Frame Replacement - What additional cost to expect from the Dealer?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dborrer, Apr 28, 2018.
  1. Apr 27, 2019 at 4:45 PM
    #181
    bobsuruncle
    bobsuruncle PhD in voiding warranties
    Bob
    Fall City, WA
    06 TRD OR DCSB
    ARB bull bumper Warn XD9000 Icon 2.5 EXT Road Armor rear bumper Archive Garage shackle flip FJ/T4R tcase 4.30 gears Dirty5’s T4R rear axle swap w/disc brakes New frame from Toyota under EWP
    I have an aftermarket 3/16 skid that I removed prior, and the front driveshaft had a bad ujoint I wasn't going to pay them to do it. They didn't reinstall it for liability reasons.
  2. Apr 27, 2019 at 4:46 PM
    #182
    Armkb
    Armkb Well-Known Member
    Hudson Valley, New York
    09 TRD Sport DCLB
    Bilstein 5100, OME 885X, LR UCA, ARB/EL095R, ES LCA Rack & Sway Bar Bushings, Yellow Wire Mod, ABS Switch, TPMS Mod, Scanguage, Toyota Bed Mat, WeatherTech Floor Liners, Extang Trifecta Cover, Fumoto Drain Valve
    My bad!
  3. Jun 29, 2019 at 8:50 PM
    #183
    brendenlow
    brendenlow Active Member
    Piggybacking of this thread as I dropped mine for a frame replacement this week. While there for inspection they identified that my steering rack is leaking from the seals and needs replacement along with sway bar links seeping grease. I am going to call Monday and see if my service manager can consider these ancillary parts as the total cost for replacement of both will be close to $1k.
    He also provided a list of items he has seen replaced at no labor cost and included shocks, carrier bearings, and ball joints. Any advice for these or other parts I should have replaced?
  4. Jun 29, 2019 at 8:53 PM
    #184
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Other than some butchered wiring for the aftermarket backup cam (somewhat easily fixed at home), no problems arose.
    bobsuruncle likes this.
  5. Jun 29, 2019 at 9:54 PM
    #185
    bobsuruncle
    Bob
    Fall City, WA
    06 TRD OR DCSB
    Good luck. Wear and tear isn't considered ancillary unless it's rusting away.
  6. Nov 16, 2019 at 12:26 AM
    #186
    Riodelarosa
    Riodelarosa Well-Known Member
    Oregon
    Silver o2003 Tacoma 3.4L V6
    Grill guard, rain visors, bug deflector, custom luggage bars on canopy
    Ok so, Im just jumping on this thread new. Kinda out of line, cause my frame replacement was actually on a 1st gen under 15 year extended warranty. But I came across this thread searching for frame replacement info.
    Toyota dealership outsourced my frame replacement warranty/spare tire carrier recall to an outside shop and took 2 years to do the work. Shop decided to cut off parts to cut time, and ordered and installed factory parts that werent covered (i.e. entire oem exhaust system) without my request, authorization or even notifying me until the job was said and done. They still have my truck and say I owe them ~$3,700 on shit I never signed for.
  7. Nov 16, 2019 at 12:36 AM
    #187
    Jasonstacoma
    Jasonstacoma Well-Known Member
    2019 dcsb Barcelona red
    Stock
    I'm glad you saw this post
    Riodelarosa[QUOTED] likes this.
  8. Nov 16, 2019 at 6:44 AM
    #188
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    @Riodelarosa oh that suuuuucks. Whytf did Toyota sub it out? They made the decision to do that. They should be responsible to who they subbed it out to.
    Back to the topic at hand:
    My frame replacement cost me nothing. Although I did ask them to call me because there were some things I wanted done during the process. They did not bother and showed me a list of about $5,000 worth of things they suggested including the timing chain.
    I laughed and said you're kidding? Needless to say, I declined.
  9. Nov 16, 2019 at 4:26 PM
    #189
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    It’s less than 1k to hot dip galvanize a taco frame. The dealerships should offer this option.
  10. Nov 16, 2019 at 7:28 PM
    #190
    bobsuruncle
    Bob
    Fall City, WA
    06 TRD OR DCSB
    :ohsnap:
    Got a spare set of keys? Go get your truck back. Don't even tell them your coming.
    Marc70 likes this.
  11. May 29, 2020 at 11:07 AM
    #191
    boxxed
    boxxed Well-Known Member
    Denver, CO
    09 Off Road
    I know this is an old thread but I am about to get my frame replaced. Was wondering Do they take off the upper control arms as part of this process and if so should I bring then new OEM ones to put on?
    Thanks
  12. May 29, 2020 at 2:55 PM
    #192
    dborrer
    dborrer [OP] Well-Known Member
    Mr. Dan
    St. Augustine, FL
    2006 Tacoma TRD Sport 4x MT
    2018 new Frame (thank you Rust!), FJ T-case swap. SPC(LR) UCAs, Bilstein 5100s front - rear, OME 883 at 0, HeadStrongOffRoad 3 leaf progressive AAL, MESO custom 2nd gen (Red/White) LED dome & Ultimate Maps, Spyder Halo Projector w LEDs (which SUCK), Spyder LED tails
    Man - put something better than OEM back on! I went with the most economical choice out there https://www.headstrongoffroad.com/s...g)_Ball_Joint_Upper_Control_Arms_-_25470.html Call (email) Marie at Headstrong OffRoad and you will not be disapointed - they ROCK!
    I also went with Bilstein 5100s and OEM Springs. All reassembled for free labor during my Frame recall.
    If i was doing it over, I would have also have handed them a rear Add-a-leaf (I came back and paid for that to be installed a few weeks later because I was lower in the back than front) - and that is NOT a look I condone.
    I also would have handed them: Body mount bushings, Motor and Transmission Mounts. We inspected all of mine at the time, and felt they were all "Okay" but 2 years after the frame recall I hear squeaks that i'm sure are those body mounts..... sure isn't the suspension....
    I would also hand them a new Steering Rack: mine is just starting to leak, and its not a fun looking job to DIY job- although having just last week pulled and replaced my CVs and the inner front Diff needle bearing with the East Coast Gear Supply Mod (Bushing replacement) - I can do the steering rack job, but it doesn't look fun at all..... so in hind sight, it would have been well worth the $ then to get a new rack and have them install it.
    Think of it this way: Your about Rig is about to become a forever truck... take advantage of their free labor as much as you can while you have the opportunity of a life time!!!!!
    TRDSport10 likes this.
  13. May 29, 2020 at 3:16 PM
    #193
    boxxed
    Denver, CO
    09 Off Road
    Totally appreciate that info.. I will look in to what you have suggested. I replaced the coil overs about a month ago and put shocks in the back. I am also getting the leafs replaced due to the E02 recall. I was thinking about having the rear main done for the savings. I ll see what they have to say.
    I figured the UCA is easier for me to do then the rear main seal.
    I really appreciate the info..
    Thanks.
  14. May 29, 2020 at 3:22 PM
    #194
    dborrer
    Mr. Dan
    St. Augustine, FL
    I also was given new rear leaf pkg, and therefore only did the AAL... (for now).
    Honestly i'm probably not going to lift my truck any more than the (?) 1.5-2" that happened with this suspension until I hit the lottery.
    What I don't plan to do is my clutch.... and rear main seal at that time... that is a big job to pull the transmission IMHO with out a shop and those type tools which I do not have.
    Good luck, how many miles are you?
    I'm a Colorado native.... Go Broncos!
  15. May 29, 2020 at 3:25 PM
    #195
    boxxed
    Denver, CO
    09 Off Road
    I am at 160k.. I moved here about 6 years ago.. Go Wings..
  16. May 29, 2020 at 3:28 PM
    #196
    dborrer
    Mr. Dan
    St. Augustine, FL
    HA! I grew up NFL football, hence. I only moved away because of the love of Ocean and help of a wife. Enjoy - it's an unbelievable state!
    I loved the Avs tho when they were the shit - and Patrick Roy !
    237k all mine and counting...
    boxxed[QUOTED] likes this.
  17. May 29, 2020 at 6:40 PM
    #197
    boxxed
    Denver, CO
    09 Off Road
    Where did you look up the parts you needed? I honestly can tell exactly what I should get. Its not something I am real familiar with and its a little confusing.
    Are these the parts you are referring to? https://toyotaparts.mcgeorgetoyota.com/index.php?p=cart Do I only need 2?
    https://www.amazon.com/gp/product/B00G1X9ZA6/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
  18. May 29, 2020 at 6:47 PM
    #198
    roadking1
    roadking1 Well-Known Member
    n.j.
    2023 Solar Octane TrdPro 6-speed manual
    not the upper control arms.... lower ones are replaced..bring new shocks if you want.they will be installed for free.
  19. May 29, 2020 at 6:54 PM
    #199
    boxxed
    Denver, CO
    09 Off Road
    Thanks.. Shocks were done a few months ago.
  20. May 29, 2020 at 9:31 PM
    #200
    dborrer
    Mr. Dan
    St. Augustine, FL
    go to @HeadStrong Off-Road and Marie will take care of you!
    Looks like them - mind you I personally have not researched ANY brands yet... so i have NO idea if that is a good quality product or not.
    Read some posts and threads, have fun!
    HeadStrong Off-Road likes this.
