Frame Recall
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BestOpaEver, Jan 31, 2015.
  1. Jan 31, 2015 at 8:26 PM
    BestOpaEver
    BestOpaEver [OP] New Member
    05prerunner
    Toyota is replacing the frame on my 05 prerunner. The dealer is encouraging me to get new shocks and struts (even aftermarket) saying that they have to remove and reinstall them as part of the frame replacement, so I get free labor - what an opportunity. First of all, anyone have recommendations on what to replace? I only have 71k miles and plan to keep it another 5+ years. Control arm bushings? Secondly, I know there are some parts such as wiring harnesses that the dealer in going to replace because reusing is too time consuming or risky. Are there any parts that I should NOT buy beforehand because the dealer is sure to replace anyway? Thanks for your help.
  2. Jan 31, 2015 at 8:34 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    The shocks might be a good idea. Other than that, don't spend a nickel more than you have to, imo.
  3. Feb 3, 2015 at 10:27 PM
    texvet61
    texvet61 Well-Known Member
    Ocala, FL
    09 Tacoma TRD Sport
    Lighting: Phillips LED headlights, BD's S2pro fog lights, LP4 pro and LP9Pro Racing LED's, Black OaK IR cubes. COMMS: Cobra WSX75 CB, Icom 7000 Ham Radio, antenna; Alpha MotoSS HF 80m-40m, CA-2x4SR tri-band 2m/70cm/ - AUDIO: ALPINE ILX-W650, KTA-450 Amp, S-A60M 300Wt mono amp, F/R door speakers, JL Audio C2-650X, JLAudio Micor 8" sub. C4 Fab Hybrid Bumper, Warn VF12000S, Locking Rear seat Gun Vault. Locking Console Gun Vault, FPV winch Camera,
    How can you find out if your truck is part of frame recall
  4. May 23, 2015 at 4:11 PM
    TimsTaco
    TimsTaco Well-Known Member
    Tim
    Moncton, NB
    07 DCLB SR5 Sandstone Metallic
    OEM Fog lights, headache rack, work lights, Tailgate Theft Deterrent (hose clamp), Tailgate Reinforcement, Roll'n'Lock tonneau cover, OEM Inverter
    I went to the dealership to find out if mine was involved in the recall today, and it is :(
  5. May 23, 2015 at 4:18 PM
    Croth51
    Croth51 Croth Metal Works
    Christian
    Rancho Cucamonga Ca
    Tacoma Dbl Cab
    16 Method NV,33 Bfg AT KO2, 14 in Fox shocks hydraulic bumps swayaway coilovers 50 in LED Lightbar A pillar Ditch lights ,Custom Skidplate,4 Hella Hid lights,Custom grille,7 in Pioneer touch screen Head unit, 12 in CT sounds Meso CT 1400.1 amp, kicker doorspeaker, 500 watt doorspeaker amp, white LED rocklights, LED pod Dustlight,
    #2ndgenprobs
