Frame surface rust
Discussion in 'Detailing' started by Redsoxnation, Mar 28, 2011.
  1. Mar 28, 2011 at 6:37 AM
    Redsoxnation
    Redsoxnation [OP] Well-Known Member
    Pa.
    PreRunner TRD 4X4 Impulse Red
    none yet...
    Hey Guys,
    My 06 TRD is starting to show some surface rust on the main frame...Looks ugly.. I have been touching it up with 3M spray on undercoating.. But that doesn't last.. Is there any spray on product out there that will coat and prevent? I remember the old wax base Zee coat back in the day that was great stuff.... Any of that in a spray can?
    Or recommendations... Thanks
  2. Mar 28, 2011 at 6:44 AM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    Rustoleum.
  3. Mar 28, 2011 at 6:47 AM
    poynter
    poynter Well-Known Member
    Tony
    Somerset, KY
    2019 Cement TRDOR
    POR-15
  4. Mar 28, 2011 at 6:50 AM
    Dadic 78
    Dadic 78 Well-Known Member
    Fil
    Edmonton, AB CANADA
    08 Double cab TRD
    Sand it off with a purple 3M disc, then apply some POR-15. Bye bye rust.
  5. Mar 28, 2011 at 6:54 AM
    Redsoxnation
    Pa.
    none yet...
    and POR-15 would be? :rolleyes:
  6. Mar 28, 2011 at 6:57 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
  7. Mar 28, 2011 at 7:09 AM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    try KBS etching frame paint, better that por15 IMO
  8. Mar 28, 2011 at 7:10 AM
    Redsoxnation
    Pa.
    none yet...
    cute.. thanks.. zikes $20 a can
  9. Mar 28, 2011 at 7:11 AM
    Redsoxnation
    Pa.
    none yet...
    Thanks I'll look into all options..
  10. Mar 28, 2011 at 9:56 AM
    novataco
    novataco Well-Known Member
    NOLA
    06 Sport V6 auto
    Aries bull bar, Lund grill screen, blackened h/l, Weathertech plastic all over, Access LE tonneau, window tint, tube steps, DF-Toy aux adapter, cig plug always on, console vault, hitch step, 1700 watt in-cab inverter and dual battery (in-progress), Delta bike hitch mounts
    I've noticed some rust on my frame. I was wondering if a shop could do a little sand blasting and painting. I would hate to not eliminate it completely, and then cover it up with paint.
  11. Mar 28, 2011 at 9:59 AM
    novataco
    NOLA
    06 Sport V6 auto
  12. Mar 28, 2011 at 11:06 AM
    james
    james In over my head...
    Friday Harbor, WA: Fairbanks, AK
    '98 Tacoma V6
    I used a product on a commercial fishing vessel in a place where I couldn't do any sandblasting: PPG Amerlock 400. I scraped and scraped and then mixed up a batch (it's epoxy-based, marine for steel), and then applied with a brush. If I could put my truck up on a lift and spend some time with a rust converter, then hit it with Amerlock 400, I think I would do okay.
    ...but I haven't heard of POR-15. That looks interesting too.
  13. Mar 28, 2011 at 11:28 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    x2
  14. Mar 29, 2011 at 5:12 AM
    poynter
    Tony
    Somerset, KY
    2019 Cement TRDOR
    POR-15=
    Paint
    Over
    Rust
    Its worth the money.
  15. Apr 30, 2011 at 11:56 PM
    sherstcp
    sherstcp Well-Known Member
    Calvin
    Seattle
    '11 Pyrite TRD Sport
    OME 3" lift, BFG's, more to come soon...
    If you want bomb proof protection, go with RUST BULLET. I used POR 15 a few years ago while restoring my FJ40 and even with good prep work, the rust eventually bled through. It's not a bad product, I just don't trust it. Rust Bullet is AMAZING. You can paint over an un-prepped piece of steel and it will neutralize and permanently coat over the rust. ONLY issue is, it comes in gray...and as far as I know, nothing but. If it were me...RUST BULLET with a black spray over top.
  16. May 26, 2011 at 6:03 PM
    Michael G
    Michael G Member
    Northeast PA
    2006 Tacoma 4 cyl Manual 5 speed
    Fluid Film NAS after sanding and repainting frame. Works great.
  17. May 30, 2011 at 6:34 PM
    YFZ450MOE
    YFZ450MOE When you blow off steam you get an eyepatch
    Moe
    Auburn, WA / Roseburg, OR
    09 white DCSB TRD (it's getting there)
    Icon Extended Travel 2.5" Coil Overs All-Pro U-Bolt Flip Kit Bilstien Rear Shocks Fabtech Add-a-Leaf Icon Upper Control Arms All-Pro Rear Bumper w/ Wrap Arounds & Hitch with custom LED plate light BHLM and Morimoto III D2S retrofit Satoshi Grill 2 Hella Black Magics behind Grill Bestop Supertop BAMF sliders
    POR 15 isn't cheap but its dam well woth it. I did the entire underbory on my early bronco with it, running gear and all. The onlt thing I've heard bad about it is that it will fade after long sun exposure. I can scratch or chip it off. Very heavy duty stuff!!!
  18. Jun 8, 2011 at 1:12 PM
    Paulie
    Paulie Well-Known Member
    Paulie
    USA
    Tacoma
    Dont use undercoating. Try a wax srpray, Amsoil offers one. Use paint or Rust Bullet.
