Frame rust recall
Discussion in '2nd Gen. Tacomas (2005-2015)' started by markey, Feb 14, 2013.
  1. Oct 25, 2015 at 4:13 AM
    #1201
    johneman
    johneman Life is good relaxin' on the porch!!
    Ken
    Warwick,Bucks PA
    2021 TRD OR Magnetic Gray
    Go Rhino Dominator D1 step, Extang Encore Tonneau.
    :wave:Took mine in for the same reason (had 5 recalls needing to be done) and the airbag light was on. When I picked it up, I got about 2 miles from the dealer when my light came on again. Back to the dealer and left the truck, with them giving me a loaner for 2 days because they had to order another spiral cable. So far all is good and it's been about a month or so. Just waiting to get the call on the new frame.
  2. Oct 26, 2015 at 7:02 AM
    #1202
    Mad Man Marty
    Mad Man Marty Well-Known Member
    Marty
    PA
    2007 Tacoma SR5 TRD Sport
    6speed, TRD intake, bed tie downs, weathertech rear,Tint
    You should not be charged labor by the dealer to replace any part that must be removed from the old frame & installed on the new frame.
    You will be charged a possible reduced labor charge to replace a item like the timing cover.
    Since the engine is already out of the frame,& other items are out of the way it makes it easier & faster to replace items.
    I hope that helps,& yes I've had my frame replaced.
    a.s. likes this.
  3. Oct 30, 2015 at 1:28 PM
    #1203
    TACOMAst
    TACOMAst Member
    David
    Columbus, OH
    06 SR5 4WD
    None yet...
    They just called and have my truck completed already! Just over 1 week. No charge. Said spiral cable is fine, messed with connections under driver's seat and reset the indicator light. Said if it goes off again they'd have to replace the seat sensor or connector assembly under the seat. Not so sure that it won't just need another spiral cable though. Guess time will tell. Will post again after driving my Taco for a week or so.
  4. Oct 30, 2015 at 6:24 PM
    #1204
    Fitz235
    Fitz235 Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
    I agree with Janster. It sounds like either that dealer is giving you a major hookup, or they don't have a firm understanding on the work being requested. My dealer has been great, but even those guys told me they were going to charge me $300 to assemble my coil/strut assembly if I brought everything in individually. And they wouldn't even consider installing an AAL. I brought my coil/strut assembly into them assembled, and they didn't charge for that, because that was the same amount of work for them. I would think the AAL for most dealers is a liability issue, especially in light of all the leaf spring issues. Beyond that, I would imagine that would be a good 1.5 - 2 hours of extra labor.
  5. Oct 31, 2015 at 6:49 AM
    #1205
    a.s.
    a.s. Well-Known Member
    Stack
    NY
    Silver '07 DCSB Sport
    KO2s/5100s/Eibachs/TRD
    I hear ya. They've been replacing frames for months so they are either lying (totally possible) or they explained it correctly. I do plan to have my shocks pre-assembled and ready to put on. I'm getting new leaf springs- or at least that's what I was told. Installing an AAL should not take long at all. Some dealers will and some won't. Hopefully mine will (not sure I mentioned that to him?).
    This stuff I'm not concerned with. Its the "other" bits and pieces. I'm not sure what the dealer should be replacing as part of the frame recall. What will they try to get me to pay for that I should absolutely not have to?
  6. Oct 31, 2015 at 7:31 AM
    #1206
    Fitz235
    Rob
    New Hampshire
    Really you shouldn't have to pay for anything. Many dealers will give you the option to replace things that will be easily accessed, or being disassembled anyway, at either a reduced rate, or for free.
    The short (unofficial) list (beside frame itself) is rear leafs, lower control arms, brake lines, wiring harness. And a bunch of smaller things like engine splash guards, clips, etc.
  7. Nov 1, 2015 at 4:39 PM
    #1207
    coryip
    coryip Active Member
    WNY
    05 Silver AC
    I just recently got my 05 back from the dealership and I have to say I'm not impressed. I dropped my truck at the dealership in Batavia, NY and the following morning received a call saying my truck needs over $4000 worth of repairs. I lost my shit. Service manager then stated that these are only suggestions, I declined and said to let me know when truck was completed. 5 days later I received a call saying they can't finish my truck unless I buy 2 new calipers $500+ because the bleed screws were seized and would break if they try to bleed the brakes. I was not pleased and said do what you got to do to get my truck back together. After thinking that over i decided to call customer care and explain my frustration. I feel that i brought them a running driveable truck and expect to receive the same back, they are the ones wanting to replace the frame and should absorb any expense to make that happen. I ended up agreeing to pay 25% of the cost of 2 calipers.
    7 days in I get the call that its ready and go to pick it up. I drive off and when I get to about 35-40mph I get a terrible noise from the front. After pulling into the local walmart i see that both front inner fender wells were not clipped in and rubbing the tires and put a hole in the right side one. I drove back and they put the necessary hardware on. I would think they would at least drive the truck down the road and give it a good look before calling the job complete. After driving the truck a few more days i then notice the front right federwell is covered in grease and found that to be the cv boot sliced open. Possibly from the plastic fenderwell getting sucked back into it. Back to the dealership and they said they will order part and take care of it but I haven't heard anything from them in over a week. Other issues I have noticed is a terrible vibration at 40-50mph under acceleration and braking. Rear mudflap not secured to truck with the 3 push pins that are used to help keep it tight to body. I know that was not that way because just a few months ago i replaced one flap and put new pins in all 4 flaps. Another thing I have noticed is the gas cap no longer has the keeper that keeps it attached to the truck. This seems like such a small detail but I have noticed when getting gas I now have to try to not lose the cap that I'm holding in my hand. Now steering has some slop to it that wasn't there before.
    My truck wasn't perfect when I dropped it off but It has always impressed me with how tight and how well it drove for a truck thats 10 years old and 120k miles. I no longer feel that way when I jump in the truck but now notice all the shit that they screwed up. I still feel that toyota makes an excellent truck but feel they made a mistake thinking they could tear it apart and get it back together and expect it to drive the same. I still don't understand how dumping $12K-15k makes more sense than offering an option to upgrade to either a new tacoma or tundra.
  8. Nov 1, 2015 at 8:07 PM
    #1208
    Dan Brown
    Dan Brown Tacoma Problems
    Dan
    Northeast
    2005 Tacoma Access Cab
    Anyone else on the hook for $ they didn't expect to pay? All I want is the frame swapped out - instead I'm getting quoted $5380 for parts that the dealership is saying will need to be replaced as they'll be damaged in the rebuild. I've been going back and forth with Toyota for 2 weeks to no avail. Finally decided to put it all together in the hopes that those searching the internet for a solution see that its not exactly an easy fix. >> http://tacomaproblems.com
    PSUnick likes this.
  9. Nov 1, 2015 at 8:27 PM
    #1209
    TXTaco13
    TXTaco13 Taco/T4R Enthusiast
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
    What parts are they saying are bad?
  10. Nov 1, 2015 at 8:32 PM
    #1210
    Dan Brown
    Dan
    Northeast
    Full list at the website tacomaproblems.com but they've pretty said that they're not sure what they can take off and not damage. As a result, they're quoting a little over 5K in parts that aren't covered in the recall. Way more than I can afford at this time and it seems Im at the point where I either accept the cost or they give me the truck back as-is.
  11. Nov 2, 2015 at 2:35 AM
    #1211
    Charlot
    Charlot Well-Known Member
    Ontario, Canada
    Tacoma TRD 2018 Upgraded
    Man,i can t beleive that these Dealers are making you pay.
    I had my frame changed last February,and i didnt have to pay one penny.
    The only part that i paid was my muffler which had a whole in it,and they gave me a great deal on that muffler which was brand new ,but belonged to a guy that had dual exhaust installed on his new truck.
    So i paid close to half price of what they usually are.
    I feel sorry for these guys that have bad experiences like them.
    I also never had to go back,for any issue.
    All the best
    Charly
  12. Nov 2, 2015 at 2:51 AM
    #1212
    coryip
    WNY
    05 Silver AC
    They had the same approach with mine saying some parts may not be reused. Tranny lines power steering lines supposedly some crack in my exhaust that was going to break when removing. The exhaust alone was going to be over $1200.
    All that was in the $4000 quote and they managed to get it all put back together. But after driving it who knows how well they did. With the issues I have had it makes me wonder what else underneath the truck that I'm not seeing was half assed.
    LuvTacos likes this.
  13. Nov 2, 2015 at 4:11 AM
    #1213
    rcsb jon
    rcsb jon Well-Known Member
    Pittsburgh
    '17 Ridgeline RTL-T | AWD | White | Ebony
    -WeatherTech liners
    Meanwhile they got the muffler for free... because the guy said, "just throw it away"
  14. Nov 2, 2015 at 4:52 AM
    #1214
    tkbentzin
    tkbentzin Member
    Tyler
    I'm currently in the process of getting a new frame on my 2005 tacoma, they said the frame is in and will get it in this week. After reading this thread I'm nervous about taking it in lol. My truck drives awesome right now.
    Best of luck to you guys
  15. Nov 2, 2015 at 6:13 AM
    #1215
    Dianna
    Dianna Well-Known Member
    Dianna
    Ohio
    -06 Tacoma Sport -77 FJ40 -14 4Runner Trail Premium -19 Tacoma TRD Sport Cement Gray
    Dan Brown, I see on the list of parts needed that one of the most expensive items they say you need is a catalytic converter, is there something wrong with one of your cats?
    Another part needed is an exhaust, buy a TRD for under 300 bucks. You get the cool TRD stainless tip and a cool sound :)
    Or, many members here give away their exhaust after they upgrade. I have a spare I'd be happy to give it to you if you were closer.
    And that dealership is raping you on parts prices. http://trdtoyotaparts.elmoretoyota.com/oe-toyota/174100c100. You were quoted $1922.22, buy it here for $1,281.48.
  16. Nov 2, 2015 at 6:33 AM
    #1216
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    I think we all got zapped with this. Plus all the parts they removed now will have problems. If you slide cv out of the seal it will pretty much screwed up your seal so now you get leaking front diff. Now I have to ask them to fix this or fix it myself (which is pretty much what will happen because they will not cover)
    Its crazy.
  17. Nov 2, 2015 at 7:25 AM
    #1217
    Mad Man Marty
    Marty
    PA
    All these problems are due to the dealer.
  18. Nov 2, 2015 at 7:36 AM
    #1218
    Stuligan
    Stuligan Well-Known Member
    Ontario, Canada
    05 TRD OR 4L V6 6spd
    Billy 5100 level lift (0.85" front) White/Amber DRL/Signal Kit GTA Car kit for AUX/IPod Satoshi Grill 2x 20" LED Light bars behind grill HID headlights LED Taillgihts LED interior lights.
    Got my truck back in August, just haven't been on TW lately. Truck feels brand new, best it's felt since I've owned it. Only expense I paid for was a new steering rack. Normally I do eveything myself, but in this case it was just so much easier for them to do it rather than when it was put back together. I'm very happy with how it turned out, shouldn't have taken 11 months for them to start on it after the inspection, but now that it's done I'm happy.
    Along with the steering rack they had several other "recommended" fixes, but I told them to just do the work covered by the recall and I'd do the rest myself. (Stuff like wheel bearings and brakes). And they were fine with that.
    Like I said, happy with the truck that I recieved back. Any issues that I've found in the past few months have been fixed right away by the dealer without any fuss. And haven't been major things.
  19. Nov 2, 2015 at 8:00 AM
    #1219
    LuvTacos
    LuvTacos Well-Known Member
    That really sucks. If it were me, I'd dump the truck and kiss Toyota goodbye. With this and the 4.0 piston slap Toyota doesn't want to fix, it's obvious the quality rep Toyota used to have ain't there. Don't be a "fan boy" to any make, reputations change, time to try something new.
  20. Nov 2, 2015 at 8:29 AM
    #1220
    81shark
    81shark Well-Known Member
    PSUnick likes this.
