Frame rust recall
Discussion in '2nd Gen. Tacomas (2005-2015)' started by markey, Feb 14, 2013.
  1. Dec 5, 2018 at 7:37 AM
    #3281
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    You might want to have your lower steering shaft replaced. The u-joint tends to corrode and stick (bad ju-ju when trying to steer) and now is the time. I had a couple other things done. No labor just parts. The guys doing it were experienced and still messed up a bunch of stuff. I took it back and they made it right.
  2. Dec 30, 2018 at 9:48 AM
    #3282
    Ajamar
    Ajamar New Member
    Peter
    2011 Silver Tacoma
    Well it's finally done!
    Haddad Toyota (Lenox/Pittsfield) did the rusty frame treatment. They kept the vehicle for a week, scaled the frame, treated it with a black, wet, tar-like spray and covered holes with "plugs". I was told this is the treatment that is used on frames under recall. All of which was done "in-house" and not outsourced like the first time. I will add that if it wasn't for the Service Manager, whom I dealt directly with in the end I would probably still be fighting with them.
    Additional, during this process I worked with a woman from the Berkshire Consumer Services Program (BCRHA), working in cooperation with the Massachusetts Attorney General’s Office who guided me on a few things. Apparently Haddad has multiple complaints filled against them and are known for their poor customer service. Contact the BCRHA if you have any issues with Haddad, they're on first name basis with each other.
    BCRHA also told me that vehicle sales is the number one complaint they get in the Berkshires.
  3. Jan 7, 2019 at 8:24 AM
    #3283
    Pianozchfr
    Pianozchfr Member
    2007 sr5 4x4 4.0 access cab
    Hi Y'all
    I have a 2007 Tacoma v6 access cab 4x4. I am located in Michigan. The truck has 120000 Miles on it and is all around a great truck. I took it into the dealer about a week ago for the frame inspection and was told that it was not eligible because it was inspected and sprayed in 2015. Also, the truck was originally sold in Canada and that would also make it not eligible for inspection and if necessary replacement of the frame. It has been 3 years since it was sprayed and i was not the owner of the truck when this was done in 2015. The Undercoating is now flaking off and she is looking a bit rusty. Do I have a leg to stand on or am I sol when it comes to getting it inspected and may be replaced? What do you all think? Oh, this is my first post on Tacoma world so I apologize if I am ignorant of any well know Tacoma knowledge.
    Thank you in advance for your help
  4. Jan 7, 2019 at 9:29 AM
    #3284
    sgage
    sgage Well-Known Member
    2007 Red Tacoma SR5
    The fact that it was previously inspected and sprayed 3-4 years ago IN NO WAY makes it ineligible for another inspection, and if it meets the criteria, a frame replacement. However, I don't know about the originally-sold-in-Canada angle. I would contact Toyota Customer Service.
    robssol likes this.
  5. Jan 7, 2019 at 10:35 AM
    #3285
    DLillest
    DLillest Well-Known Member
    Quebec, Canada
    2007 SBM DCSB 6MT 4x4
    I agree with the above poster. I purchased mine last summer and when I called the dealer to have the frame inspected, they told me the same thing,
    "Sorry it was already inspected and sprayed 8 months prior".
    I told them that's not how it works and I wanted it inspected again. So they agreed and approved me of a new frame that same day.
    As others have said, I'm not sure about the Canada/US condition though.
  6. Jan 7, 2019 at 10:47 AM
    #3286
    Pianozchfr
    Pianozchfr Member
    Update
    I contacted Toyota customer service and they told me to go to a different dealership to have the inspection done. Ok... I called the other dealership and they said I can get it inspected and I have an appointment for this Saturday. Yay! Should I take the time to get under my truck with a hammer and do some pounding to see if there are any holes? I am afraid if I touch it they will void the warranty. Let me know what you all think and I will keep this updated with how it goes.
  7. Jan 7, 2019 at 11:40 AM
    #3287
    Northern Taco
    Northern Taco Well-Known Member
    2022 Tacoma trd off road premium 2023 tundra trd off road
    If it's a Canadian truck they simply run the vin through the Canadian system. I had a USA truck and that's what they did for that truck. I'd have a look under your truck at the frame about where your feet would sit while in the front seats, the catalytic converters are next to the frame and the heat generated from them speed up the rust process. Lightly tap around, that will not void anything.
    robssol likes this.
  8. Jan 7, 2019 at 12:16 PM
    #3288
    Markcal
    Markcal Well-Known Member
    Peter,
    You have every right to want your frame redone because they never prepared the frame properly, but technically they are correct about getting a new frame if a perforation is found while coating it. This extended warranty or "LSC" only applies to Tacoma from 2005-2010, so this wouldn't apply to your 2011, so anything the dealership does is because they want to keep you as a loyal customer, not because they have to.
    Ajamar[QUOTED] likes this.
  9. Jan 7, 2019 at 12:20 PM
    #3289
    ClassicVW
    ClassicVW Well-Known Member
    George
    North and South Jersey
    2018 Tacoma SR 4x2 2.7 DCSB MGM
    It couldn't hurt to poke around and see if any problem areas pop up. I'd want to know if it was my truck, regardless how it plays out with the dealer. Just don't tell them you poked around, don't want to give them an excuse to blame you for their rust problems.
    robssol likes this.
  10. Jan 7, 2019 at 12:52 PM
    #3290
    Pianozchfr
    Pianozchfr Member
    Thank you all for your help. Looks like I am going to be under my truck tonight. I am hoping to get a new frame out of this but as you said regardless I want to know if my frame is toast.
  11. Jan 7, 2019 at 2:18 PM
    #3291
    nighthawk6
    nighthawk6 Member
    07 TRD Crew SB
    look on the inside frame rail next to the cat. significant problem area
  12. Jan 7, 2019 at 3:11 PM
    #3292
    Hashc93
    Hashc93 Well-Known Member
    Do this make sure its a big hammer too I think using the claw works best.
  13. Jan 7, 2019 at 3:37 PM
    #3293
    Pianozchfr
    Pianozchfr Member
    Update.
    Well I tapped away in those areas and I think I may have one of the only Tacomas with a stock frame from a northern state that is still in good shape. I was not even able to find a little hole. Darn. I am still going to bring it in on Saturday to see if they can find something I cant. I will keep y'all updated.
    TOMB, george101 and Marc70 like this.
  14. Jan 7, 2019 at 3:49 PM
    #3294
    Markcal
    I have a 2006 Tacoma from Saltachusetts and the dealership associate remarked that my frame looked like it came from the south it looked so good, so my OCD about cleaning my frame has paid off I guess:confused: :boink:
    george101 and Pianozchfr[QUOTED] like this.
  15. Jan 8, 2019 at 5:50 AM
    #3295
    Fiesta346
    Fiesta346 Well-Known Member
    PA
    2013 Tundra rock warrior
    My frame was great I took it anyways and they applied the anti corrosive applicant to my frame free of charge. Even though yours is good it's worth taking
  16. Jan 17, 2019 at 6:52 AM
    #3296
    Pianozchfr
    Pianozchfr Member
    Update
    Hi Y'all. Well my frame passed inspection and the warranty is up July 20th so it looks like I am going to be scraping all the old Toyota undercoating and rust off and putting on the 3 step por15 on the whole frame. Do you all have opinions about undercoating when you take the frame down to bare metal? Thank you for your input.
    robssol and george101 like this.
  17. Jan 17, 2019 at 7:03 AM
    #3297
    vwbuggsy
    vwbuggsy Well-Known Member
    Clinton, MD
    09 DC 4X4 LB Black Sand Pearl
    N-fab steps, Wet Okole Covers, line-x, tint, vent shades, budget stereo upgrades, weathertech floor liners
    No undercoat. Go with something soft and semi temporary like fluid film, boiled linseed, waxoyl, etc.
    Personally, I don't drink the por 15 koolaid either. I've used it, it's highly overrated. It's a bitch to work with and unless your prep is perfect, which is challenging, it will come off in sheets later or worse trap and exacerbate rust. It's uv sensitive and overpriced. If you do take the frame down to bare metal though and do great prep work, it is a solid product.
    I use rust bullet or master series primer, and for frame or undercarriage work then black rustoleum. All of which are far more forgiving and easier to work with.
    Best of luck!
  18. Jan 17, 2019 at 8:06 AM
    #3298
    Pianozchfr
    Pianozchfr Member
    Thank you for your input I will look into the products you listed.
  19. Jan 17, 2019 at 12:02 PM
    #3299
    iowa530
    iowa530 Well-Known Member
    Iowa
    08 Double Cab 4X4, TRD
    I have a 2008 that passed inspection last year. The frame is covered in surface rust, but otherwise seems solid. I'd like to get a new frame, but I doubt I ever qualify, only 67,000 mi.
    On a side note, I have a 2008 Rav4 with the 2.4l I4 that has oil issues. It too is low miles, so it doesn't use enough oil to qualify for new rings, etc...
  20. Jan 17, 2019 at 2:08 PM
    #3300
    ClassicVW
    George
    Not sure what you're asking. You want Toyota to warranty your Rav forever?
