Frame Repair
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kurt Franz, Oct 18, 2022.
  1. Oct 18, 2022 at 8:59 AM
    Kurt Franz
    Kurt Franz [OP] Member
    2007 Regular Cab Prerunner
    Standard Cab Prerunner - looking to find something similar to this that will work. Can't find anything for the Gen2 Standard Cab models
    SafeTCap® Frame repair kit to repair the front frame on the 2nd Gen Tacoma Access cab and Double cab models.
    Any insight appreciated
    KF
  2. Oct 18, 2022 at 8:58 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    2015 Toyota Sienna with rear locker
    burrito782 likes this.
  3. Oct 18, 2022 at 9:09 PM
    burrito782
    burrito782 Shit Throwing Ape
    08 TRD Off Road
    I was thinking the same thing as well, probably not offered as regular cabs are relatively uncommon (i.e. not enough demand to justify).
  4. Oct 19, 2022 at 8:47 AM
    Kurt Franz
    For anyone interested I emailed Safe-T-Cap:
    I have a 2007 standard cab Tacoma Prerunner. Will I be able to purchase part number TAC-230X/D-L and cut the length accordingly to fit my standard cab? It appears that the front section is the same on all tacoma trucks and the only difference would be the length heading towards the rear. My truck is in great shape except for the bad area of the frame.
    Thanks
    The RESPONSE:
    Hi,
    The 230X/D-L will not need to be cut. If you were to need the 231 you would cut that piece to make it work, it is a straight cut easy peasy. If you end up needing the 232, 233 or 234 you just need to purchase the X version of those parts.
    Please indicate if the truck is a Automatic of Manual transmission when ordering the 230.
    Regards,
    steelhd and Too Stroked like this.
