Frame repair in Bowling Green, KY?
Discussion in 'Kentucky' started by Zach G, Jun 6, 2019.
  1. Jun 6, 2019 at 7:25 PM
    Zach G
    Zach G [OP] New Member
    Allie
    Tacoma
    Does anyone know who can perform some of frame repair for a 2004 Tacoma in Bowling Green KY?
    GQ7227 likes this.
  2. Jun 6, 2019 at 7:29 PM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    No option for replacement by Toyota?
  3. Jun 6, 2019 at 7:41 PM
    Zach G
    Allie
    Tacoma
    Nope, they are telling us that the warranty that is still in affect because of the class action law suite is void because several owners back, (can't tell us who or when) did not have the underneath sprayed. So we are screwed.... I see several videos on here where people were able to repair the frame rather than replace..
    GQ7227 likes this.
  4. Jun 6, 2019 at 7:47 PM
    Seagull233
    Tom
    Upstate New York
    2004 DC 4x4 V6
    This company makes weld in replacement pieces. https://www.autorust.com/ Then you need someone to cut out the bad, and weld in the new.
    Sorry for your bad luck from the PO. Toyota isn't really unwilling to replace, if within the timeframe, and the prior treatment was made. But definite no-go without the treatment.
    GQ7227 likes this.
  5. Jun 6, 2019 at 7:49 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Should probably try asking in the regional treads. Probably find someone more local
    GQ7227 likes this.
  6. Jun 6, 2019 at 8:01 PM
    mwrohde
    mwrohde Well-Known Member
    Sugar Hill, GA
    2003 Tacoma 4x4 5-speed 3.4 TRD SR5
    What he means is go to the top of the page where you see "Home ... Forums...Watched......" and click "Forums". About halfway accoss, you'll see "Reginal Discussion". Find your region and ask this same question. Someone close to you may be able to help.
    Sperrunner[QUOTED] likes this.
  7. Jun 6, 2019 at 9:04 PM
    jenk
    jenk Well-Known Member
    Jen
    Central Coast of CA
    2001 Black Tacoma TRD Prerunner
    I'm having to do frame repair as well. I'm going to get the frame reinforcement pieces from above mentioned website, and then do a local yelp search for welder/fabricator. I found this one guy that has great reviews, just gotta see if it's something he can do and for how much $$.
    Other forum might be able to help ya!
  8. Jun 6, 2019 at 9:04 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    You need a frame?
    GQ7227 and T4RFTMFW like this.
  9. Jun 6, 2019 at 9:10 PM
    jenk
    Jen
    Central Coast of CA
    I do but I wouldn't know anyone to help swap, plus the $$ factor.
    GQ7227 likes this.
  10. Jun 6, 2019 at 9:16 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Oh, i have a 96 v6 6lug frame for free
    GQ7227 likes this.
  11. Jun 6, 2019 at 9:24 PM
    jenk
    Jen
    Central Coast of CA
    Thank you for the offer, that's very generous of you! I'll have to pass though.
  12. Jun 6, 2019 at 9:24 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i still need to borescope inside of my frame once I get it powerwashed out, hopefully its 0k in there, I can only feel some sand and dirt sticking pinky finger in various slots/openings
    gotta figure out how to get the bed off first without paying out many 100s of dollars!!
    gotta cut costs...
  13. Jun 7, 2019 at 12:07 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Finding someone that will do this type of work can be hard and expensive.
    Most places need to remove the fuel tank for insurance reasons which adds new parts that break and need replaced .
    Then you never know what your going to find till you get started .
    People I know just quoted @ $2500.00 to do frame repair
  14. Jun 7, 2019 at 5:37 AM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    How bad is the frame? Can you show some pictures?
    I am in Evansville and have done repairs on several 1st gens. But, I'd like to see how bad it is before offering any help.
    GQ7227 likes this.
  15. Jun 7, 2019 at 8:55 AM
    Sogoku19
    Sogoku19 Well-Known Member
    03 Tacoma (black)
    I’m from Clarksville, TN, not too far from you. We have a frame shop here in town that has a good reputation. I haven’t had any work done from them just yet but they have photos on their website of them reinforcing frames and stuff and the site states that they specialize in framework and suspension. The name of the company is Tennessee Frame on kraft st in Clarksville. Best of luck.
  16. Jun 7, 2019 at 9:29 AM
    tacomainthesun
    tacomainthesun Well-Known Member
    02(sold) 17 trd or
    I took the bed off mine here recently. There are 6 bolts connecting the bed to the frame. 4 of them are 17mm and 2 are 19mm. You should need a deep well socket for the 19mm ones. Start by removing the tail lights and feed the wiring down past the bed. Do this for both then get under the bed. Cut the electrical tape that holds up the wiring until all of it dangles down to the ground. No need to remove any not connected to the bed. Remove the gas cap and fuel neck. Mount an electric hoist above the bed in your garage (I used one from harbor freight) Now you can remove the 6 bolts. This is the hardest part as mine were very rusty. Use penetrant oil as needed wd40 pb blaster etc. once removed set aside and now you need to attach ratchet straps to the rings in the bed tighten those bad bois up and hook to the hoist hook. Leave your mud flaps and wheel well plastic on. This is a two man job now. You need to have someone pull back the wheel well plastic in order to make sure it doesn’t clip the gas nozzle. They will guide the bed around as someone operates the hoist. Once the bed is raised put the gas cap back on and drive it out from under. Park truck. Get 4 old buckets and some wood planks. Place these in a square. Lower each corner of the bed unto the buckets. It’s now time to get to work. Remove any loose debris with a wire brush. Now you can drive the chassis cab to the weld man. Costed about 200 for the frame reinforcements. Better than 3000+. Drive the chassis cab back after picking it up and begin rust treatment. I used rustoleum rust neutralizer gray bottle looks like clear jelly when sprayed. Make sure it’s spread in. Use toothbrushes in smaller places and a medium size paintbrush otherwise. This needs to dry overnight. Now spray rustoleum rust preventative. Spray paint can black, works just like regular spray paint. I recommend this is done outside rather than the garage. This dries quickly do 2 coats. 2 cans of this was enough for me. Now you can put the bed back on and fasten it. Then to the fuel neck and lastly the tail lights and wiring. Use electrical tape to tie the wires back on to the same plastic mounts. Test to see if the tail lights and tag lights work. That’s it!:amen:
  17. Jun 7, 2019 at 9:31 AM
    tacomainthesun
    02(sold) 17 trd or
    F1EEF8EC-6ECD-449B-9341-6CC43E8B3E99.jpg My Trok before rust treatment and welds
    cruiserguy, GQ7227 and jenk like this.
  18. Jun 7, 2019 at 1:40 PM
    jenk
    Jen
    Central Coast of CA
    oooh! thank you for the info!!!
  19. Jun 7, 2019 at 1:47 PM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    Take it to the Corvette plant?
  20. Jun 7, 2019 at 1:55 PM
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    Wulf and GQ7227 like this.
