Frame Replacement 2003 Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by Greg 4X4, Nov 13, 2016.
  1. Nov 13, 2016 at 5:54 AM
    Greg 4X4
    Greg 4X4 [OP] New Member
    Greg
    2003 Tacoma extended cab 4X4
    What should I examine/consider changing when my frame is replaced. My truck has 240,000 kilometers/158,000 miles. Body is in good shape.
  2. Nov 13, 2016 at 6:17 AM
    taczilla
    taczilla I intend to live forever; so far.... so good!
    Marc
    PEC, Ontario, Canada
    2016 RAM Rebel
    2012 TRD Sport - STOLEN! / 2016 RAM Rebel
    This thread.
  3. Nov 13, 2016 at 8:31 AM
    Greg 4X4
    Greg
    Thanks for the great help. Good build though.
  4. Nov 13, 2016 at 2:51 PM
    twp
    twp Well-Known Member
    Ky
    2002 trd
    I was wanting to know the same thing. Mine goes in soon for the replacement.
  5. Nov 13, 2016 at 2:53 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    I've read that some dealerships will gladly do other needed work or even install mods (i.e. new suspension) for you while the truck is apart getting a new frame (so long as you provide the parts, of course) and other dealerships where they won't touch anything other than what they have to. Depends on your dealership.
    If you do need new suspension, now would be a good time to try and get it done
  6. Nov 13, 2016 at 7:58 PM
    ghs57
    ghs57 Well-Known Member
    Chops
    Catskill Mts. NY
    '17 Grey TRD OR xtracab 3.5L 4WD
    Pretty much stock right now
  7. Nov 13, 2016 at 8:10 PM
    ghs57
    Chops
    Catskill Mts. NY
    Assume you are approved for new frame?
    Just for reference, your '03 was undercoated by Toyota before the deadline and has subsequently failed a frame inspection? I'm in another tread currently were a member says Toyota told him it was either that the frame was replaced upon inspection or the undercoating was applied, but not both. That scenario does not jive with my experience/research on this issue, nor with the terms in the warranty notice from Toyota.
  8. Nov 13, 2016 at 8:41 PM
    eon_blue
    Azusa, CA
    The way the replacement program worked was if Toyota inspected and coated your frame, then you would qualify for a new frame on their dime later on down the road if your frame ended up rusting out despite the undercoating. The warranty was good for 15 years from the build date of the vehicle.
  9. Nov 13, 2016 at 8:44 PM
    eon_blue
    Azusa, CA
    The deadline for first gens to get inspected and undercoated was awhile ago (few years?) though if I'm not mistaken, so it's too late to get the warranty if you hadn't before then.
  10. Nov 15, 2016 at 12:00 AM
    ghs57
    Chops
    Catskill Mts. NY
    Agreed.
    Not sure why the guy is getting the run around, unless some details have been left out. There are many accounts here of dealers not honoring the warranty, then corporate overriding that decision and authorizing the replacement.
    I follow most frame threads, having been through a replacement on my '01, and I am counting on the warranty on my '03 right up to the day it expires.
  11. Nov 15, 2016 at 8:20 AM
    Greg 4X4
    Greg
    The dealer has been great. Getting pricing for rear shocks, front struts and front skid plate. Thanks for the info.
  12. Nov 15, 2016 at 10:29 PM
    carofchoice
    carofchoice Well-Known Member
    Jeff
    Newton, IL
    2003 DC 4X4 TRD, 2012 X-Runner
    I follow these types of threads also, just went through the frame swap a little over a month ago. The dealer I took mine to wouldnt do any aftermarket parts but I did add some OEM parts to the list. The dealer was a POS to deal with though, told me one thing and denied it later type shit. Last time I ever take a vehicle to them, will drive the extra half hour to the next dealer.
    I chime in on some of these threads but seems like you and a couple others straighten out the bad info some throw around.
