frame rust
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jeremy175, May 15, 2012.
  1. May 15, 2012 at 8:12 PM
    Jeremy175
    Jeremy175 [OP] Member
    Jeremy
    South MS
    TRD Sport
    I recently acquired a 2000 Toyota Tacoma and upon further inspection, I have found rust holes in the frame. I understand Toyota has a frame rust recall or something on 95-04 Tacoma. Any info or guidance on getting this fixed through Toyota would be appreciated.
  2. May 15, 2012 at 8:15 PM
    precoma
    precoma Well-Known Member
    Corey
    Lake Arrowhead, CA
    2009 4x4 trd sport
    Total Chaos 3.5 Long travel, Defined SUA
    from what i have read you just take it into the dealer and tell them you want the frame rust inspection and they beat the shit out of the frame with hammers intell it crumbles or stays solid if its good they re paint and coat it and if it crumbles they replace it
  3. May 16, 2012 at 7:05 AM
    FishinTaco
    FishinTaco Well-Known Member
    D'Arcy
    Sudbury, ON
    TRD 4x4 5spd
    5100's all the way around, OME 880's and AAL, BF's 265/75R16. Switched beds from Stepside to Fleetside
    Jeremy, there is lots of info on here about it, have a search around.
    Call Toyota with your VIN to see if it has been checked yet, there is also a website for it. If it has, you are likely eligible for the extended 15yr frame warrantee. Years 1995.5 to 2000 were bought back by Toyota at 1.5x KBB. If it is a 2001 to 2004 they will re-frame it at their cost.
    If the truck has not previously been checked and/or undercoated, you are out of luck as the time to get your truck in has elapsed and the 15yrs extended frame warrantee does not apply. Their are some folks on here that are in the same boat as you and are contesting their cases. If I were you I would have a chat with them.
    I've been through both the buy back and the re-frame.
    Cheers,
  4. May 16, 2012 at 9:04 AM
    Jeremy175
    Jeremy
    South MS
    TRD Sport
    I seriously doubt this truck has been inspected. I hope it makes a difference that I just got the truck about a month ago.
  5. May 16, 2012 at 9:22 AM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    33's,armor,crawler,dents, ect
    OME lift CBI sliders, front bumper homemade rear bumper 33x12.50 m/t Gears Aussie locker inchworm crawlbox Homemade flat belly
    IIRC a truck purchased after the recall was annoced you would any get what you paid for it back. Thats IF its still under the 15 years which a 2000 should be. Call toyota sucks to lose your truck so soon after buying it.:(
  6. May 16, 2012 at 12:05 PM
    sportsterchop200
    sportsterchop200 Well-Known Member
    NE Georgia
    03 TRD Tacoma 4x4
    OME 881, Bilstein 5100 @ 0", OME 10mm JK spacer, Stock rear on 265/70-16
    I purchased an 03 less than a year ago that came from Ohio. I live in Florida. I found out about this issue after the fact and took it back to the dealer. They advised that it was checked before the sell and I had them re check it. I am told everything is good even though the frame appears fairly rusty. I also contacted Toyota and they said that the recoating is not available in my area and if the dealer approved, they would send a new frame to replace the old one. No buy back or recoating option. As of now I have begun repainting the frame myself. So far it seems to be OK. I still have not done the hammer and punch test yet.
  7. May 16, 2012 at 12:13 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    The recoating isnt so hot anyways it falls off in a year. I would whack all the areas with a hammer myself. My truck was recoated and tested but i got it to fail in my driveway:D
  8. May 16, 2012 at 1:12 PM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    FWIW I bought my old '97 for $4k in Nov 2010, clearly after the recall was announced, and it was bought back from me less than six months later for $8600!
    Go have it inspected! it's possible you just hit the jackpot :)
  9. May 16, 2012 at 2:04 PM
    Jeremy175
    Jeremy
    South MS
    TRD Sport
    So, would I be better off going to a local dealer or calling Toyota? I am really hoping Toyota will buy it back.
  10. May 16, 2012 at 4:04 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    The dealer takes care of it for toyota.
  11. May 16, 2012 at 5:52 PM
    Jeremy175
    Jeremy
    South MS
    TRD Sport
    Ok, thanks
  12. May 17, 2012 at 6:13 AM
    FishinTaco
    D'Arcy
    Sudbury, ON
    TRD 4x4 5spd
    For Canada and most states there was a deadline. If you did not have your truck in for it's first check-up by October of 2011 (some dealerships moved to dec etc..) it would not qualify for the buy back program or re-frame job.
    The dealership here in town was turning people down just weeks after the last due date.
    Hope this clears things up, and I've got my finger crossed for you.
    DC
  13. May 17, 2012 at 6:48 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    I know hind site is 20/20 but does anyone ever even think to look under a vehicle before buying it?
    Thats the first thing I do,if there are oil leaks I usually pass and go no further, then under the hood, next look for hail and body damage, then if it passes I do the test drive.
  14. May 17, 2012 at 3:16 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    If it is out of warranty im pretty sure you can contact toyota corp. There is some kind of an attempt going in the courtroom to get the warranty extended again
