Frame rust
Discussion in '1st Gen. Tacomas (1995-2004)' started by 98tacomaguy, May 1, 2016.
  1. May 1, 2016 at 8:57 PM
    98tacomaguy
    98tacomaguy [OP] Member
    Carnation, Washington
    1998 single cab 4wd 2.7 liter Tacoma
    I recently purchased a 98 Tacoma with some pretty bad rust issues on the frame, any suggestions on how to repair or replace it?
  2. May 1, 2016 at 9:09 PM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
  3. May 1, 2016 at 9:09 PM
    FirstGen Jer
    FirstGen Jer Well-Known Member
    Jeromey
    big bear lake, CA / lake havasu, AZ
    1999 toyota tacoma 3.4l v6 sr5 4x4
    Take a look at @gray223 build thread. He rebuilt his frame. You will find a lot of useful info there.
    gray223 likes this.
  4. May 1, 2016 at 11:20 PM
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    yeah you can take a look at my build. I'm guessing you probably have rust in the same spots. I'll try my best to answer any question.
  5. May 2, 2016 at 5:32 PM
    98tacomaguy
    Yeah a lot of mine is in the same spots, what kind of metal should I buy to reinforce the frame?
  6. May 2, 2016 at 5:47 PM
    gray223
    SE Missouri
    2014 Tundra Limited
    We just used 1/8" inch steel
  7. May 2, 2016 at 6:39 PM
    98tacomaguy
    Ok, Any recommendations for rust treatment? I was planning on using por-15.
  8. May 2, 2016 at 6:45 PM
    eon_blue
    eon_blue Well-Known Member
  9. May 2, 2016 at 6:49 PM
    gray223
    SE Missouri
    2014 Tundra Limited
    I used chassis saver. It's good stuff. Never tried that por 15. Chassis saver is pretty tough when applied correctly. It made to go right over rust. All the loose stuff needs to be knocked off first.
