Frame Replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by jsabowabo, Dec 20, 2016.
  1. Dec 20, 2016 at 6:46 PM
    jsabowabo
    jsabowabo [OP] Well-Known Member
    Evans, GA
    2004 Xtra Cab 4x4 TRD
    Stock
    I'm having my frame replaced by Toyota in the next few weeks. The frame is all solid, except for this spot on the drivers side rear. Is there anything else I should have the Toyota dealer do while they are doing the work? It's an 04 XtraCab 4WD with 237K. Timing belt and water pump were done at 209K. The truck lived 6 years in Ohio, then 6 in North Carolina. It passed frame inspection in 2012, but I guess the Ohio road salt was not kind to it.
    I'm basically wondering what parts I should be buying to give to the dealer in the next few weeks. So far I bought a pair of new Bilstein rear shocks and a new rear bumper..
  2. Dec 20, 2016 at 6:51 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    That sucks. Would be good to check your brake hard lines and junction block(s).
  3. Dec 20, 2016 at 11:31 PM
    ghs57
    ghs57 Well-Known Member
    Chops
    Catskill Mts. NY
    '17 Grey TRD OR xtracab 3.5L 4WD
    Pretty much stock right now
    You will get new brake lines. I also had them replace a leaky rear main seal while they had the engine out, and some other small items where I only had to pay for the parts.
  4. Dec 21, 2016 at 6:19 AM
    ROCKIN RICHIE
    ROCKIN RICHIE Well-Known Member
    BEAN TOWN
    02'TACO
    If you're keeping the truck... get that list going as Toyota will replace anything for list price of parts and you'll have virtually a new truck! Did my frame in 2008 and truck still tight as new.
  5. Dec 21, 2016 at 8:34 AM
    TacoMan2017
    TacoMan2017 Well-Known Member
    Man, I hate to drive on salted roads...
  6. Dec 21, 2016 at 8:40 AM
    retroboy1989
    retroboy1989 Single Cab 4x4
    99 2.7L 5spd 4x4
    I didn't know Toyota still replaced frames on 1st gens....
  7. Dec 21, 2016 at 8:53 AM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    Yip...the 02's are starting to all be too old/coverage time expiring, but the last two year models still have another couple years or so left on the coverage clock. If covered it is still 15 years from the date it rolled off the lot so till all first gens have become that old frame replacements will continue...
    Nutritive and Logger like this.
  8. Dec 22, 2016 at 1:39 PM
    carofchoice
    carofchoice Well-Known Member
    Jeff
    Newton, IL
    2003 DC 4X4 TRD, 2012 X-Runner
    OP, check with the dealer if they will add parts or not. the dealer i took mine to wouldnt do anything that didnt come with the frame. some dealers do and some dont. before you go buying all this stuff, check first unless you dont mind doing some of the work.
  9. Dec 22, 2016 at 4:03 PM
    jsabowabo
    Evans, GA
    Stock
    That's good advice. The passenger side valve cover was leaking oil, so I pulled them today and replaced the gaskets. I don't want to pay the dealer $400-500 in labor. I don't think they would cover that even if they were "nice".
    Nutritive likes this.
  10. Feb 4, 2017 at 10:32 AM
    jsabowabo
    Evans, GA
    Stock
    I got a call from my service manager and my new frame is in. I drop it off Monday. He said to include any new parts I want swapped out and their is no charge for labor. I put new bilstein 5100's front (on 1" lift) and 4600's for the rear, along with a new back bumper. After this its new tires. We will see how it goes.
  11. Feb 4, 2017 at 3:27 PM
    twp
    twp Well-Known Member
    Ky
    2002 trd
    They replaced mine at the first of the year. Took a week to get it back. Truck drives like new, and feels nice and tight.
  12. Feb 4, 2017 at 9:54 PM
    bry838
    oregon
    That good they offered to swap any parts of your choice. Some guys on here have ended up having to pay labor for any aftermarket goodies because their stealership are a bunch of greedy bastards!
    Logger likes this.
  13. Feb 5, 2017 at 6:02 AM
    Logger
    Logger out for a rip are ya bud?
    Sam
    '13 TRD OR Double Cab
    Make sure they set your front shocks on the correct setting. There's no 1" option on 1st gen billies. You got either 0, 1.25 and 2.50
    Just make certian they don't set it on 2.50! It'll ride terrible on stock coils, the reason I suggest double checking is, time is of the essence for them. The faster they complete the swap the more they pocket out of the allotted 62 swap time.
  14. Feb 5, 2017 at 6:37 AM
    PFA1975
    PFA1975 Well-Known Member
    PFA
    San Diego, CA
    03 TRD 4WD Xtra Cab
    Fox 2.5 CO Fox 2.0 rear shocks
    Subscribed... Thankfully, my Taco has spent it's life in TX and CA.
  15. Feb 5, 2017 at 10:43 AM
    jsabowabo
    Evans, GA
    Stock
    Not mine. First six years in Ohio, then North Carolina the next 6. Ohio was not kind to it, but I've seen much, much worse. I'm undecided over leaving the new frame alone or coating it with POR15 or something.
  16. Feb 5, 2017 at 11:21 AM
    bry838
    oregon
    I believe the new ones bilstein makes have 4 settings now and think there is a one inch setting or somewhere close to. I think i read that somewhere recently? Anyone have a confirmation on that, as far as 4 settings on a new design 5100??
    eon_blue likes this.
  17. Feb 5, 2017 at 12:11 PM
    jsabowabo
    Evans, GA
    Stock
    My 5100's have 4 settings. Stock, .67, 1.3, 2 or something similar. I went for the .67. It defintly has four clip positions.
  18. Feb 5, 2017 at 10:16 PM
    bry838
    oregon
    Yeah, i thought there was a new 4 position design...
  19. Feb 6, 2017 at 12:58 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Yeah, there are actually 2 different 5100s available for 1st gens (both can be seen on Headstrong's website), one has 4 settings and the other has 3.
  20. Feb 6, 2017 at 1:28 PM
    Big Daddy
    Big Daddy Well-Known Member
    Jeff
    New Jersey
    2003 Tacoma Dbl Cab 4WD
    Let us know how it goes - I should hear tomorrow concerning mine.
