Frame Replacement - What additional cost to expect from the Dealer?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dborrer, Apr 28, 2018.
  1. Jul 13, 2018 at 12:28 PM
    #121
    casey2012
    casey2012 Well-Known Member
    mark
    yota
    none
    i had a o6 they replaced my frame plus springs front and rear and shocks gave me a rental car they had it 3 months never charged me a thing
  2. Jul 13, 2018 at 4:00 PM
    #122
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    I’m guessing yes but don’t really know. The first time the pedal almost went to the floor, the second time it was better but still really soft so I’m thinking they hadn’t bled the brakes at all and then bled them poorly?
  3. Jul 13, 2018 at 7:29 PM
    #123
    dborrer
    dborrer [OP] Well-Known Member
    Mr. Dan
    St. Augustine, FL
    2006 Tacoma TRD Sport 4x MT
    2018 new Frame (thank you Rust!), FJ T-case swap. SPC(LR) UCAs, Bilstein 5100s front - rear, OME 883 at 0, HeadStrongOffRoad 3 leaf progressive AAL, MESO custom 2nd gen (Red/White) LED dome & Ultimate Maps, Spyder Halo Projector w LEDs (which SUCK), Spyder LED tails
    Same!!
  4. Nov 3, 2018 at 4:46 PM
    #124
    ASTacoma06
    ASTacoma06 Member
    2006 Toyota Tacoma
    i was told that lower control arms aren't part of the replacement program. are they? should I call toyota canada?
    i am getting my frame replaced on Nov 26th.
  5. Nov 3, 2018 at 8:46 PM
    #125
    MurderedTacoV2
    MurderedTacoV2 Booty Admirer
    Adam
    Hudson, New Hampshire
    06 Taco TRD OR
    3 inch lift, B110’s, Dakars, Dirty5’s, Dual Locked
    They 100% are part of the frame recall. Our parts department has them by the box outback literally hundreds of taco control arms just waiting for frames.
    _swede and dborrer[OP] like this.
  6. Nov 4, 2018 at 5:41 AM
    #126
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    You should at least check the u bolts torque, I'm pretty sure it's 90 ft lbs. And the wheels.
  7. Nov 4, 2018 at 5:45 AM
    #127
    fixnfly
    S.W.PA
    My brakes were horrible when I got my truck back. They overfilled the master cylinder and it was overflowing on the way home.
    I called back and was told "sometimes the brakes are hard to bleed." Fucking hacks
    eherlihy likes this.
  8. Nov 4, 2018 at 5:48 AM
    #128
    Jckdnls
    Jckdnls Roads less explored
    Spicer, mn
    93 3.0 v6 sr5 5spd 08 ac or 6sp
    Dakar torsion bars
    With my frame swop the did lower control arms springs and hanger bearing. Had to go back n do a retorque. It realy depends upon the dealership and how much they are willing to try n write off.
  9. Nov 4, 2018 at 8:26 AM
    #129
    lynyrd3
    Bill
    East Central Upstate NY
    I got LCA ,new rack that I paid for and the steering shaft . Now all of a sudden when I am braking coming to a stop the truck pulls right big time .Steering wheel wants to go to the right too when braking ?
  10. Nov 4, 2018 at 11:03 AM
    #130
    Jckdnls
    Spicer, mn
    Dakar torsion bars
    Check to see if tge left caliper is working. Or when they did the swop could have colapsed the hose or line. Seen that happan, whe not ptoperly hanging the calipers.
  11. Nov 4, 2018 at 3:14 PM
    #131
    lynyrd3
    Bill
    This just started happening ,my frame was swapped months ago :notsure:
  12. Nov 4, 2018 at 3:25 PM
    #132
    Jckdnls
    Spicer, mn
    Dakar torsion bars
    If it only does it while braking than chances are a caliper may have went bad. Does it pull when you just take your foor off the throttle?
    lynyrd3[QUOTED] likes this.
  13. Nov 4, 2018 at 3:34 PM
    #133
    lynyrd3
    Bill
    Yup ,when braking
    Jckdnls[QUOTED] likes this.
  14. Nov 4, 2018 at 3:35 PM
    #134
    lynyrd3
    Bill
    Guess it’s time to upgrade them calipers :D
  15. Nov 5, 2018 at 6:06 AM
    #135
    MurderedTacoV2
    Adam
    06 Taco TRD OR
    Frozen caliper pistons and possibly warped rotors, my fronts have been warped for about 25 k and it pulls hard right with crazy steering wheel twerk on braking. Still sending it to this day lol.
    _swede likes this.
  16. Nov 5, 2018 at 7:38 AM
    #136
    lynyrd3
    Bill
    Put PowerStop drilled and slotted rotors and PS pads probably 4-5 years ago and broke them in properly . Pads still look good . Just took it for a ride and now it’s not pulling when braking :notsure:
  17. Feb 27, 2019 at 2:51 PM
    #137
    _swede
    _swede Well-Known Member
    NH
    '17 TRD OR DCSB AT
    This made me LOL:
  18. Feb 27, 2019 at 3:21 PM
    #138
    SWPA Tacoma
    SWPA Tacoma Well-Known Member
    Stevo
    2006 White Tacoma DCLB
    First thing I did after my frame replacement was have it fluid filmed. Found a guy that does it on a lift he has in back of his house....$125. Man did he do a great job too.
    lynyrd3 likes this.
  19. Feb 27, 2019 at 5:30 PM
    #139
    MurderedTacoV2
    Adam
    06 Taco TRD OR
    138K on original the front rotors now, the sending continues my friend.
    RCBS likes this.
  20. Feb 28, 2019 at 6:34 AM
    #140
    _swede
    NH
    '17 TRD OR DCSB AT
    Adam, I do believe you, but do you have anything in writing to support this? Is there a Toyota service bulletin out there that has authorized parts/labor list? I saw the list in this thread that one member had covered for his specific truck (haven't even checked if the LCAs are on there yet), but I don't think that's enough to justify my argument anyways.
    They're ordering my frame and the service adviser told me "no, they're definitely not included". I'm going to do my research and be prepared when the frame arrives.
