Fraying Serpentine Belt
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JD_P, Aug 17, 2015.
  1. Aug 17, 2015 at 7:38 PM
    JD_P
    JD_P [OP] Well-Known Member
    Terrebonne, Oregon
    2015 TRD Off Road Access Cab
    A few days ago I noticed a clicking noise coming from the front of the engine. I looked around the fan area and was unable to locate the source. The noise stayed about the same for the next two days and then today it was different. After checking the fan area it became quite clear that the serpentine belt was fraying and getting shredded. I will have a new one put on tomorrow. I just can't see what would cause this to happen within three months and 8,000 miles of having the truck. Maybe it was just a faulty belt. Is there anything I might be missing?
  2. Aug 17, 2015 at 8:23 PM
    Tacorriendo
    Tacorriendo Well-Known Member
    Fred
    Texas
    2009 DCSB 4x4 Off-Road
    Front lift, ride rite air bags, side steps, rear camera switch.
    the only two things that can be, is defective belt and an out of aligment pulley. For the looks of the first picture, it was probably the belt. is not normal to have lines across the belt because of the way they are designed, your it looks like it was swon with fabric tread.
  3. Aug 17, 2015 at 8:49 PM
    Usethe2nd
    Usethe2nd Well-Known Member
    Justin
    Fall city
    Welded metal
    Did you move all pulleys by hand and try to push them from the top and bottom while the belt was off? Check all bearings and bolts. I have a laser belt alignment tool at work that I use to check engines that consume belts. Shit can get a little bit out of alignment and cause excessive wear and tear.
  4. Aug 17, 2015 at 9:49 PM
    JD_P
    Terrebonne, Oregon
    Didn't really do too much inspection. Everything is so new that I haven't checked it out thoroughly. I will see what the dealer finds out tomorrow and thinking it should be covered under warranty.
  5. Aug 18, 2015 at 3:37 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Frayed belt edge is generally caused by misalignment of a pulley. The noise you heard could be related - maybe a bad bearing or tensioner is causing excessive movement of a pulley.
  6. Aug 18, 2015 at 6:43 AM
    R0dzilla75
    R0dzilla75 Well-Known Member
    Rodney
    Virginia
    05 Sport
    HID fog light 265-70-17 Firestone destination ATs Led interiors lights TRD seat covers
    Be sure to check your pulleys well because old pieces of belt love to get caught behind them and jack things up. I had a noise for a long time and didn't find it until I really got under the truck with the belt off and turned each pulley by hand. Low and behold I pulled a long piece out that was wrapped around one of my idler pulleys. No more noise.
  7. Aug 18, 2015 at 7:56 PM
    JD_P
    Terrebonne, Oregon
    Looks like the idler pulley was damaged and that caused the belt to wear wrong. All fixed under warranty.
    DoorDing, Kyitty and Usethe2nd like this.
  8. Aug 19, 2015 at 3:05 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    What did the dealer say about it when they replaced it?
    At 8K you still have a warranty, use it.
  9. Aug 25, 2015 at 8:14 PM
    JD_P
    Terrebonne, Oregon
    The original serpentine belt and the idler pulley were replaced on 8/18/2015. Today I hear a different noise under the hood again. I check the belt and there is a line showing wear. The dealership inspected it and everything appears fine, but obviously isn't. I will set up another appointment and see what we can figure out.
  10. Aug 25, 2015 at 9:09 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    What DoorDing said. Something is rubbing on the back side of that belt. It should be pretty easy to track down just by following the belt around all the pulleys with a good visual inspection using a flashlight and mirror with the engine off.
  11. Aug 25, 2015 at 9:23 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Well, that's f'd up.
  12. Aug 25, 2015 at 10:41 PM
    Rufus
    Rufus Well-Known Member
    SoCal
    2010 TRD PreRunner Sport
    OEM Truck Bed Extender, Window Tint, Tailgate Security Mod, OEM Spare Tire Lock, Cam Locks (storage compartments), OEM Bed Mat, OEM Skid Plate, Stant 11504 Locking Gas Cap, TW Edrin55 OEM Running Boards, Pop & Lock w/Back-Up Cam, Black WeatherTechs, Red Line Quick Lift Plus Hood Struts, Wet Okole Front Seat Covers-black/charcoal with red & white TRD graphic & back seat pockets, DIY Satoshi Grillcraft & Old School Toyota Badge, TW ZonKs Black UWS Low Pro Truck Box, Rear Suspension TSB, 3M Scotch Guard Paint & Headlight Protection Film 8mm Urethane, Flyzeye V2 Wired Amber/White/Amber Interior LED Lights w/Silver Case, Sleek Looking Black LED Tail Lights from K2 Motors (Identical to OEM, but black).
  13. Aug 27, 2015 at 4:41 PM
    JD_P
    Terrebonne, Oregon
    I took the truck in to the dealership yesterday. They were busy and wouldn't be able to check it out until today. Due to the damage done to the belt and distance I travel, they gave me a rental car to use.
    This afternoon, I got a call from the dealership. They told me that there was damage done to the fan pulley, something they said they missed during last week's inspection.
    They said that since it was damaged, it would not be covered under warranty. Hopefully this will fix it completely. Too bad it is going to cost me $175 to fix. I asked how the pulley could have been damaged since it is behind the grill, ac condenser, radiator, under the hood, enclosed by two fenders and a skid plate. I didn't get an answer except that it was damaged and not covered under warranty.
    At least I don't have to pay for the rental car and new belt.
  14. Aug 27, 2015 at 5:06 PM
    Mfreund1
    Mfreund1 Well-Known Member
    Eastern Ia
    2007 SR5 Sport
    I would not pay a dime. Tell them to show how me the damage occured and why it is my fault. If they cannot it should be covered under warranty. They are giving you a bs line because they do not want to take the hit on customer service score because it took then two trips to fix a problem.
  15. Aug 28, 2015 at 6:39 AM
    PackCon
    Connor
    Why is it not covered under warranty?
    How is the fan pulley being damaged YOUR fault?
    The cost of a new belt is negligible so that really isn't a pro. I'd tell them to prove the damage was my fault and if they couldn't, to get in there and fix it.
  16. Aug 28, 2015 at 10:04 AM
    oldstick
    oldstick Medicare Member
    GA
    I'm with the others. I believe they really mean defective from the factory and that eventually caused the "damage" they are referring too. Damage to the pulley and to the belt, they probably both damaged each other in the process. Were the fan blades damaged? Can they explain how something got in to damage the pulley without at least touching the blades?
  17. Aug 28, 2015 at 11:06 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    yeah fuck that... dealer is just being a cheap ass. that fan pully should be replaced for free at no cost to you.
  18. Aug 28, 2015 at 3:39 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Ask to see and take pictures. I don't understand how the pulley was damaged without not being noticed... They should be covering this. IMO
  19. Aug 28, 2015 at 6:46 PM
    JD_P
    Terrebonne, Oregon
    Well, it looks like I will never know what happened. I did get the pulley back and it is bent. As frustrating as it was to deal with, I am just glad it's finally fixed. I have been cautious about any forest road driving in case something happened too far out. I suppose I should keep a belt with me as a back up. Other than a bug deflector I installed with a Phillips screwdriver, I haven't had the hood up. It could have happened during the 5,000 mile service.
    Thank you for all the help and support.
  20. Aug 28, 2015 at 7:09 PM
    twalchlii1
    twalchlii1 Tacotraitor
    Tom
    Wa
    2018 GC Trailhawk
    Are floor mats a mod?
    Call Toyota. Also, contact your state attorney general and file a complaint ( online this is how you do a BBB complaint) I will bet real money you will get some recompense. Takes about 5 min to do. If it works, please post, so I can prove to wife I was right. For once. Thanx
    Manpants likes this.
