Frame rust recall
Discussion in '2nd Gen. Tacomas (2005-2015)' started by markey, Feb 14, 2013.
  1. Feb 6, 2019 at 7:15 PM
    #3421
    OutriderDan
    OutriderDan Member
    Daniel
    '07 Tacoma DCLB TRD Sport
    I was qualified today as well! Such a relief. I haven't read through this whole thread because it is so long, but if I can offer my advice to those of you researching before you take it to a dealership for its first inspection, learn from this:
    First, I took the truck in blindly without having inspected it myself. Don't do that.
    Second, know what the settlement document defines as the "rust perforation standard" and also know whether you are still eligible according to the defined time period. A GM of a dealership tried to tell me that it had expired. He was wrong. ----"A 10 mm PERFORATION". That's one perforation and you qualify. You won't be approved if it's only through one layer of the two layer frame. Even if the top layer is critically delaminated. MAKE SURE THEY MEASURE IT IN THE CLAIM THEY SUBMIT TO CORPORATE ---- time period; 12 years from date of first purchase.
    Third, listen to the guys on this thread and take a hammer to it. This opened up 2 holes in my frame, which would have been denied otherwise. Light tapping is all you need to find a bad spot.
    I was denied because of no perforations. Persisted enough to get the field rep out after I found the holes. Very impressed with the field rep I met today. A heck of a guy. I had an answer in 40 minutes.
    Do all these things before taking it in and you may avoid some of the same anxiety from the last week!
  2. Feb 6, 2019 at 7:31 PM
    #3422
    jepho
    jepho Active Member
    jeff
    I just got my truck back a few weeks ago.
    Took it in for an inspection (frame had about a 23mm round hole, other wise looked totally fine). Dealer sent paperwork off to Toyota. about a month later they called and said it was approved for a replacement. Brought the truck in 2 weeks later on Wednesday jan 23 first thing in the morning. They called back Friday morning and said it was ready to be picked up! FAST job! The one mechanic who does the frame replacements at this dealership said he has done about 23 so far. So he has it figured out. Labor got billed out for 41 hours.
    New frame, lower control arms, leaf springs, brake lines, nuts bolts and various hardware. I did notice the new frame also had plugs in all the holes and the two sections that are laminated together had pick sealant run along the seams.
    Did I mention the truck is a 2005 with rebuild status! :bananadance:
    bobsuruncle likes this.
  3. Feb 6, 2019 at 7:39 PM
    #3423
    bobsuruncle
    bobsuruncle PhD in voiding warranties
    Bob
    Fall City, WA
    06 TRD OR DCSB
    ARB bull bumper Warn XD9000 Icon 2.5 EXT Road Armor rear bumper Archive Garage shackle flip FJ/T4R tcase 4.30 gears Dirty5’s T4R rear axle swap w/disc brakes New frame from Toyota under EWP
    Wow, I thought it exempted trucks with a rebuilt title status? Either way, nice!
  4. Feb 6, 2019 at 7:52 PM
    #3424
    jepho
    jepho Active Member
    jeff
    Its supposed to, even the mechanic said. I guess they slipped it through some how.
    bobsuruncle[QUOTED] likes this.
  5. Feb 7, 2019 at 3:30 AM
    #3425
    DLillest
    DLillest Well-Known Member
    Quebec, Canada
    2007 SBM DCSB 6MT 4x4
    Has anyone had issues with sliders bolted/welded onto the frame? I assume this could potentially speed up the rusting process?
    I don't have them but I'm wondering for those that do.
  6. Feb 11, 2019 at 1:08 AM
    #3426
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Devil Horns by Andres, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers, Pop and Lock tailgate theft deterrent mod 2.0, Plasti-dip rear bumper. Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    And if Dana had washed the frames after welding and machining operations and not contaminated the rust proof dip it wouldn’t have been a problem.
    BigMau[QUOTED] and DLillest like this.
  7. Feb 11, 2019 at 5:02 AM
    #3427
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    My truck sits in a unheated garage. I agree it keeps it damp so rust has moisture and air to grow.
    But so does the wife’s suby.
    The truck rusts and the suby isn’t by any means close to what the trucks underneath did.
    My dealer doesn’t care if you bought it yesterday or if its salvage/rebuilt as long as it’s registered to you and qualified they will do it.
    Unsure about stuff welded to the frame?
    I think they will do it but it will return missing the welded on parts. They may charge to remove them for you if you choose.
    Don’t trust the dealer!
    Know what you have before you go.
    I found my fail, when showing the tech out in the parking lot he admitted it would had probably got missed.
    I’ve found holes on 3 trucks that were missed by the Toyota inspection.
    Even the tundras are getting new frames here.
    Pressure wash frame.
    I use an all to poke and stab.
    Take a lot of pictures I have a inspection scope also.
    The pics can be reviewed later to zoom in on spots hard to see.
    A phone can get some good pics in hard to see spots.
    Take a lot of pics!
    The ones of your thumb or forehead crack who knows what the hell that was of are easily deleted.
    cleats50 likes this.
  8. Feb 11, 2019 at 10:04 AM
    #3428
    bobsuruncle
    Bob
    Fall City, WA
    06 TRD OR DCSB
    I had sliders and a cab mount chop done to mine and it qualified. I didn't even close the cut portion of the cab mount back up.
    Jeffch[QUOTED] and DLillest like this.
  9. Feb 11, 2019 at 10:32 AM
    #3429
    DLillest
    Quebec, Canada
    I always wondered if they would void the frame replacement if you had the cab mount chop. I feel like that gives them leverage to say you modified/cut/drilled your frame which in turn accelerated the rust. (Not saying that it does).
  10. Feb 11, 2019 at 6:53 PM
    #3430
    cleats50
    cleats50 Well-Known Member
    chris
    Tacoma 2007 TRD
    air intake push bar running boards
    I had a similar expierence. The service manager said his techs could not find any holes so I showed him pics I took on my phone. I had a frame approved by corporate within 10 minutes and some meek looking techs lurking about. Even if you trust them don't trust them. A new frame is a big deal.
    Jeffch[QUOTED] and bobsuruncle like this.
  11. Feb 11, 2019 at 6:58 PM
    #3431
    cudason
    cudason Well-Known Member
    Vancouver
    TURD
    Eagle Alloy 050 series wheels. TRD fj shift knob Bilstein 5100 set @1.75 TRD CAI TRD seatcovers 2009 Taillights Xenon HID kit
    My 2005 just had its frame replaced last week.gotta day I was pretty pleased with the job the local Toyota did. I put all new bilstein 5100’s on and new 4Runner SR5 rims wrapped in KO2’s. Did the timing cover seal, water pump, serpentine belt, rear diff seal as well. The truck drives amazingly and was done in a week.
  12. Feb 13, 2019 at 8:36 PM
    #3432
    jepho
    jepho Active Member
    jeff
    Just curious... What dealership did you go to? I had a pretty good experience too and very fast turn around.
    I went to OpenRoad Toyota Port Moody
  13. Feb 17, 2019 at 2:26 PM
    #3433
    BigMau
    BigMau Member
    Lords Valley, Pennsylvania
    09 Tacoma SR5 4x4 2.4l
    Leer Cap
    Yeah.. Just wanted to crank them out and get paid$$$ Once the winter weather breaks up here in NE Pennsylvania, I gonna give the 17 Tacoma a good wash, wax and frame cleaning.
  14. Feb 18, 2019 at 2:27 PM
    #3434
    vwbuggsy
    vwbuggsy Well-Known Member
    Clinton, MD
    09 DC 4X4 LB Black Sand Pearl
    N-fab steps, Wet Okole Covers, line-x, tint, vent shades, budget stereo upgrades, weathertech floor liners
    Finally got the call that they are pulling my truck into the garage for the swap today. It's been there at the dealer since the first week of December.
    Man I miss my truck! Since then I've been in a Corolla for a month, a rav4 for a few days, and a third gen for a minute. My least fave for general driving has been the third gen truck actually but at least it's a truck.
    I brought them third gen uca's, front strut and coils assembled, and rear shocks. Hopefully they won't give me shit about using third gen parts for my second gen. I'm also hoping they replace the rear springs under the recent spring recall, I do qualify but hopefully they'll recognize that.
  15. Feb 18, 2019 at 2:59 PM
    #3435
    Fcelroy
    Fcelroy New Member
    2006 Tacoma
    I had mine done last year at this time. The dealer wanted to take my Taco in November until the new frame arrived. I asked if it was unsafe to drive? They checked it and said no. So I kept driving it until the new frame arrived.
    Because I had previously patched the oil pan, I had them replace it. They also recommended replacing all the power steering lines since it showed some sign of corrosion. When its all done and you're back on the road, make sure everything sounds and feels like it did before. They will be doing a lot of work on your pickup.
  16. Feb 18, 2019 at 3:04 PM
    #3436
    vwbuggsy
    Clinton, MD
    It's been too long... Not sure I remember how she felt :annoyed:
    But yeah I get what you're saying I'll look her over good.
    I'm going to wait and see what they recommend as far as extra work. I'm broke as hell right now so if it's not going to explode, I'm not trying to replace it right now.
  17. Feb 18, 2019 at 3:39 PM
    #3437
    sgage
    sgage Well-Known Member
    2007 Red Tacoma SR5
    I had my frame done last summer. I was in a loaner for 2 1/2 months, because my frame was about to crumble into dust and was not road-worthy - no way were they letting me keep it while waiting for the replacement. At least they gave me a brand-new Taco. Weird - too big and fancy for me. Didn't stop me from telling all my friends that it was my new truck! :)
  18. Feb 18, 2019 at 3:59 PM
    #3438
    vwbuggsy
    Clinton, MD
    I was happy to roll their loaners. I got to save a couple thousand miles of wear on mine. Better gas mileage for the most part, and I got to try several of their newer lines of vehicles. Sedan, SUV, and truck for an extended test drive. I admit I really like some of the electronic geegaws. I love radar assisted cruise control, heated seats, integrated blue tooth, and the power rear window on the new truck was awesome as is the bed light. I like the lines and stuff on the reverse camera though I can live without it.
    Most of that stuff I can add to my truck if i really want it, barring the radar unless I get really creative. I hate the lane departure stuff and was glad I could turn that off.
    I really hate the power delivery and shifting on the third gen. The driving feel is really odd. Maybe they did get more horse power out of the smaller motor but it feels like it's getting flogged pretty hard. The overall driving feel just isn't to my liking. Luckily the suspension felt fine because I'm putting third gen suspension stuff on my truck. I didn't really find anything much to complain of there, stiffer but also more connected so I'm okay with that. Wireless charger didn't work through my case very well.
    Lighted 4wd switch is a good thing but having it look like another cabin temp control and on the same panel is really stupid placement. I put her in 4w hi doing around 65 on pavement one night trying to turn the heat up, whoops!
    robssol likes this.
  19. Mar 12, 2019 at 5:10 AM
    #3439
    Lambert
    Lambert New Member
    Looking for assistance. I have a 2004 Tacoma that is completely rusted underneath and will not pass inspection. I did receive a recall notice several years ago (maybe more) concerning the frame rust and was told by the dealership that the frame was fine and did not need replaced. Now I feel that I was mislead. The truck is in very good condition otherwise. So my question is... am I screwed or do I have any recourse.
  20. Mar 12, 2019 at 6:01 AM
    #3440
    bobsuruncle
    Bob
    Fall City, WA
    06 TRD OR DCSB
    If it had the CRC applied, the frame warranty should be extended to 15yrs from "in service" date IIRC. If nothing was done then you're screwed. I'm not too familiar with the 1st Gen rust warranty so you may still have sent recourse.
