Frame recall tow bar/bumper issues?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by deerslayer75, Jan 31, 2021.
  1. Jan 31, 2021 at 4:29 AM
    deerslayer75
    deerslayer75 [OP] Well-Known Member
    Tim
    jersey shore
    11 TRD sport Dblcab Lngbed
    pop-n-lock, mcgard tailgate lock, chrome tube steps, bed extender, chrome brush guard, Fold a cover (G-4) tonneau, weather tech floor mats and rain gaurds, sock monkey: TRD 3rd brake light and whitetail decals, LED bed lights, blue map & dome, 3rd brake light and license plate LED mod, illuminated 4x4 switch, fishing rod holder mod, scangauge II, Remote start & alarm, TW sticker, Flyzeye cupholder light mod
    I had my frame replaced as per the recall and less than a year later my bumper is not straight. After inspection it appears the bolts or mount are so rusted that it broke free and is toggling back and forth. If it was a rust issue you think it would’ve been included in the recall. Has anyone else had this problem and if so what did you do to fix it?
  2. Jan 31, 2021 at 7:39 AM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    My receiver bar is pretty rusty with flaking rust and will have to be replaced shortly. I've started to look at replacement bumpers/receivers. Toyota could have chosen a better metal composition for their frames, rear bumpers, and receiver hitches.
  3. Jan 31, 2021 at 7:51 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    It's not the alloy, but the finishing process. A poor finish allows almost anything to corrode.
  4. Jan 31, 2021 at 8:07 AM
    dtaco10
    Dave
    A little more nickel or chromium in the metal composition would have slowed the corrosion process. It didn't have to be so much it made it into stainless, but it would have slowed the corrosion. Better to recycle than let it rust away along the roads and have nothing left. Rust isn't recyclable.
  5. Jan 31, 2021 at 8:21 AM
    Too Stroked
    Tom
    Not going to disagree with you there, but the steel used in truck frames is pretty standard - and relatively inexpensive. A few bucks invested in a better finishing process would do wonders for salt spray numbers. Look at (almost) everyone else in the truck business. Nobody with wild alloys in their frames and most other folks (except maybe Jeep) don't have significant corrosion issues. Just better finishes. I spent way too many years in the metal finishing business so I can speak with some authority here.
    eherlihy likes this.
  6. Jan 31, 2021 at 10:01 AM
    taco_rhyno
    taco_rhyno Well-Known Member
    06 DC 4x4 Sport
    Glad you got a new frame. The frame replacement was a warranty enhancement (not a recall) program that was agreed to as a lawsuit settlement. Unfortunately, The settlement doesn’t cover your problem.
    if you have a factory tow package (like mine) then your hitch is part of your bumper mounting. My truck’s hitch assembly was just as bad as the frame so I put an aftermarket bumper on mine.
    Muddinfun likes this.
  7. Jan 31, 2021 at 5:06 PM
    dtaco10
    Dave
    The frames should be prepped and finished as unibody cars and SUVs are.
  8. Jan 31, 2021 at 5:52 PM
    Too Stroked
    Tom
    Bodies normally use Zinc clad steel. Frames do not.
