Freaking spider INSIDE my odometer!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Beater_Bimmer, Mar 14, 2019.
  1. Mar 14, 2019 at 9:13 PM
    Beater_Bimmer
    Beater_Bimmer [OP] Well-Known Member
    San Francisco, CA
    2002 Tacoma 4x4 DCSB
    Hi guys,
    I purchased my truck recently and after a bit of driving and the light hitting it just right, I noticed a freaking dead spider in the corner of my odometer housing under the plexiglass (argh)!
    Now that I've noticed it, it drives me crazy. What's the best way to get this guy out and off to the spider cemetery? I'm assuming taking apart my whole dash and the odometer housing will be a pain in the butt. Are there instructions anywhere that cover this?
    Check it out:
  2. Mar 14, 2019 at 9:22 PM
    Beater_Bimmer
    San Francisco, CA
    Haha, don't know, ask the spider?
    Your battery charge level is low.
    Rocan, 12TRDTacoma, SwampYota and 6 others like this.
  3. Mar 14, 2019 at 9:23 PM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    Take the cluster out and pull the clear cover off. It's a fairly quick process even though it seems like a huge task
  4. Mar 15, 2019 at 12:09 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Just watch out for the live spiders
  5. Mar 15, 2019 at 12:28 AM
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    Shop vac and try to get a decent seal around the hose stick over the odo reset pin where there’s a small gap. Did it in an old vehicle I had with a dead spider worked like a charm.
  6. Mar 15, 2019 at 12:34 AM
    black coffee
    black coffee A is A.
    Glenn
    509
    2010 AC 4x4 SR5 V6
    This sounds like a job for Billy the Exterminator.
    GQ7227, cruiserguy and JJ Customs like this.
  7. Mar 15, 2019 at 12:35 AM
    black coffee
    Glenn
    509
    2010 AC 4x4 SR5 V6
    If you do this be careful. The plastic scratches easily.
    GQ7227 and El Duderino[QUOTED] like this.
  8. Mar 15, 2019 at 12:37 AM
    El Duderino
    Jeremy
    HI->PNW
    I used silly puddy as a gasket no scratches
    LivinOnEdge and GQ7227 like this.
  9. Mar 15, 2019 at 12:38 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I’ve done it a few times, shouldn’t take you a few minutes. Here’s a step-by-step.
    1. Remove Lower Dash Valence, should be a few 10mm bolts and a few screws. Use a deep socket.
    2. Remove the screws from the instrument cluster surround, roughly three or four.
    3. Tilt the steering wheel all the way down.
    4. Remove the HVAC controls, and the screws that hold the center console stack to the dash. There will be a few behind the HVAC trim and a few below the radio.
    5. Pull the center control stack out, but don’t remove it.
    6. Pull on the instrument cluster surround until it comes out. Remove the buttons with some friction clips.
    7. Unscrew the instrument cluster from the dash with a few Phillips screws.
    8. Unplug the three dash harness connectors by pushing down and pulling on the friction clips.
    9. Use a flathead screwdriver to push in the friction clips that hold the Plexiglass lens and backing together and pull each half off.
    10. Remove Spider
  10. Mar 15, 2019 at 12:41 AM
    black coffee
    Glenn
    509
    2010 AC 4x4 SR5 V6
    11. Take spider to spider cemetery.
    Spare Parts, GQ7227, ajm and 3 others like this.
  11. Mar 15, 2019 at 12:41 AM
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    Scrap it.
  12. Mar 15, 2019 at 12:44 AM
    m603holden
    Marteeen
    New England
    Deal. I want the spider though.
    For research...
    SwampYota, GQ7227, ajm and 2 others like this.
  13. Mar 15, 2019 at 12:46 AM
    Nunya Bizness
    Dont let ColoradoTJ see this...
  14. Mar 15, 2019 at 12:50 AM
    m603holden
    Marteeen
    New England
    Haha I actually LOL'ed at that.
    Owning 3 tacomas I can appreciate a good cluster class reference
    Nunya Bizness likes this.
  15. Mar 15, 2019 at 6:31 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    F***ing brilliant, even if it doesn't work, lol. That's a damn good idea
  16. Mar 15, 2019 at 6:32 AM
    cruiserguy
    Elijah
    SEKS
    @Sperrunner
    Dibs
    Edit: Crow beat me to the dibs on it a few posts earlier
    Sperrunner likes this.
  17. Mar 15, 2019 at 7:19 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Thanks for looking out
    cruiserguy[QUOTED] likes this.
  18. Mar 15, 2019 at 7:19 AM
    cabowabotacoma
    cabowabotacoma Well-Known Member
    Rob
  19. Mar 15, 2019 at 7:22 AM
    Fatal_Paradox
    Fatal_Paradox Well-Known Member
    Bardstown, KY
    2003 Tacoma DC 4x4 01 Tacoma 2.4 5lug
    33's Bedliner Nerf Bars (Custom)
    I not only get spiders in my cluster, but I see them in and on my truck all the time. They are small yellowish maybe clear. Does anyone else have this also? Why do they love our Taco's?
    GQ7227 likes this.
  20. Mar 15, 2019 at 9:30 AM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    nah, nah.... the true story is that the truck came equipped with a spidey sensor, to allow it to have superhuman...errr supermechanical powers. Looks like spidey battery is dead. Needs a new one.
    Replace it and the truck will fire spider webs from the headlights
    GQ7227 likes this.
