frame is bad and they just sent pics and info to toyota canada to see how they want to proceed. so now just have to wait to hear from toyota canada
  19. Sep 4, 2014 at 4:43 AM
    #59
    davet
    davet Member
    dave
    king city, ontario
    Heyyyy it work. Thank you !!
  20. Sep 4, 2014 at 4:54 AM
    #60
    davet
    davet Member
    dave
    king city, ontario
    My frame failed about 2 weeks ago. Toyota said that it should only take about a week for the frame to come in, obviously not lol. The person at Toyota keeps telling me "it should be a few days". So I'm playing the hurry up and wait game. They also said there are 6 frames being ordered so mine is not the only one. THE GOOD THING, is apparently I'm the first one on the list ! .... Hopefully. This is the Toyota at st Clair and Jane area in Toronto. I just want this frame so I can put a lift on !! Haha. It's like waiting for Christmas is September. I'll keep you guys posted like I have been. If I'm able to take pics of the frame swap I'll post them in this thread.
