FREE Fluid Film Samples are Here!
Discussion in 'Deals & Coupons' started by Dano50, Jul 3, 2012.
  1. Jul 9, 2012 at 6:12 AM
    #101
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    Rust, can form behind the paint is what he is saying.
  2. Jul 9, 2012 at 6:18 AM
    #102
    Enigmaaron
    Enigmaaron All your soul are belong to us
    PA
    1st gen superiority
    If you have rust behind your paint then your paint will be bubbled/peeling and you have a much bigger problem than fluid film will solve. If it's just starting to form under the paint then the miniscule amount of air/moisture that may be trapped wouldn't go very far.
  3. Jul 9, 2012 at 6:38 AM
    #103
    Dano50
    Dano50 [OP] Active Member
    As far as prep goes, just wash the existing dirt and grime off. Fluid Film can be applied directly over tightly-adhering rust. If you have heavy rust scale, you'd want to clean it up prior to applying.
    Fluid Film is non-conductive and can be used as a dielectric. It works excellent at protecting electrical systems.
    It sprays on amber and then becomes clear. You will know it is there by the shine on the surface, which is why it can also be used as a wax.
    Fluid Film is a once a year vehicle undercoating. You may need to touch up the wheel wells.
  4. Jul 9, 2012 at 8:24 AM
    #104
    puckstopper55
    puckstopper55 Well-Known Member
    Long Island
    '11 Double Cab TRD Sport, Mag Grey
    tailgate anti-theft Map Light LED's Dome Light LED LP LED Halogen Bed Light Extra D-Rings in bed Anytime Fog Lights Tri-Fold tonnau cover Wet Ok's
    didnt you suggest we use this on battery terminals?
  5. Jul 9, 2012 at 8:42 AM
    #105
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    yes....
    :goingcrazy:
    whats wrong with that?
  6. Jul 9, 2012 at 9:45 AM
    #106
    puckstopper55
    Long Island
    He just said its non-conductive. I am pretty sure you want your terminals to be as conductive as possible.
  7. Jul 9, 2012 at 9:47 AM
    #107
    XXXX
    sKiP
    05 Prius
    I never apply it to the actual post.... I apply mine to the outside of the terminals. Never had an issue in almost 20 years that way. I also use Mobil1 to do so.
  8. Jul 9, 2012 at 9:53 AM
    #108
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    wait, it's already distributed in canada, but we can't get the free sample? fail.
  9. Jul 9, 2012 at 9:56 AM
    #109
    XXXX
    sKiP
    05 Prius
    This product is ORMD and if you know what that means youll understand why the company isn't willing to send out a 3oz sample and spend over $10 in mail charges to do so.
  10. Jul 9, 2012 at 10:02 AM
    #110
    Madjik_Man
    Colorado Front Range
    Cool thanks man
  11. Jul 9, 2012 at 11:43 AM
    #111
    Chris135
    Chris135 Well-Known Member
    Regina,Sk
    2011 Tacoma DCLB SR5 TRD Sport
    Debadged Bilstein 5100 shocks in front OME 885 coils Icon 1.5"aal 16" fj cruiser Trd rims 285/75/16 duratrac tires 1.25" spidertrax wheelspacers (4) Tinted front windows Grillecraft upper grille Custom Trd boxside decals Allpro front bumper Piaa 510 fog lights Box mounted ammo can Rear diff breather BHLM Tinted front windows Rolltop tonneau cover Hand controls (for wheelchair users)
    If there is rust under your pair you won't always see signs of it until it is too late. In my experience almost any amount of rust that you can notice that is just covered up will continued to spread, it's just a matter of time. I'm just giving everyone a heads up before they take this as a cure or a stop to rust. If you want to try it that's fine but I hope Not everyone will take this blindly as an instant stop/cure for rust. As a lubricant and to keep my undercarriage clean I most definately will be purchasing a can in the future. But I will not be applying it on top of any rsut to stop it. Just my 2 cents
  12. Jul 9, 2012 at 12:28 PM
    #112
    udy2554
    udy2554 NORTHERN RED-NECK
    Naples, NY
    '06 Tacoma TRD Sport
    Toytec ULK, Light Racing UCA's, OME Dakar rear leaves, ARB Bumper with XRC8 winch, Good Year Duratracs 285/70/17's on 17x9" Level 8 Strike 6's. Leer cap in the winter. Pioneer Double Din with BT, iPod, etc. Boston Acoustic components in all 4 doors with a Sony amp, powered 8" sub. Ultra gauge, Tom Tom...
    Got mine today! Man, that was quick, thanks Dano!:D
  13. Jul 9, 2012 at 12:33 PM
    #113
    XXXX
    sKiP
    05 Prius
    Dude it's just a coating....and the company was nice enough to give us samples so we could try it. If it slows it down that's great. Even NASA can't stop wires from corroding in billion dollar space craft.
    I'm sure it's better then the WD-40 many people spray their frames with currently.
    So what do you advise to slow the rust down on your boxed sections of frame?
  14. Jul 9, 2012 at 5:20 PM
    #114
    Chris135
    Regina,Sk
    I get that its a coating, and i appreciate the fact they are nice enough to give you guys free samples. thats very cool of them. But they're saying it "stops existing rust on contact". Not trying to make a big deal of it i just want people to have realistic expectations rather than expecting a miracle product thats stops rust. My concern is also more so directed to rust on panels such as a door or a box side where you could essentially coat it and think its stopping your rust. frames rust thats a fact unless you seal it up right away before any corrosion begins. maybe this would work for that if you started with a new frame maybe it wouldn't. linex would probably work better, but to each his own. and yes i agree that it would be better than wd-40, i don't know why they hell you would ever do that but hey thats just me. once again just stating my 2 or 3 cents so people have realistic expectations, not trying to make a big deal or hijack this thread. if you still have comments about my skepticism please pm me so i don't steer this thread in a different direction. It sounds like a really cool product and its awesome of them to give out free samples. my apologies if i seemed ungrateful of what was being done.
  15. Jul 9, 2012 at 5:49 PM
    #115
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    If it stops the chemical reaction which causes the rust to form, then essentially, it stops rust. And by stopping, I mean only while the product is intact and fully covering the area that is starting to rust. It's not like this is the only company that uses those type of facts to their advantage. I don't think anyone on so far in this thread, thinks it will completely stop or heal rust, just by spraying something on.
    Anyway, thanks to Dan (OP) I got my sample today, and will give a shot.
  16. Jul 9, 2012 at 7:03 PM
    #116
    udy2554
    Naples, NY
    The main reason I want to try this is to keep more of the salt off my undercarriage and drivetrain. The only thing that will keep anything from rusting would be keeping it stored in a controlled enviroment!
    I've read a little about Fluid Film in an old thread regarding the use of old engine oil and/or tranny fluid as a protectant against the salt used on the roads around here. I used to do this, but would like to try something a little less impactive on the enviroment. It seems the cost is quite reasonable, so I am giving it a try this winter.
    The freebie sample is a great perk. They are showing quite a bit of confidence in their product by giving away as much of it as they are.:thumbsup:
    Thanks again Dan!
  17. Jul 10, 2012 at 4:41 AM
    #117
    XXXX
    sKiP
    05 Prius
    X2!
  18. Jul 10, 2012 at 5:15 AM
    #118
    troy28
    troy28 Well-Known Member
    Capitol of Salty Roads
    Need help
    PM sent. Thank you!
  19. Jul 10, 2012 at 5:22 AM
    #119
    Bloodhound
    Bloodhound Banned from the Pics Thread
    Greg
    East Moline, IL
    '10 TRD O/R DBL-CAB
    Floor-mats, Running Boards, Shorty Antenna, AFE Pro Dry Air Filter, AVS In-Channel VentVisors, Beer cans in the bed
    PM inbound..
  20. Jul 10, 2012 at 5:28 AM
    #120
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Mine came in the mail yesterday and already have some plans for it! So far I'm thinking about using it in some dings that removed the paint and started to rust and also using it as a wax on the rear chrome bumper. If there's enough left, I'll lube the motorcycle chain with it.
    Thanks for the great deal Dan0 :thumbsup:
