Frame slider light questions
Discussion in 'Lighting' started by gordi, Nov 24, 2014.
  1. Nov 24, 2014 at 4:21 PM
    gordi
    gordi [OP] Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
    I am installing some frame sliders here in the next week and wanted to run 4 6-8" led white strips one for each door so they shined down on the steps. I wanted them to come on with the dome. So i found the slot 9 the blue wire in the fuse panel behind the coin tray. So i wire those 4 together and wire the negative ends to the blue wire. then a positive from the battery to the positive side of the leds. Does that mean that it grounds back up through the dome light? But wouldnt the lights have to be after the dimmer not before if the power is coming from the battery?
  2. Nov 24, 2014 at 9:09 PM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
  3. Nov 24, 2014 at 9:32 PM
    Btnewman
    Btnewman Benjamin Newman
    Benjamin
    Grand Junction co
    Uh. It's beat to he//. But it's only 1 owner.
    Custom body work/damage ARB rear locker Bumpers Shocks Other parts Tires and Rims Air tank fully plumbed into truck "Golf ball mod"
    Maybe post some pics of what your trying to setup? That might help answer some questions.
  4. Nov 24, 2014 at 11:43 PM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    i just dont get the wiring to the dome light mod. I need some one that has done the interior lights or dome light mod before to chime in. Could i run power to a relay then to the lights and have it come on with the dome light?
  5. Nov 24, 2014 at 11:56 PM
    gordi
    Josh
    North Idaho
    2011 DCSB trd sport
    OR would it be best to tap into the dome power and run it to a relay which will be open with the power from the door. Then just power from the battery to the relay and lights.
  6. Nov 25, 2014 at 4:58 PM
    fergyz
    fergyz Mmmm...Tacos
    49th State
    06' DBC 4x4 6spd
    if i remember correctly, the blue wire is the ground side of the dome light circuit. this particular ground wire is controlled by the body control module. will only be activated when triggered by a door or remote lock/unlock. i know LED's are of low amperage but you still may want to use a relay and have pin 85 tied into the blue wire to trigger the relay. +12 volts to pin 86.
  7. Nov 25, 2014 at 5:04 PM
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    I didn't use a relay and my lights have been working flawlessly ever since. I used a 3A fuse for the positive wire that goes to the led strips.
  8. Nov 28, 2014 at 9:08 PM
    Vanguard
    Vanguard No can remember!
    Brooks
    Kailua, Hawaii
    13' TRD Sport 4x4
    Icon Extended C/O's non resi, OME 60091/Dakar Leaf Pack, All Pro U-bolt Flip, Timberens, 17" SR8's, 285/70/17 Duratracs, AFE Stage II Intake, Magnaflow Cat back w/Resonator, BHLM, Grillcraft, 15/5 Tint, All-Pro HD Sliders @10 degr, OEM Roof Racks, TRD Skid Plate, Wet Okole's, Scan guage II, Optima Yellow
    I ran strips all the way down my rocker panel after I saw Deeez setup. Constant power and switched ground. I don't think you need a relay for this. I believe relays are for using a smaller switch to control a heavy load. But I think the ground is good enough for the LEDs since it's not carrying a much heavier load. You may want to switch out your dome bulb to LEDs to free up some of the circuit draw too.
    http://youtu.be/CDfmz_8WQZM
