Frame swap. Need help
Discussion in '1st Gen. Tacomas (1995-2004)' started by Twalt87, Jan 30, 2018.
  1. Jan 30, 2018 at 5:25 PM
    Twalt87
    Twalt87 [OP] Well-Known Member
    Travis
    Vancouver island Bc
    A friend of mine is doing a frame swap for his 98 tacoma, 2.7l. He got his new/used frame and theres some differences.
    I think the frame is a 97, as there was a change up i heard? Anyways, the engine sits further back, the engine mounts wont line up, the angles are wrong. On top of that, the transmission mount is half a hole out.
    Any one know if there was a change up? also if it is just the mounts, and we get that sorted, will the engine hit the firewall?
  2. Jan 30, 2018 at 5:42 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Engine mounts won't line up? It must be for a v6 then. If the transmission mount doesn't line up the donor truck could've been a manual or auto respectively.
    The v6 mounts differently than the 4 cyl one does, thus the frames are not intercompatible.
  3. Jan 30, 2018 at 6:04 PM
    Twalt87
    Travis
    Vancouver island Bc
    Edit: I misread your post, sorry.
    Ive never seen a frame be different between engine groups before, that is odd. I think he is going to cut off the original perches and weld them on the frame in the correct location.
    Other then the perches being in the wrong place, are there any other differences between the 2?
    Why did they change the frame for v6 and l4? anyone know?
    Speedytech7 likes this.
  4. Jan 30, 2018 at 6:27 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    The frames are different because the v6 is just a bigger engine. You have to re-weld the engine mounts a couple inches back to accommodate the 4 cyl engine block due to the size difference.
    You will also see a difference in transmission type. A manual transmission will have the crosssmember closer to the engine due to the smaller size, while an automatic transmission will be farther back due to the more elongated size.
  5. Jan 30, 2018 at 11:38 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Time to do some fabrication !!
  6. Jan 30, 2018 at 11:59 PM
    Speedytech7
    3435 E Trent Ave, Spokane, WA 99202
    It's less Tacoma and more mod
    Bigger in displacement but physically shorter than the 4cyl, the four cyl fills the latitude of the engine bay pretty closely, the V6 has a bit more room, hence why it can even manage to have an exhaust pipe cross over behind the engine over the bell housing without contacting the firewall. Mounts on the frame had to move to accommodate the 4cyls extra space requirement due to it's 4cyls being all on the same plane.
  7. Jan 31, 2018 at 6:52 AM
    Twalt87
    Travis
    Vancouver island Bc
    Yep, not a problem. Thanks for the answers. I will tell him to get his welder out.
