'Free' add on features ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by coma09, Apr 22, 2013.
  1. Apr 22, 2013 at 11:00 AM
    coma09
    coma09 [OP] Updated avatar
    BC Canada
    2013 taco access cab 4x4
    Just pulled the three switch blanks above the mirror control.
    Two of them have pre-wired sockets behind them.
    Now I have a dilemma.
    Do I buy the Toyota Oem switches and get some new functionality for 'free'
    Or are they useless and I carry on with my accessory switch install?
    Anyone know what they are for?
    2013 4x4 base model auto v6 access cab
  2. Apr 22, 2013 at 12:21 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    Picture?
  3. Apr 22, 2013 at 12:25 PM
    coma09
    BC Canada
    Looking in the owners manual from front to back a couple times I finally found one diagram that indicates left is for fog switch, and right is for inverter.
    Neither I have installed from factory .... So just ignoring them and carrying on
    Maybe this post will help the next guy that comes across them.
    Got all excited for a sec ... Free diff lock! No :(
  4. Apr 22, 2013 at 12:28 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Buy the part and install it, i.e. diff lock, inverter, etc and the switch and you have a 'free' feature every time you flip the switch.
  5. Apr 22, 2013 at 12:29 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Even though the wiring harness is located behind the switch blank, there is usually some other, sometimes expensive, equipment or wiring that is missing somewhere along the line. You do not have the ability to simply plug in a switch and gain any functionality with any of those harnesses. They can make adding a feature a bit easier but there is more you'd need to buy or wire to make it all work.
