Frame Replacement - Rebuilding Frame Jig?
Discussion in '1st Gen. Tacomas (1995-2004)' started by kckrawford, Dec 5, 2013.
  1. Dec 22, 2013 at 12:33 AM
    evrt
    evrt New Member
    Everett
    TX Panhandle
    03 x-cab 4x4
    Thanks I'll look into it, can't hurt.
  2. Jan 8, 2014 at 6:58 AM
    kckrawford
    kckrawford [OP] Well-Known Member
    Casey
    Longview, TX
    01 DC Ltd. TRD 4x4
    Just an update
    FINALLY got my truck back this past Saturday. Didn't get home from work til Tuesday night but had to take it around the block. Have to say that the dealership done an OUTSTANDING job. Everything seems to be bolted up nice and tight. Only thing i found was the wiring in the rear needs to be tidied up a little bit and i had to adjust the shift linkage. When i put the shifter in drive it was in second. Had to bump it towards neutral. 5 min fix and it was good as new.
    They replaced the frame, subframe parts, lower control arms, lots of nuts and bolts. I had them leave the leaf springs and all the suspension stuff alone since it was relatively new and aftermarket.
    Now comes times for the build thread.
    I will post pictures later. Truck is headed to the accessory shop for a spray in bed liner.
