Frame rust recall
Discussion in '2nd Gen. Tacomas (2005-2015)' started by markey, Feb 14, 2013.
  1. Feb 9, 2016 at 2:24 PM
    #1961
    PSUnick
    PSUnick Lets Go State!
    MA
    2007 AC 4x4 Sport
    My dealership service manager told me flat out they prefer to change the frames. It pays more hours and is more money for the dealership. I had two 'unofficial' inspections before mine finally failed.
  2. Feb 9, 2016 at 4:58 PM
    #1962
    L J
    L J Well-Known Member
    Illinois
    07 4X4 SR5 TRD Sport DCLB
    I visited my truck Monday. I miss the old girl and it's only been a week. Was told it would likely be done mid April.
  3. Feb 9, 2016 at 6:04 PM
    #1963
    Redtaco704
    Redtaco704 Well-Known Member
    Jon
    Charlotte, NC
    05 DCSB 4x4
    Bilstein 5100's all around, Pro-Comp AAL, Pioneer in Dash DVD, Image Dynamics Component speakers, Custom 10" sub enclosure
    Service manager at Scott Clark Toyota in Charlotte told me parts should be here by the end of the week. We shall see I guess.
  4. Feb 9, 2016 at 6:57 PM
    #1964
    BlackTaco1014
    BlackTaco1014 Well-Known Member
    What's the deal if you have weld on sliders? Will they still replace or is that a nono?
  5. Feb 9, 2016 at 7:00 PM
    #1965
    nettereo16
    nettereo16 Active Member
    Durham, NC
    06 TRD Sport AC
    @Redtaco704
    How long you been waiting??
    Dropped mine off last week and they said minimum 4 months. Up in VA btw.
  6. Feb 10, 2016 at 12:10 AM
    #1966
    luka
    luka Well-Known Member
    Kailua, HI
    Prerunner -> 4WD Converted
    Pelfreybilt, Warn, BAMF, DTRL toggle on/off, FJ OEM Fog/Aux Light switches, 2012 lower center console swap, wired in auto-dimming rear view mirror, Wet-Okole inside, Weathertech , Rigid, Tint, Roto-Pax, Bestop, OME, Extended SS brake lines, TRD TX Pro/Baja Graphite 16" Rims
    thanks, all I can do is sit and wait...its been a decent deployment though. it'll be nice to come back and be able to take a hot shower without wearing sandels lol
    in Hawaii, all of the Toyota dealerships are under the same umbrella company Servco, and they are not part of Toyota USA...so my gf called the dealership closer to her house and talked to the scheduler that schedules for all the locations.
    my job is metal fabrication...welding, machining, anything and everything metal...and I can bet my paycheck that if I were given the inspection criteria, it would fail.
    a Lawyer is definitely an option...hopefully I hear back later this week.
    Beaglesridefree likes this.
  7. Feb 10, 2016 at 6:19 AM
    #1967
    cynicalrider
    cynicalrider #NFG
    Jersey
    They will, they can cut them off or you can. I opted to cut mine off so i can have enough material to weld back on with. Worried they would fuck it up.
  8. Feb 10, 2016 at 10:08 AM
    #1968
    BlackTaco1014
    Awesome to hear, was worried about that, hope my frame rots threw in the next month haha!
  9. Feb 10, 2016 at 11:55 AM
    #1969
    Redtaco704
    Jon
    Charlotte, NC
    05 DCSB 4x4
    Dropped it off on Monday. I feel like I might be waiting longer than two weeks.
  10. Feb 11, 2016 at 4:17 PM
    #1970
    tinker2
    tinker2 Well-Known Member
    East Of The Big River
    Really nothing to look for, a few $'s each I wish I would have thought to have them changed. When they did my frame the steering knuckles/spindles had to come off, they were right there. It would have just taken a few minutes to change each one.
  11. Feb 11, 2016 at 5:49 PM
    #1971
    L J
    Illinois
    That's a really good idea. If the seal is new the bearings look to be a pretty easy job. Now I need to add seals to the parts list but I can wait on the bearing assemblies. Went to the dealer to get something different to drive. Just didn't like the Highlander and I needed a hitch. Really lucked out . They put me in a 4runner limited. Now I want heated leather seats and a sunroof for my truck.
  12. Feb 11, 2016 at 6:28 PM
    #1972
    tinker2
    Yep, then if you have a wheel bearing go bad a few months later the inner seal shouldn't need to be changed. Just change out the hub assembly and roll.
  13. Feb 11, 2016 at 6:39 PM
    #1973
    L J
    Illinois
    I'm a little skeptical though. Seems like the bad bearing might allow enough play to eat the seal. May do it anyway because the seals are pretty cheap. Thanks for the idea either way.
  14. Feb 12, 2016 at 7:18 PM
    #1974
    Nimble9
    Nimble9 visit squareonecreations.com Vendor
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    Just thought I'd share my expirience with the frame swap. I just recently bought a 06 4x4 DCSB. I test drove it and thought it drove great, minus the wheel bearing they had to replace. I was then informed they've had the truck since June 2015 and the dealer's son has been driving it while waiting for the new frame. Well a week later, the frame arrived, they started the swap on Monday 2/8 and I picked it up 2/10. I can't believe how many parts were new when I crawled underneath!
    New frame, new brake lines, new TSB rear leaf springs, and new wheel bearing was what I was told would be installed.
    I found that I had what looked like new rear shocks, new LCA's, new front sway bar, and more.
    Pardon the white salt in the pics, that's after 2 days of driving here in PA.
  15. Feb 13, 2016 at 6:27 PM
    #1975
    KitCarson
    KitCarson New Member
    05 Taco PreRunner Crew Cab Red
    Am I the only one who is frustrated that the dealer looked under my truck and says it passed the inspection and does not need a new frame, or to even be sprayed...? :(
    I was kinda hoping for all the new parts on my old 2005 crew cab PreRunner with 178k miles.
    Especially was hoping to get the TSB springs seeing as mine are bout bent flat, nearly looking like they are upside down.
    I honestly can't remember where my truck originally hailed from, as I am the 3rd owner, but it is now a FL truck and sees plenty of sea salt... just apparently not enough for them to do anything for me.
  16. Feb 13, 2016 at 6:40 PM
    #1976
    dean3324
    dean3324 Member
    2005 access cab
    I hope you didn't sign off on anything per the paperwork I got they are either doing a frame swap or coating them. Where abouts are you from??
  17. Feb 13, 2016 at 10:12 PM
    #1977
    KitCarson
    Mayport (north east) Florida.
  18. Feb 14, 2016 at 3:22 AM
    #1978
    L J
    Illinois
    You're facing a real uphill battle if your truck is registered in Florida. Not saying you don't have a rusty frame but I don't think Florida is one of the states included in the LSC. You may be able to join a class action lawsuit. Did you get the safety recall letter for the leaf springs?image.jpg
  19. Feb 14, 2016 at 10:35 AM
    #1979
    themanbornwithin
    themanbornwithin Active Member
    NJ
    05 Tacoma DCLB TRD Sport
    Dropped my 05 DCLB off yesterday for the recall. Got a call 2 hours later saying I could pick the truck up, the frame failed and they need to order a new one. ETA is 1-4 months. They said they will replace the leaf springs when they transfer the frame.
    From the sides, it didn't look bad to me. But in December when I was installing a backup camera, I reached underneath to pull myself under the truck and a chunk came off. Figured I'd be getting a new frame.
  20. Feb 14, 2016 at 10:51 AM
    #1980
    L J
    Illinois
    So I was reading a different thread about the leaf spring recall and the part numbers for the replacement spring kits were posted in it. They do not match the part numbers for the new springs being installed with the frame replacement that are posted in this thread. Does anyone know if the springs included in the frame replacement are the same as the recall springs?
