frame rust buy back
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jeremy175, Feb 17, 2013.
  1. Feb 14, 2016 at 10:07 AM
    #121
    Joestoy
    Joestoy Member
    2004 Tacoma rust bucket
    This is the info from toyota
  2. Feb 14, 2016 at 10:17 AM
    #122
    ghs57
    ghs57 Well-Known Member
    Chops
    Catskill Mts. NY
    '17 Grey TRD OR xtracab 3.5L 4WD
    Pretty much stock right now
    That's worth having the dealer check out. They should know if it's theirs. Possibly the record is missing. Your service record timing of 2010 is about right for this. Also possible that the original owner had it coated by the dealer before delivery. This is what a friend of mine did when he bought his truck back in 2003.
  3. Feb 14, 2016 at 10:25 AM
    #123
    Joestoy
    Joestoy Member
    I wonder why all the dealerships don't know about this.
  4. Feb 14, 2016 at 10:41 AM
    #124
    carofchoice
    carofchoice Well-Known Member
    Jeff
    Newton, IL
    2003 DC 4X4 TRD, 2012 X-Runner
    that's what I'm saying. I've talked to two warranty guys at two different dealers and neither of them knew anything of the 15-year warranty (from production date) after the coating has been applied.
    thanks for the copy of the letters Joestoy, will have to take this to the dealers and see what they have to say.
  5. Feb 14, 2016 at 10:42 AM
    #125
    ghs57
    Chops
    Catskill Mts. NY
    Where are you located? My dealer said something similar the first time I brought it in after I bought it in 2013 until they ran the VIN and saw that it met the warranty requirements. This from a dealer that has done hundreds of frame replacements, including my 2001 two years before. The warranty on '95-'00s has expired, which was for Toyota to buy back the vehicle because frames were not available for those model years. The '01-'04s are also beginning to age out of warranty (provided corrosion protection was applied as required by the terms of the warranty extension).
    There are dozens of threads on this topic here, and many stories of denied claims. At least check your service records for the required inspection/preventative maintenance. If they are still not cooperating, ask for the regional rep, or higher. If you are going to be turned down, at least get that from Toyota corporate.
  6. Feb 14, 2016 at 11:05 AM
    #126
    carofchoice
    Jeff
    Newton, IL
    the truck is originally from MA, now it's in IL. both states are part of the cold weather states on Toyota's list. the CRT was applied in Jun 12th 2011
    I'm not sure if the dealer I took it to has done any frame replacements yet. I took it in to get the timing belt changed, I asked the guys when I was picking it up about the frame and they acted like I was gonna rob them. first thing I asked them about the frame and he just cut me off and was like "it's over!" so I asked, since I just purchased this truck I'm screwed out of the money I just spent purchasing it. he was like pretty much... after I brought up the 15-year warranty since the truck has been CRT'ed he was like well if there is penetration through the frame (10mm hole) then we can start the process with Toyota. he never really gave me a straight forward answer so that's why I took it to another dealer. the other dealer thinks that once the CRT has been applied, Toyota's end was completed.
    thanks for the info ghs57, I was planning on going higher with it like you suggested since dealers aren't being very helpful
  7. Feb 14, 2016 at 11:24 AM
    #127
    Joestoy
    Joestoy Member
    Toyota has really gone down hill. I thought i was buying I very reliable truck
  8. Feb 14, 2016 at 11:27 AM
    #128
    carofchoice
    Jeff
    Newton, IL
    no kidding right, I've owned a few Toyota's and never had any problems with them. hate to have to make a switch to chevy or ford ;( if Toyota doesnt back their vehicles.
  9. Feb 14, 2016 at 11:27 AM
    #129
    Joestoy
    Joestoy Member
    Ghs57 what dealership did you use?
  10. Feb 14, 2016 at 11:29 AM
    #130
    ghs57
    Chops
    Catskill Mts. NY
    It would seem there can be some miscommunication on this issue at the dealers, and between us owners. You did at least get a positive response from the tech should they find a hole. But you would think based on that response the cost was coming out of his pocket. It seems the techs at my dealer have been quite thorough in their inspection or my vehicles. It's almost as if there are looking for the work. Toyota must have a pretty good reimbursement plan for the dealers when they do this work.
    But, employees come and go. New people may not be as familiar with all the warranty/recall specifics, and the volume of this work probably has fallen off from the high a few years ago. The dealer used to have stacks of Tacoma frames in the back lot. I wish I had taken a picture when my '01 was done.
  11. Feb 14, 2016 at 11:29 AM
    #131
    carofchoice
    Jeff
    Newton, IL
    first dealer was in Effingham IL. Dan Hecht Toyota and the second one i asked question at was in Mattoon IL. KC Summers Toyota
  12. Feb 14, 2016 at 11:32 AM
    #132
    ghs57
    Chops
    Catskill Mts. NY
    Closest dealer to me:
    Prestige Toyota
    756 E. Chester St By-Pass
    Kingston, NY 12401
  13. Feb 14, 2016 at 11:34 AM
    #133
    carofchoice
    Jeff
    Newton, IL
    From his response it did seem as though the cost was coming out of the dealer. I was really surprised that he acted that way since Toyota would be paying for all the costs, not the dealer. when they did the frame inspection first before the timing belt he stated that the frame had soft spots while being struck with a ball peen hammer. with the CRT covering the rusted areas together it may not show a hole. The CRT is flaking off all over the frame so I'm sure in time the rust will produce a hole somewhere.
  14. Feb 14, 2016 at 11:37 AM
    #134
    Joestoy
    Joestoy Member
    I may have to drive out of Louisiana to get this done!!
  15. Feb 14, 2016 at 11:37 AM
    #135
    carofchoice
    Jeff
    Newton, IL
    maybe ill give them a call sometime and see what they say. i wish they were closer to give them the business
  16. Feb 14, 2016 at 11:40 AM
    #136
    Joestoy
    Joestoy Member
    Same here.
  17. Feb 14, 2016 at 11:41 AM
    #137
    Joestoy
    Joestoy Member
    Feel like I'm about to eat almost 10000
  18. Feb 14, 2016 at 11:43 AM
    #138
    carofchoice
    Jeff
    Newton, IL
    I'll keep things updated on here. since I just got the frame inspected last month, ill check back in the summer for another checkup and post what they say.
    thanks again Joestoy and ghs57
  19. Feb 14, 2016 at 11:45 AM
    #139
    carofchoice
    Jeff
    Newton, IL
    I know how you feel. paid 13100 for the truck and another 1300 for the timing belt and other maint i just did. whenever I contact Toyota I will def be including the cost of everything and ask them if I just tossed it all out the window.
  20. Feb 14, 2016 at 11:46 AM
    #140
    Joestoy
    Joestoy Member
