Frame replacement at 38,500miles // 62,000km; anything to consider?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tirediron, Jan 19, 2022.
  1. Jan 19, 2022 at 5:30 PM
    tirediron
    tirediron [OP] Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Got rear-ended a few weeks ago, and the insurance company is putting a brand-new frame under my third gen :eek: !!!!! Just wondering what, if anything I should think about having replaced/changed while her skirts are off. The truck is 98% street/road driven and (IMO, at least) well maintained.
    The only thing that came to mind was the coolant cross-over pipe, but if it's not leaking (it's not at the moment), I'm loathe to mess with it.
    Thoughts?
  2. Jan 20, 2022 at 4:37 AM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    Toyota certainly knows how to replace frames. . I would get the new frame coated with rust protection. Every sq inch. Most people I find have to do it afterwards and it’s a pain crawling around under doing it yourself.
    xndak, mistareeman, tacoman45 and 6 others like this.
  3. Jan 20, 2022 at 4:53 AM
    Ktm350JH
    Ktm350JH Well-Known Member
    Any idea on the cost of the replacement frame?
    tirediron[OP] likes this.
  4. Jan 20, 2022 at 4:59 AM
    Red Alert
    Red Alert Well-Known Member
    CT
    2020 Tacoma SX 3.5 4x4 BRM AC
    ^^What Greg said. As long as it's apart it would be a wise investment to have everything Cosmolined.
    AFAIK there's no new improved coolant cross-over pipe so no sense fixing what isn't broken.
  5. Jan 20, 2022 at 5:47 AM
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    wouldn't replacing a frame encompass a complete totaled vehicle?, surprised they are doing that?
  6. Jan 20, 2022 at 6:19 AM
    Greg-tacoma
    Greg
    2016 Black 4cyl 4wd
    Toyota replaces frames all the time. Plus. To be totaled the repair cost would be more than the ok value of that vehicle. That’s why when they total something you only get the book value
    shakerhood and tirediron[OP] like this.
  7. Jan 20, 2022 at 6:53 AM
    tirediron
    Thanks! I hadn't thought of that, but I'll discuss it with the body shop. Given where I live (Vancouver Island), salt/corrosion is not a consideration. I FF the truck every year 'just in case', but this is definitely an option!
    The frame itself is just shy of $10K, and 31 hours labour for the R&R, so roughly $14K.
    I was thinking about swapping out with the Lexus one, but I really don't know if the failure-rate for the OE version is such that it's worth it.
    Typically, but according to the bodyshop, the repair bill for my truck sits at around $28K, the insurance company would have gone to almost $38K before writing off!!! :eek:
    Yep. if they totalled it, I would likely be looking at >$15K out of pocket to replace with new.
    Skydvrr, zoo truck, Junkhead and 2 others like this.
  8. Jan 20, 2022 at 7:50 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    As far as that crossover coolant pipe i through toyota had installed an improved plastic version from the earlier gen3 trucks.
  9. Jan 20, 2022 at 7:54 AM
    zoo truck
    None
    Basically about same cost as the dealer told me back in 2020 when i questioned them about frame issues. It was $12k on their gen2 tacoma frame replacements.
    tirediron[QUOTED][OP] likes this.
  10. Jan 20, 2022 at 7:58 AM
    MadRussian
    MadRussian Well-Known Member
    Metrowest MA
    2010 TRD OR AC
    See if you can get the new frame better painted/coated while its still naked. That will give you much better rust protection then factory.
    Also, since you will have a different frame if the Tacoma frame 'recall' extends to your year your truck might not be covered any more.
  11. Jan 20, 2022 at 8:46 AM
    Mad German
    Mad German Well-Known Member
    2016 TRD Off Road
    Hope it all goes well for you. As stated, Toyota certainly knows how to/all about replacing frames! :D:D:D
  12. Jan 20, 2022 at 9:07 AM
    Vmax540
    Vmax540 Well-Known Member
    Chuck
    Clarion PA.
    2019 TRD Sport 4X4 Access Cab Blue
    Are frame straitening machines a thing of the past ?
  13. Jan 20, 2022 at 10:07 AM
    Ktm350JH
    I take it that was 14k Canadian right?
    tirediron[OP] and vicali like this.
  14. Jan 20, 2022 at 10:14 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    More advanced frames have crumple points to take energy out of accidents. It is hard to repair these frames to provide the same accident protection again. Insurance will replace a frame. Rebuilders will pull it straight and sell it.
  15. Jan 20, 2022 at 1:59 PM
    tirediron
    I thought so, but haven't found a definitive answer. If anyone knows for sure...
    Right in line, given inflation & exchange.
    Given where I live, not really an issue, but worth noting! Thanks.
    My thought exactly!
    Nope, this bodyshop has a very high-end frame table, but the frame is tweaked into a parallelogram. Going over speedbumps is... interesting!
    Oui!
    Good point!
  16. Jan 20, 2022 at 2:20 PM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    My bill covered by Toyota Canada for my 2005 was $14k..
  17. Jan 21, 2022 at 10:59 AM
    Alamo72
    Alamo72 Well-Known Member
    2020 Tacoma SW TRD OR DCSB Tech & Prem+LED
    Mostly Stock
    Sorry-same here. My 2020 with 15k miles got rear ended Tuesday. Collision place is supposed to start a frame replacement in March. They outsource the frame replacement to a place that only does frames and then they finish the cosmetic stuff and new bed. Says it will take 2-3 months, once started. Let me know how things go for you. For myself, I sorta feel like this is the worst outcome, considering the quality of work at most places these days. I’m trying to stay positive though. BFF05057-9502-4B25-9254-1161D701AFD9.jpg
    Kev250R likes this.
  18. Jan 21, 2022 at 11:11 AM
    Jp260z
    Jp260z Well-Known Member
    2017 Tacoma DCSB SR
    If it helps at all, I'd be relieved to know that a frame replacement specialist was swapping it instead of the collision shop. More to go wrong there if the tech is inexperienced....(fortunately?) Toyota frames have been such a problem lately id think any place that specializes in frames would have seen many in their shop.
    The collision shop handling the cosmetics isn't cause for concern as that is normal with every job they do. If they are reputable no problem, should come out looking great.
    I'd recommend, as others have above, going the extra mile on rustproofing while the access is good.
    Kev250R and Alamo72[QUOTED] like this.
  19. Jan 21, 2022 at 11:26 AM
    airforceb2cc
    Don
    KCMO
    Hell, I'd take that insurance check and run! Bob the frame and make a killer crawler outta it!
  20. Jan 26, 2022 at 12:01 PM
    TNZach
    TNZach Member
    Middle, TN
    2018 TRD Offroad
    @tirediron @Alamo72 Do either of you have the work estimate for the cost to do the work and wouldn't mind sharing? I was just rear ended and took my truck to a "preferred partner" shop and I think my estimate is way low for a frame replacement. I'm having a couple of independent estimates done to compare but real examples would be nice. Thanks!
