Frame rust recall
Discussion in '2nd Gen. Tacomas (2005-2015)' started by markey, Feb 14, 2013.
  1. Dec 15, 2015 at 6:57 AM
    #1481
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    You still dont have a truck ?
  2. Dec 15, 2015 at 9:04 AM
    #1482
    epfatboy
    epfatboy Member
    Eric
    Looking to buy one
    None yet but will do small lift
    So what about 2009-up? Do they have a similar problem?
  3. Dec 15, 2015 at 9:10 AM
    #1483
    tgear.shead
    tgear.shead Well-Known Member
    No. New frame from new manufacturer.
  4. Dec 15, 2015 at 10:41 AM
    #1484
    81shark
    81shark Well-Known Member
    It's back in the garage. 8.3 months. 3 dealer trips post pickup for little shit and one seal.
  5. Dec 15, 2015 at 10:44 AM
    #1485
    rcsb jon
    rcsb jon Well-Known Member
    Pittsburgh
    '17 Ridgeline RTL-T | AWD | White | Ebony
    -WeatherTech liners
    Did anyone try to trade in at the dealer, when they failed it? Get a new vehicle... let them deal with the frame nonsense, broken parts, technician negligence, etc...
    No reason value should be changed... if they do such good work, it's a new frame, well worth it for them.
    george101 likes this.
  6. Dec 15, 2015 at 10:54 AM
    #1486
    tgear.shead
    While a valid point, it might be against the rules that Toyota has laid out for the frame swaps. Strictly speaking from a theoretical point of view, of course, since I have no reference to their rules.
    My expectation is that if there was some consistent allowance for trade-in of rotted frame vehicles, there might end up being a glut of used vehicles on the market, OR, they might not be able to keep up with the demand for new ones, blocking new truck buyers from getting them in a reasonable time.
    From Toyota's point of view, I think it is probably most efficient to fix the truck first, and then allow a trade-in once there is less incentive.
    On top of that, if you consider the age of the vehicle -- 2005-2008 is 7-10 years old now. Those are getting up there in age and might be starting to go bad mechanically or in the body shortly, which could mean that they will start being replaced via crushers shortly anyway, regardless of their having a new frame. That means keeping the assembly lines working at a more normal rate and spreading out new truck purchases in a more natural manner.
  7. Dec 15, 2015 at 10:57 AM
    #1487
    rcsb jon
    Pittsburgh
    -WeatherTech liners
    If they devalue the truck, based on their junk frames, then they really don't stand behind their products or service
  8. Dec 15, 2015 at 11:42 AM
    #1488
    BlueT
    NorthEast
    Most likely, since its the same people and the same process. Metalsa bought Dana frame manufacturing. So its not like this is totally different company making frames. 2009 is just makign around 6 year mark, so complete failures should start after that winter.
    Where are I am 2009 frames look as bad as others. so be prepared that 2009+ will end up wit hthe same issue. Also since there is no longer Dana to cover the cost, if your frame fails on 2009+ you are on the hook for it.
    It costed Toyota $13K to swap my frame. I doubt you will be willing to spend that much on the frame.
  9. Dec 15, 2015 at 11:58 AM
    #1489
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Dan
    21' Tundra Platinum & 08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    I had Toyota send me a new letter. Got it last week. No mention of the CRC campaign in the letter. Mine simply states they will inspect the frame, if perforation is found they will determine an appropriate remedy...this makes no sense to me, apparently the salt Utah uses is less corrosive than in the other areas they are coating the frames...(shrugs shoulders). I still plan to have mine inspected, and will then coat it myself in the spring so I know it is done right...wasn't sure I wanted Toyota's CRC applied anyway after seeing some of the sloppy jobs done on other members trucks in this thread.
  10. Dec 15, 2015 at 12:00 PM
    #1490
    BlueT
    NorthEast
    Wow 8 months that is flat out crazy, You would think ater that long truck is perfect / better than new.
  11. Dec 15, 2015 at 12:00 PM
    #1491
    BlueT
    NorthEast
    Whats the deadline in your letter ? IS it March next year too ?
  12. Dec 15, 2015 at 12:06 PM
    #1492
    08TRDOFFROAD
    Dan
    Yeah, March 31, 2016, IIRC.
  13. Dec 15, 2015 at 12:13 PM
    #1493
    BlueT
    NorthEast
    Hmm so they did not bother extending that... Interesting. Thats 3 months away.
    I think few dealers did that, but I think in general Truck had to have a owner to be eligible for frame swap.
  14. Dec 15, 2015 at 12:19 PM
    #1494
    08TRDOFFROAD
    Dan
    Yep, I plan to take mine in the first week of March, we are usually through the worst of our winter, road salt season by then.
  15. Dec 16, 2015 at 7:04 AM
    #1495
    Beaglesridefree
    Beaglesridefree Well-Known Member
    2018 Tacoma DBL cab 4x4 TRD Sport, Premium and Tech Pkgs
    I am considering this option since dealer #1 wants $200 to install new shocks and coilovers. (also wanted $800 for front 5100's with Eibachs, parts only)
  16. Dec 16, 2015 at 10:39 AM
    #1496
    a.s.
    a.s. Well-Known Member
    Stack
    NY
    Silver '07 DCSB Sport
    KO2s/5100s/Eibachs/TRD
    Got the call. Dropping my truck off in 30 minutes Let the games begin...
  17. Dec 16, 2015 at 11:34 AM
    #1497
    BlueT
    NorthEast
    Take pictures around the truck before you drop off. I realized I should have done it.... just to remeber which digs were mine which ones are new.
  18. Dec 16, 2015 at 7:15 PM
    #1498
    MG06tacoma
    MG06tacoma Well-Known Member
    PA
    06 4x4 Base
    My truck has been back at the dealership since yesterday. After the issue with the unsecured coolant hose, the check engine light lit up and stayed on. Today they called and said that for some reason the fuel filler neck area has a crack and is generating a code, so since the truck didn't have that problem when I brought it in, they are taking care of it free of charge...
  19. Dec 17, 2015 at 5:58 AM
    #1499
    a.s.
    Stack
    NY
    I have it all in my head. Been contemplating this moment for a few months and was ready when I brought the truck in. Gave them new shocks and other bits with clear instruction. We'll see what extras they try to hit me up for. They gave me a crapolla, which I already HATE. Almost ripped the front bumper off getting up my steep driveway. o_O
  20. Dec 17, 2015 at 8:51 AM
    #1500
    johneman
    johneman Life is good relaxin' on the porch!!
    Ken
    Warwick,Bucks PA
    2021 TRD OR Magnetic Gray
    Go Rhino Dominator D1 step, Extang Encore Tonneau.
    Just picked my Tacoma up from the dealership. They did the frame replacement and a new clutch in 3 days. Drove it home with no problems. Will look it over real good when the rain stops. The service writer told me they give a one year unlimited mileage warranty on all their work (just as long as you can prove they are responsible:confused::rolleyes:).
