Frame Rust 2001 -2004
Discussion in '1st Gen. Tacomas (1995-2004)' started by twfsa, Sep 23, 2010.
  1. Nov 21, 2012 at 5:19 PM
    #161
    DblCabMN
    DblCabMN Well-Known Member
    Mpls, Minnesota
    03 DC TRD/LTD
    Bilstein 5100's all around - Toytec/Eibach 112-620 Coils, Wheelers 5-Pack+Wheelers 2"AAL. 33x10.5x15 KM2s - Siped on Summit Racing 84-5883 rims with 3.750 BS. 4.88s. Demello HD round sliders. Home built full skids. Home built front bumper. Plasti'd badges. Energy Susp. steering rack bushings. Sway bar delete. Deck plate mod. aFe Pro-Dry. Gibson exhaust.
    I'm thinking my frame has some sort of rot i can't find. When i put the front up on jack stands placed just in front of the cross member-before the frame kicks back in towards the center. When releasing the jack slowly, once the frame rails are touching the jacks and i keep lowering, the front end seems to 'sag' a good 2 inches.
    Has anyone else experienced this? My friend with a 98 Xcab 5vz said his never 'sagged' and it was bought back for rot last year. He sees the flex too. Would the weight of the double cab alone be enough to cause this? Am i just seeing things? or could my frame be stretching/flexing that much due to rot somewhere that i can't see?
  2. Nov 22, 2012 at 5:14 AM
    #162
    85GT 79FJ40
    85GT 79FJ40 Well-Known Member
    Ken
    New Hampshire
    19 TRD Sport DCSB 6M - 2017 Honda Africa Twin
    I think you're just seeing the truck's suspension settle. Frames do flex slightly but if yours was flexing that much it would have VERY visible rot issues.
  3. Nov 22, 2012 at 6:45 AM
    #163
    DblCabMN
    Mpls, Minnesota
    03 DC TRD/LTD
    This is with the front tires a few inchs off the ground, but i'm assuming you mean the rear leafs are unloading and 'teeter tottering' the front end down.
    Next time i put it up, i'll watch the bed to see if it goes up while the front drops. Thanks for the (hopefully) logical explaination.
  4. Nov 22, 2012 at 9:06 AM
    #164
    Swampmonkey
    Swampmonkey Well-Known Member
    Wes
    Fairhope, AL
    2011 Prerunner TRD DC
    UWS black low profile toolbox, TRD intake, TRD exhaust, TC uca's, Rear 2" toytec aal, OME Front and Rear shocks, OME 885s, NFABs
    Just bought a little 2003 reg cab 2wd. Do you have to be the original owner to get frame installed or sprayed under warranty?
    Brie likes this.
  5. Nov 22, 2012 at 9:25 AM
    #165
    fishbomb
    fishbomb Well-Known Member
    nh
    sr5
    bilstien coil overs add aleafs With bolstiens in rear, mickey thompson mtz tires 285/75r16 on 16x8 dick cepek dc2 wheels. Hella black magic 500 lights up front.
    I am not the original owner. I would contact Toyota corporate and ask questions. My trucks previous owner had the truck frame go through the dealership treatment process less than 2 years ago. I found rust and holes. I contacted Toyota corporate and sent it to local dealer for inspection . New frame is in future.
  6. Nov 22, 2012 at 12:12 PM
    #166
    antler3649
    antler3649 Member
    Eric
    Yellowstone Natl Park
    I found a couple of soon-to-be holes, along with this (pretty major) hole in the frame. Have my inspection appointment on Monday. I'll probably get new shocks up front, a new timing belt/water pump put on, and my A/C fixed while they have it all apart. Anything else that I should get done?
    In response to the person 2 posts up: you do not have to be the original owner to get the frame replaced/sprayed. However, you do have to get it into the dealership before the end of the year for the warranty to be valid, so get on that ASAP.
  7. Nov 22, 2012 at 2:02 PM
    #167
    Taco.VR4
    Taco.VR4 Fast Cars, Off-Road Trucks, and Hott Women ;)
    Jay
    Grand Rapids, MI
    '02 Tacoma, '97 3000GT
    5100s, Icon 3 AAL, Custom-built front/rear bumpers, Hybrid seats, 3000GT modified intake box, toolbox, D-rings
    negative
  8. Nov 22, 2012 at 5:45 PM
    #168
    Keith Mahoney
    Keith Mahoney Member
    keith
    Aviano, Italy
    99 extended cab TRD 4x4
    HomeBrewTalk.com sticker
    It may have been covered here already but does anyone know how much a new frame from toyota costs if I ever wanted to do a replacement myself? I just paid 10k for my 1999 extended cab, 4x4 TRD off-road with 3.4 manual and 155k miles with records of all servicing done by the dealer.
    The price was high but I am in Hawaii and things cost more here. Plus the truck was from the original owner and came from southern California. It has a clean rust free black frame which is the reason I paid so much for it. This is the truck I have always wanted and when the frame goes I won't mind spending a few grand to get a new frame for it.
  9. Nov 27, 2012 at 10:58 AM
    #169
    antler3649
    antler3649 Member
    Eric
    So as an update - made an appointment at the dealership for 8:20am on monday. Took the truck in and there was an argument between CEC and the Warranty center at toyota corporate, so we got sent away with our truck at 11:30. 3 hours sitting in a dealership just to get the frame inspected (and fail).
    Talked to CEC at Toyota and they were still convinced that my truck would be covered and not to worry it was a mixup between the dealership and the warranty center and I should hear back later on Monday.
    Tuesday morning the dealership just called me back saying that Toyota would be replacing my frame "because it's the right thing to do...and as a nice gesture," but the last guy he replaced a frame for ended up having to pay $1,000 out of pocket for the repairs that weren't covered in the warranty. As he said "for things like bushings and brackets that were too rusty to put back on." I take it that this is not the norm. Sure, I plan on having some extra work done (front suspension, etc...) but I'm hoping that the frame replacement kit comes with all of those parts.
    So, those of you that have had it done - did it cost you anything extra for stuff that couldn't be put back onto your truck?
    Brie likes this.
  10. Nov 27, 2012 at 6:21 PM
    #170
    vantaco
    vantaco Well-Known Member
    02 Taco Xtracab TRD Step Side
    sorry, what i forgot to add is that both dealerships i took it too said that since the inspection and coating was already done they refuse/can't reinspect it again which i think is total bull shit
    so should i just keep forcing it (i'm thinking i'll talk to a manager next time) or just go right to Toyota Canada?
    Brie likes this.
  11. Nov 27, 2012 at 6:34 PM
    #171
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    I thought the cutoff date was the end of 2011...not 2012.
  12. Nov 28, 2012 at 4:27 AM
    #172
    fishbomb
    nh
    sr5
    Toyota told me inspections yearly for free. The replacement frames are supposed to be ok.
  13. Nov 28, 2012 at 2:46 PM
    #173
    FishinTaco
    FishinTaco Well-Known Member
    D'Arcy
    Sudbury, ON
    TRD 4x4 5spd
    5100's all the way around, OME 880's and AAL, BF's 265/75R16. Switched beds from Stepside to Fleetside
    Hey Vantaco, Taco.VR4 is right, if it has been sprayed (by the dealership under it's campaign) your warranty is tact. They will inspect it yearly or take it in when you find a hole. Push it for sure, the guy you are talking to doesn't have a clue.
    DC
  14. Nov 28, 2012 at 3:32 PM
    #174
    jodjr
    jodjr Well-Known Member
    New Hampshire
    03 Tacoma V6
    Ya Fishin is correct...I bought my 2003 last year...it was treated buy Toyota 2 years ago and it failed. New frame , springs, brake lines, all fluids, front end parts. I bought new front bumper and timing belt...even though it only had 50k miles on it.
    Antler...that is incorrect...you don't have to spend a dime. All fasteners and hangers etc. will be covered by Toyota. The replacement includes these items.
    The bill for my replacement was about 13k paid for by Toyota...Never heard of GM or Ford doing this for their customers.
  15. Nov 28, 2012 at 3:37 PM
    #175
    ak47dennis
    ak47dennis Well-Known Member
    dennis
    Pa
    TRD
    That's because frames rotting out from crap metal aren't the norm. ;)
    Brie likes this.
  16. Nov 28, 2012 at 7:06 PM
    #176
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    Fishin and ffirg are correct.
    I had my frame inspected last Nov, passed, and recieved the rust-proofing.
    I called on Monday to schedule another inspection and rust-proofing for this Saturday but was told that the coating is a one-time deal. The Service Manager (whom I'v dealt with in the past and trust) said that the deadline to recieve the coating was indeed 12/31/11 and that those trucks that were not inspected and coated prior to that date are no longer included in the extended warranty. He basically said that I got in just in time last year and that others who failed to do so are SOL.
    They will still inspect my frame for perforations on a yearly or as requested basis and replace faulty frames up until the 15 yr extended warranty has expired.
  17. Nov 28, 2012 at 11:16 PM
    #177
    ffirg
    mike
    Anchorage, Alaska
    That's what I thought. I thought I read somewhere that if you live in certain states (Alaska being one of them) that you do not need to take further action and that the 15 year extended warranty will still apply. It had something to do with those states not offering the rust proofing service. When I contacted my dealer they acted like they've never heard of the rust problems and tried to charge me for the inspection...I never went back so I guess I'm SOL if the frame ever fails...
  18. Nov 29, 2012 at 3:46 AM
    #178
    ak47dennis
    dennis
    Pa
    TRD
    Toyota told me that the extended frame warranty is ONLY good in the 48. That Hawaii & Alaska is another division.
  19. Nov 29, 2012 at 6:18 AM
    #179
    TIPICOTACO
    Tyler
    nw nj
    damn there's so much speculation and inconsistency regarding this situation..
    there's got to be a Toyota Service guy on this site that can set us all straight.. anyone out there??
    Brie likes this.
  20. Nov 29, 2012 at 10:11 AM
    #180
    antler3649
    antler3649 Member
    Eric
    As I'm dealing with this right now, I can for sure let everyone know that New York State is an exception to this rule. Due to EPA regulations in NY State, the treatment wasn't approved for an extra year. So, if you're in the state of New York, you have until 12/31/12 to have the frame treatment applied. So get in soon!!
    Also, states outside of the 12 "salt states" in the NE are not covered in this warranty. According to Toyota they just "don't have these issues outside of the dozen salt states for some reason." Not sure if AK is covered as well, but I know for sure that Utah (a state that salts its roads more than the places I've lived in the midwest) is not covered.
    Hope this clarifies a few things for people.
