Frame rust opinions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RtacomaN, Feb 18, 2019.
  1. Feb 18, 2019 at 6:31 PM
    RtacomaN
    RtacomaN [OP] Well-Known Member
    Taylor
    Colorado
    Hey all, I’m looking at an SLC truck (2007) and was hoping to get some opinions of this frame rust since I’ll be coming from out of town. I’m definitely going to be picking through it with a fine tooth comb but from what you can see does the rust on it concern you? Frame hasn’t been replaced and is recall eligible. Thanks everyone.
  2. Feb 18, 2019 at 7:02 PM
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
    That frame is fine.
    blu92in99 and RyanL like this.
  3. Feb 19, 2019 at 4:33 AM
    Johnders
    Johnders Spacer Lift Survivor
    2010 Black Access Cab Tacoma Base
    2" Lift , 265/75R16 tires, K& N filter, MBRP Exhaust
    Doesn't look bad at all, typical slight rust from being over a decade old but actually pretty clean. Much better then my 2010.
  4. Feb 19, 2019 at 4:35 AM
    Clearwater Bill
    Billy
    Largo Florida
  5. Feb 19, 2019 at 6:43 AM
    96carboard
    96carboard Well-Known Member
    You didn't actually take a picture of the important spots, which would be from under the truck pointing outward towards the front body mount. Your last picture shows the front body mount. If you look carefully into that body mount (you can't see it in your picture), you will notice a big hole at the back of it exposing the inside of the boxed section of the frame. Now look where the wheels is, and where it will be throwing road crap. See how that road crap will be thrown into the boxed section of the frame? What's what you need to be worried about.
    TRDSport10 likes this.
  6. Feb 19, 2019 at 12:17 PM
    RtacomaN
    Taylor
    Colorado
    These were the pictures I got from the guy 4.5 hours away before it got dark, sorry, all I had. I will look in those spots though, thanks!
  7. Feb 19, 2019 at 12:17 PM
    RtacomaN
    Taylor
    Colorado
  8. Feb 19, 2019 at 12:18 PM
    RtacomaN
    Taylor
    Colorado
    Thanks guys, I’ll still take a good look but glad it doesn’t appear too bad in these spots .
  9. Feb 19, 2019 at 4:04 PM
    Hot Tacoma Blown
    Hot Tacoma Blown Well-Known Member
    NewYork
    05 4×4 tacoma
    Super charged,urd u - conn computer 7th injector, headers, pipe bomb y pipe,high flow exhaust.etc....
    frame looks good grind clean zinc and seal. it may help. did it all each year.And got a new frame!good luck.ps look 4 broken leafs 2.
