Frame rust recall
Discussion in '2nd Gen. Tacomas (2005-2015)' started by markey, Feb 14, 2013.
  1. Aug 12, 2015 at 10:41 AM
    #801
    cc350
    cc350 Retired Member
    So far getting water pump done at parts cost. But one thing bugging me is service rep. called and said front shocks must be replaced cause the top shock nut was seized? Why would they even take the struts apart? The struts should of been swapped over as an assembly in my thinking... Has anyone else had this happen?
  2. Aug 12, 2015 at 11:52 AM
    #802
    Kevin911sc
    Kevin911sc Member
    V1 hardwired and laser interceptor
    Dropped mine off today with mixed feelings... 202K on the original clutch and still going strong, it feels like a crime to bring in a truck in for what is essentially a frame off restoration when it is perfect minus a single hole that could be cut out and welded back to perfect.
    now if only I could find a source for the front left shock... I really wanted to move up to bilstein 4600's but the left front is backordered for the distant future.
    I guess ill let them do the clutch too... save my self a bunch of cursing
  3. Aug 12, 2015 at 2:58 PM
    #803
    eppy
    eppy Well-Known Member
    Rob
    Maryland
    05 V6 TRD OFFROAD
    Homer M3 thin lip Satoshi, BAMF Light Bar, BAMF Batwing Tie Downs, Coupe Custom Battery Hold Down, Mattgecko Bed light kit, nj636 hub/wheel bearing set-up,Shorty Antenna, JL Audio & Boston set-up, 4x4 switch light MOD, Icon 2.5 coil overs and rear shocks, All Pro flip kit, Wheelers AAL, OcTaco SS brake lines, Light Racing UCA's and custom 6 speed Ellis Precision Shift knob. Coupe modified short shifter, AISN clutch pack, URD TOB kit, and Sachs flywheel. Mobtown's rocking tailgate skin!
    Can someone explain the wire harness replacement :crazy: Is it the main wiring harness, or lighting harness etc.??? :rasta:
  4. Aug 12, 2015 at 3:54 PM
    #804
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    I'd tell them that it's not me that wants to change the shock out - THEY do - due to a defective parts recall. If they insisted in not supplying the parts - I'd tell them to put in in writing - tell them to PROOF read the memo real real good then send/call Toyota corp ASAP.
  5. Aug 12, 2015 at 6:09 PM
    #805
    R0dzilla75
    R0dzilla75 Well-Known Member
    Rodney
    Virginia
    05 Sport
    HID fog light 265-70-17 Firestone destination ATs Led interiors lights TRD seat covers
    Got my rig back today and all seems to be well. They greased and tighten bolt on the steering rack, put in a new fender liner and adjusted the hood. It looks and rides pretty damn good. I had just put 5100s all around a few months prior to dropping off for the frame so everything suspension wise is new. I will mention that they replaced all my fluids with exception to transmission, differentials and the engine oil. I did those when I got home minus the trans. Final bill was over 18 large. It's good to have her back in such great condition. This weekend I plan on cleaning the mass air flow sensor and the throttle body. Will also be installing my wet okoles. Things to do........so little time. They also fully evacuated and replaced all the freon which is another added bonus. Don't remember reading that anywhere else. They also replaced my dead battery with a brand new interstate at no charge. They hooked me up!
  6. Aug 13, 2015 at 5:29 AM
    #806
    Mad Man Marty
    Mad Man Marty Well-Known Member
    Marty
    PA
    2007 Tacoma SR5 TRD Sport
    6speed, TRD intake, bed tie downs, weathertech rear,Tint
    Hey rod,you should spend some time on your new frame to prevent or slow frame rust in the future.
  7. Aug 13, 2015 at 5:41 AM
    #807
    R0dzilla75
    Rodney
    Virginia
    05 Sport
    I've got 3 cans of fluid film that I plan to use on it. Today is mass air sensor and throttle body. If I have time I'll install my wet okoles. Then the frame coating. Good advice!
  8. Aug 13, 2015 at 5:46 AM
    #808
    Mad Man Marty
    Marty
    PA
    Follow up the fluid film with a Toyota frame plug kit.
    It will save most of the crap from going into the new frame.
    By the way,what r u going to coat the frame with?
  9. Aug 13, 2015 at 5:47 AM
    #809
    R0dzilla75
    Rodney
    Virginia
    05 Sport
    Never heard of this........elaborate please.
  10. Aug 13, 2015 at 6:37 AM
    #810
    Mad Man Marty
    Marty
    PA
    It's detailed in limited service campaign #173. You can find on this forum.
  11. Aug 13, 2015 at 7:08 AM
    #811
    R0dzilla75
    Rodney
    Virginia
    05 Sport
    According to the literature those holes are already sealed. I'll check it out today though.
  12. Aug 13, 2015 at 7:52 AM
    #812
    81shark
    81shark Well-Known Member
    that's solid. was the 18K for just the frame or did that include the rental? i'm not surprised by the freon considering they would have to disconnect the condenser.
    read somebody else got a battery too. i'm really hoping for that considering mine needs replacing. it'll be 10 years at thanksgiving.
  13. Aug 13, 2015 at 9:01 AM
    #813
    R0dzilla75
    Rodney
    Virginia
    05 Sport
    Not sure as this info was on the dealers paperwork not mine. So far so good though. How much longer do you have 81?
  14. Aug 13, 2015 at 10:57 AM
    #814
    danteisme
    danteisme Well-Known Member
    South Western PA
    06 DCSB Sport, 96 Integra GSR
    just got the word my frame is in for my standard cab, dropping it off on Monday.
  15. Aug 14, 2015 at 10:36 AM
    #815
    PSUnick
    PSUnick Lets Go State!
    MA
    2007 AC 4x4 Sport
    Hey Rodney did they turn your brake rotors/drums? I took mine for spin around the dealership parking lot and after only 1 month of sitting it had considerable vibration when braking from them rusting up. The pistons were also starting to lock up and made a nice clunk when they broke free.
  16. Aug 14, 2015 at 11:32 AM
    #816
    byrd
    byrd Unknown
    David
    Kansas
    '06 Access SR5 4x4 6 speed
    Got my frame inspected today, didn't pass. Told me 2~3 months before new frame will arrive, until then I still drive my beast.
  17. Aug 14, 2015 at 2:56 PM
    #817
    R0dzilla75
    Rodney
    Virginia
    05 Sport
    I doubt it but like I stated a few pages back my truck was driven every week for the last three months. I had recently install new drums in the rear and they were aftermarket and cause some vibration when braking. It's not so bad that I'm going to chuck them for oem just yet. The aftermarket ones must not be machined well. All in all I'm happy as a pig in shit with my truck. Have them address the issue with the brakes. If they balk go with corporate. If that fails have a lawyer send them a letter. That won't cost much, probably less than replacing your brakes and calipers.
  18. Aug 15, 2015 at 6:32 AM
    #818
    eppy
    Rob
    Maryland
    05 V6 TRD OFFROAD
    Anyone have there wiring harness replaced???? :brianr:
  19. Aug 15, 2015 at 1:08 PM
    #819
    bobsuruncle
    bobsuruncle PhD in voiding warranties
    Bob
    Fall City, WA
    06 TRD OR DCSB
    ARB bull bumper Warn XD9000 Icon 2.5 EXT Road Armor rear bumper Archive Garage shackle flip FJ/T4R tcase 4.30 gears Dirty5’s T4R rear axle swap w/disc brakes New frame from Toyota under EWP
    Just picked mine up from inspection. No replacement needed.
  20. Aug 15, 2015 at 2:39 PM
    #820
    eppy
    Rob
    Maryland
    05 V6 TRD OFFROAD
    You have the Whole frame replacement??? Dealer stated they need to change out the harness, so will follow up and inform Monday. :tumbleweed:
