Frame swap -n- facelift for Mable
Discussion in '1st Gen. Tacomas (1995-2004)' started by Loctite77, Apr 9, 2020.
  1. Apr 9, 2020 at 5:12 PM
    Loctite77
    Loctite77 [OP] Well-Known Member
    Zeek
    NC
    2097 mashup vroom vroom bigwheelieee
    Some rust, runs good.
    First time poster long time reader here! Just scored this frame for 1100, came with Asian locking hubs, calipers etc.
    Any suggestions or links to frame swap threads?
    I want to put a really nice suspension under it with about 3” lift, any suggestions there are much appreciated.
    I think I’ll document the work here. Also I’m in NC, anyone interested in helping me with this (I’ll pay you of course)!
  2. Apr 9, 2020 at 5:35 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Is that a Toyota pick up frame or a Tacoma frame?
    Wyoming09 and Taco critter like this.
  3. Apr 9, 2020 at 5:37 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Double wishbone with no torsions? It’s taco as it gets
  4. Apr 9, 2020 at 5:38 PM
    Empty_Lord
    Dan
    Pretty good score for 1100. I’d love to help, but sadly I’m a little bit further than a short drive away.
    if you need info ask, I should be able to pull up instructions that may help you
  5. Apr 9, 2020 at 5:38 PM
    pairodice
    pairodice Well-Known Member
    Jay
    SF NM
    02 DCSB prerunner 4x4 manual
    A long as it has the same engine it’s should be a simple swap aside from the usual frozen bolt out alignment cam
  6. Apr 9, 2020 at 5:42 PM
    Black DOG Lila
    Virginia
    Feeling kinda Stoopid fer axn now.
    Thanks Daniel. SAS was so long ago.
    Empty_Lord[QUOTED] likes this.
  7. Apr 9, 2020 at 5:51 PM
    Loctite77
    Zeek
    NC
    Thanks. It’s supposedly off of a 98, but I’m willing to bet it was a replacement frame from the recall. It’s super clean for a 22yr old frame.
    six5crèéd and Taco critter like this.
  8. Apr 9, 2020 at 5:54 PM
    Empty_Lord
    Dan
    What’s wrong with the original frame? Holes?
  9. Apr 9, 2020 at 6:02 PM
    Loctite77
    Zeek
    NC
    my truck was hit by an unlicensed teen in a Pontiac right on the front hub, so it currently goes down the road crooked! Plus yeah, my frame is pretty darn rusted
    I could have repaired the rust sections if it wasn’t for the being warped. That’s a double whammy! Starting fresh.
  10. Apr 9, 2020 at 6:08 PM
    Empty_Lord
    Dan
    Perfect reason for a swap, I can get the documents for the 01 frame swap if you want it as a guide. May not be 100% the same as the 98. But should put you in the right direction
  11. Apr 9, 2020 at 6:11 PM
    Loctite77
    Zeek
    NC
    Thanks I’m sure it would be helpful, but don’t put yourself out of it’s a pain. I was thinking of this method.
    https://youtu.be/Urqq8FbVvb0
  12. Apr 9, 2020 at 8:23 PM
    billybop90
    billybop90 Well-Known Member
    Bill
    Black Hills SD
    1996 Taco, 2.7, 4WD, 5 spd
    Nice score. You gonna clean it up a bit or do a complete haulover i.e. sand, prime, POR.
  13. Apr 9, 2020 at 11:55 PM
    COMAtized99
    COMAtized99 Well-Known Member
    North Carolina
    99 DCLB v8
    The Bed is stock...ish
    What part of NC are you in?
    det107 likes this.
  14. Apr 10, 2020 at 5:49 AM
    Loctite77
    Zeek
    NC
    I’m in Winston Salem.
  15. Apr 10, 2020 at 5:58 AM
    Jeeperwilly
    Jeeperwilly Well-Known Member
    NE Minnesota
    03 X-cab 4x4 TRD
    Nice find. Wish I could find frames in that condition around here.
    Loctite77[OP] likes this.
  16. Apr 10, 2020 at 5:58 AM
    Loctite77
    Zeek
    NC
    I am gonna walnut blast the little bit of surface rust there is and yes POR 15 it. Also want to spray the inside with something. Any suggestions?
    six5crèéd likes this.
  17. Apr 10, 2020 at 6:00 AM
    Tacomabaja12
    Tacomabaja12 Well-Known Member
    Oscar
    2012 Barcelona Red TX BAJA TRD
    Im a second Gen owner, I could help out. Also in W-S 336
    ireymon and six5crèéd like this.
  18. Apr 10, 2020 at 6:03 AM
    Loctite77
    Zeek
    NC
    that’s awesome man! I’ll be in touch.
  19. Apr 10, 2020 at 6:04 AM
    Tacomabaja12
    Oscar
    sounds good man message me for details
  20. Apr 10, 2020 at 6:15 AM
    Loctite77
    Zeek
    NC
    It looks really good from what I can see.
    GQ7227[QUOTED] likes this.
