Frame replacement on lifted or modified trucks
Discussion in '2nd Gen. Tacomas (2005-2015)' started by joshua721, Jan 18, 2016.
  1. Jan 20, 2016 at 10:51 PM
    TacoTaco15
    TacoTaco15 Well-Known Member
    Jake
    VA
    2015 MGM DCSB PreRunner 2.7
    LoL positive contribution to the conversation!
    They do, which is why I'm so confused. This makes no sense, and they're lying to OP by telling him that Toyota requires you to bring the truck back to stock before working on it.
    @OP, the only other thing I can think of is that they are concerned with cutting the crossmember on the new frame when they do the swap?
    Either way, this frame recall ends in March. I would highly recommend trying your luck with another dealer to get it replaced. You rate a brand new frame, no doubt.
  2. Jan 20, 2016 at 11:10 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    I can see them not wanting to cut the new frame. They aren't denying the warranty, they just don't want the responsibility/liability of cutting a new frame.
    I doubt the techs have ever installed a fabtech kit. I sure as hell wouldn't want to hack a new frame up without any experience. Who pays if the job is done wrong? Toyota doesn't sell or install fabtech kits and their techs aren't trained to do them.
    With a normal spring lift there is nothing on the frame to modify so it wouldn't be a liability concern.
    TacoTaco15 likes this.
  3. Jan 20, 2016 at 11:14 PM
    TacoTaco15
    Jake
    VA
    Okay OP, this is making more sense. I think my initial anger at your moronic dealership has faded, and I'm understanding now.
    That kit may actually be a hindrance, given that they likely don't know how to re-install it and, as @Snowman mentioned, they probably don't want to cut the frame.
    I don't think they meant that they don't work on modified trucks - we all know that's not true. However, I think yours has some frame-related mods that are causing them to pull back from it.
    I don't even know what a good answer to this problem is.
    Snowman likes this.
  4. Jan 21, 2016 at 9:08 AM
    joshua721
    joshua721 [OP] Well-Known Member
    16 f150 xlt v6
    The service guy referenced a truck with a work body or stake body that they wouldn't touch aswell.
    And as far as the lift is it's the same style they fit to the ones they up fit and sell so it's not custom or homemade
