Frame treatment applicator advice
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NOI, Oct 14, 2017.
  1. Oct 14, 2017 at 9:59 AM
    NOI
    NOI [OP] Well-Known Member
    Eric
    Michigan
    Black 2011 Tacoma SR5 4x4 Access Cab
    So I lucked in to a free OEM frame treatment kit for the 2011 Tacoma I just bought. The frame is in great shape and I'd like to keep it that way. Can anyone recommend a pump sprayer that will work with this stuff? Preferably one with a wand to make it easier to get the inside bits?
  2. Oct 14, 2017 at 10:00 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    NOI[OP] likes this.
  3. Oct 14, 2017 at 10:01 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
  4. Oct 14, 2017 at 10:12 AM
    NOI
    Eric
    Michigan
    Thanks! I didn't need the actual stuff, just the sprayer, but that helped me find it on Amazon for about $40.
    Unchained 5150 likes this.
  5. Oct 14, 2017 at 11:48 AM
    C4vettrn
    C4vettrn Well-Known Member
    Randy
    Ft. Wayne IN.
    2015 trd 4x4
    17" SR8's
    You could always run to Menards and buy a cheap weed sprayer.
  6. Oct 14, 2017 at 2:02 PM
    NOI
    Eric
    Michigan
    I was concerned about the thickness of the marterial clogging the nozzle, but that would be ideal...don't have to drag the compressor hose around that way.
  7. Oct 14, 2017 at 5:30 PM
    turbosnail
    turbosnail Well-Known Member
    Pa
    18 dbl cab sr5 v6 4x4 , 1985 turbo sr5 pick up
    I have applied the noxudol to two different Tacoma’s and I poured the stuff in a regular paint tray used for a roller and applied it to most of the frame using a small roller from the hardware store , it leaves an awesome uniform texture and you can go back and apply multiple coats to high wear areas , plus it doesn’t make half the mess of spraying it on , you’ll still need to spray the inner boxed areas etc, but it really worked great .
    NOI[OP] likes this.
  8. Oct 14, 2017 at 7:52 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    You could also buy a $39 jam gun from Autozone and apply it that way if you have a compressor. The downside is that you have to refill the gun pretty often.
    NOI[OP] likes this.
  9. Oct 18, 2017 at 3:05 PM
    308savage
    308savage Well-Known Member
    Adam
    East Tennessee
    2012 Tacoma TRD Sport DCSB
    Leveling kit, roll bar
    Do I need to avoid spraying anything underneath my truck ? I plan to spray the frame and rear end and leaf springs with the aerosol cans.
  10. Oct 18, 2017 at 3:30 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    I purchased the fluid film kik just like 5150 said above. I warmed up the 2 plastic bottles with FF in hot water, shake them good. Cranked up my compressor to 80psi and went to town. It comes out as a fog and coats everything. I also bought the flexible tube that goes on a rattle can to do other tight areas.
    Lower the spare, and just keep repositioning yourself and different spray angles will cover more area.
