Frame rust recall
Discussion in '2nd Gen. Tacomas (2005-2015)' started by markey, Feb 14, 2013.
  1. Nov 5, 2015 at 9:55 AM
    #1281
    tgear.shead
    tgear.shead Well-Known Member
    There *IS NO* two and two to put together. You are making invalid assumptions.
  2. Nov 5, 2015 at 10:02 AM
    #1282
    tgear.shead
    That is quite funny. And completely incorrect.
    The warranty only tells you what they ARE obligated to do, like replace the frame if it rusts through in LESS than 3 years 36000 (miles?). It does NOT say what they DON'T have to do, like replace a frame that rusts through in 8 years due to negligence.
    If you imagine that the owners manual will specify every single possibly maintenance item for every possible climate, then you are imagining an owners manual that is large enough that everybody who buys one of these trucks will have to also buy a warehouse to store the manual in. I wonder if it should also include the maintenance requirements for the warehouse that you use to store the manual? Do you think that the roof should be replaced every 5 years? Or 10? God forbid it starts leaking in 9 years, it might ruin your manual and you won't know how often to spray oil on your frame.
  3. Nov 5, 2015 at 10:04 AM
    #1283
    a.s.
    a.s. Well-Known Member
    Stack
    NY
    Silver '07 DCSB Sport
    KO2s/5100s/Eibachs/TRD
    Okay you're all a bunch of freaking experts. We get it. So how about those Mets.:lalala:
  4. Nov 5, 2015 at 10:45 AM
    #1284
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    You lost me there... What are you trying to argue...?
    Frame is 3/36 000 warranty and it lasts 3/36000 with out any maintenance. So Toyota does not have to put any maintenance interval on the frame. And I a mnot claiming they have to.
    But if frame supposed to last more than 5 years they should have put maintenance on it. Legally however, as of now, lack of maintenance for frame is not an issue because it will last 3/36 000 beyond which, Toyota is not responsible for frame.
    Thats why, IMHO for 2009+ folks if they have to go after Toyota, they should probably claim deceptive and unfair business practice. "You were convinced by Toyota representatives (salesman, dealer, Internet posts etc) that Toyota vehicle quality will make it last 8- 10 years which was not true"
    Maybe grab all Toyota employee posts saying frame issue is not a problem anymore and use that as exhibit of deceptive tactics. :notsure:
  5. Nov 5, 2015 at 11:24 AM
    #1285
    BlueT
    NorthEast
    Now one more thing.
    For those that think they have extended warranty and they covered... well bad news. Frame rust is explicitly not covered...
    Clever.... isn't :rolleyes:
  6. Nov 5, 2015 at 1:22 PM
    #1286
    TXTaco13
    TXTaco13 Taco/T4R Enthusiast
    Dallas, Texas
    4TH GEN V8 4X4 T4R
    '83 CJ7 '19 MT 07
  7. Nov 5, 2015 at 2:38 PM
    #1287
    81shark
    81shark Well-Known Member
    got some exciting news.... but i don't want to share quite yet.... once the letter arrives... holy snikies
  8. Nov 5, 2015 at 3:44 PM
    #1288
    BlueT
    NorthEast
    :evil:
    Mets will be Champions ?
    :popcorn:
  9. Nov 5, 2015 at 3:45 PM
    #1289
    tkbentzin
    tkbentzin Member
    Tyler
  10. Nov 5, 2015 at 3:46 PM
    #1290
    tkbentzin
    tkbentzin Member
    Tyler
    Just got my truck back. Took it in yesterday morning and got it back tonight. We will see how it drives
  11. Nov 5, 2015 at 4:18 PM
    #1291
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    Pray Tell ?? Perhaps the Bill for the rental ?? :gossip:
  12. Nov 5, 2015 at 4:34 PM
    #1292
    Markcal
    Markcal Well-Known Member
    I went under my Tacoma this weekend to change the oil and lube the chassis. I noticed one of the drain holes under the chassis, where a drain plug added wasn't seated right and it looked like there were bubbling of the CRC around it. I removed the drain plug and found that they used a round plug for a rectangular holes, which didn't fit properly, looking like it was forced into the hole with the wrong plug. It was wet around the hole and the CRC coating around it came off easily, was wet with rust. The other drain plug on the other side looked good, without any CRC bubbling and was seated correctly. I wondered if there should be a drain plug there or if not being seated correctly caused the water to collect around the hole. I wonder if water is collecting in the holes and if they didn't add those plugs, the water would drain properly, so it doesn't stagnate, causing more corrosion.
  13. Nov 5, 2015 at 4:35 PM
    #1293
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
    Toyota's changed their minds, no more frame replacements, now they're going to buy back at 175% of blue book?
    :fingerscrossed:
  14. Nov 5, 2015 at 8:27 PM
    #1294
    JeffreyB
    JeffreyB Well-Known Member
    Jeff
    2015 Access Cab 2.7 5 Speed 4X4
  15. Nov 5, 2015 at 8:30 PM
    #1295
    Tacobajasr5
    Tacobajasr5 Well-Known Member
    AB
    10 Taco sr5/325ci Turbo/98pathfinder righthand
    Black rhino 17" with Tko
    Is this true and if so can you explain what this means? lol...
  16. Nov 5, 2015 at 8:33 PM
    #1296
    JeffreyB
    Jeff
    No, that is what he is hoping the news is. Toyota had a buy back program for certain years with rusted out frames where they paid 150% of blue book value in excellent condition.
    Tacobajasr5[QUOTED] likes this.
  17. Nov 5, 2015 at 10:53 PM
    #1297
    fredgoodsell
    Salt Lake, UT
    2017 DC TRD OR
    ^this. Just wishful thinking! Not going to happen. Besides, my replacement frame is already on the way...
  18. Nov 5, 2015 at 10:59 PM
    #1298
    JeffreyB
    Jeff
    Can't imagine what it could be with him just getting his truck back with a new frame... Maybe a sorry we had it so long check.
  19. Nov 6, 2015 at 5:21 AM
    #1299
    a.s.
    Stack
    NY
    You had a frame swap done in 24 hours?!?
  20. Nov 6, 2015 at 5:34 AM
    #1300
    Markcal
    Did you ever get the set of struts and shocks for free, after asking Danica?
