Frame replaced, diff breathers missing?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by thegrudge101, Aug 24, 2019.
  1. Aug 24, 2019 at 12:42 PM
    thegrudge101
    thegrudge101 [OP] Member
    Tucson, AZ
    2008 Tacoma 4.0 V6 TRD 4x4 Off-Road Access Cab
    None
    Hi everyone,
    I've been driving my 08 since 09 and I never really noticed this until today, but I do know there used to be cables in those little clasps. Any help is much appreciated. Thanks
  2. Aug 24, 2019 at 1:01 PM
    Muddinfun
    Muddinfun Well-Known Member
    That big box on the right side of the pic is the fuse box.
    That plastic clip holds the front axle vent hoses. Look around, find the hoses and make sure they're attached to the front diff and the actuator.
    What ever happened with your head gasket leak?
  3. Aug 24, 2019 at 1:11 PM
    thegrudge101
    Tucson, AZ
    None
    Oh shoot, I am an idiot - your right the fuse box is right there lol. Duuhhh. But I still wonder what happened to the old cables? I have a very old photo of them (it's bad quality) but it looked like they may have had silver caps on them?
    The best shop in Tucson said they no longer do head gaskets. So far I havent had any real issues. Had my water pump and thermostat changed, and they didn't notice any of the gunk that can get clogged up in there from doing the HG liquid repair stuff
    Muddinfun likes this.
  4. Aug 24, 2019 at 1:15 PM
    Muddinfun
    Yep, those silver caps are the vents at the end of the vent hoses. Start at the axle and follow the hoses.
    303tacoma likes this.
  5. Aug 24, 2019 at 1:16 PM
    thegrudge101
    Tucson, AZ
    None
    Found the photo. Looks like these cables used to be in the empty clasps?
  6. Aug 24, 2019 at 1:17 PM
    303tacoma
    303tacoma Bad Karma is a Bitch
    Rebecca
    Sw Denver Concrete Jungle
    2008 TRD AC 4th gen Rav4 Platinum
    ICONS Front & extended Rears DAKARS LR UCAS Wheelers Super Bumps F/R Homersoshi & Bumper insert, Ultra Gauge, Wet Okole seat covers, AFE air filter, Truxedo tonneau cover, LED White Cluster swap by yosh2000, Audio upgrade, ECGS Bushing, rcbs204 Lighted 4x4switch, Bullaculla trailer harness relocate bracket SOS Concepts IFS skid & sliders Anti- Dark RedLine Hood Struts Matt Gecko Bed Lights BHLM Depo Tailights Fog light anytime mod ABS cancel mod Rear diff breather mod Brake light 35watt mod Relentless u bolt flip Mobtown Recovery Bar Sound deadener doors rear wall
    Vent hoses for front dif transfer case?
  7. Aug 24, 2019 at 1:17 PM
    thegrudge101
    Tucson, AZ
    None
    Ah, ok thanks. When my truck came back from my frame replacement, these cables are no longer in the clasps. I'll go look for them now. Thanks!
    303tacoma and Muddinfun like this.
  8. Aug 24, 2019 at 1:55 PM
    thegrudge101
    Tucson, AZ
    None
    Update: I cannot find these for the life of me. Do you think it's possible when Toyota changed the frame they forgot to replace the breathers? This is all is see, and ive tried looking online to find where to trace these to, but only rear diff stuff pops up. Thanks
  9. Aug 24, 2019 at 2:09 PM
    azzwethinkweiz
    azzwethinkweiz Well-Known Member
    Tucson, AZ
    2013 4x4 DCSB V6 6-Spd, TRD OR, Tow Package
    I don't know if you would be able to see it easily but somewhere on top of the diff should be a hose coming out of it... they might've just tied it up to something else instead of putting it in the clamp.
    BTW, if you need another shop to work on your truck, Canyon View Automotive which is located just south of Rita Ranch is a really good shop. They aren't the cheapest but they do quality work.
    thegrudge101[OP] likes this.
  10. Aug 24, 2019 at 2:20 PM
    thegrudge101
    Tucson, AZ
    None
    Yeah it seems to me to be kind of hard to get up in there and look. It's kind of crowded and not a very good angle. The search continues lol
  11. Aug 24, 2019 at 2:27 PM
    thegrudge101
    Tucson, AZ
    None
    Problem solved It's exactly as you said they tucked them away somewhere and just didn't pull them back up into the clasps. Thank you everyone for helping a newbie out!
    303tacoma, 05Taco4x4 and Muddinfun like this.
  12. Aug 24, 2019 at 2:35 PM
    Muddinfun
    Good job. Now follow the hoses down to the other end and make sure they're attached at the diff. The small hose is just a slip fit over a metal tube on the actuator. If either are disconnected, you will get water into the diff or actuator.
