Free Wheel Manual Hubs Conversion Kit
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by 05Taco4x4, Sep 21, 2017.
  1. Oct 3, 2017 at 10:39 AM
    #101
    05Taco4x4
    05Taco4x4 [OP] ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    I will include instructions in box, including torque specs. It's pretty simple. The most exotic tool would be a small 3-leg puller if the tulip doesn't want to slide off, but you can use O'Reilley's for free if you don't own one. A proper pair of circlip pliers will help too. I highly recommend using a torque wrench. Otherwise, wrenches, sockets and a plastic dead blow. It should take 3 hours.
    If I can find someone local to me, and willing, I'd like to make an installation video. Any takers on Oahu? @Waited many moons
  2. Oct 3, 2017 at 10:41 AM
    #102
    T4RFTMFW
    T4RFTMFW Well-Known Member
    This thread needs more title changes and OP username changes.
    MrCrowntown and Muddinfun like this.
  3. Oct 3, 2017 at 10:42 AM
    #103
    05Taco4x4
    2TR-FE Enthusiast
    Once is enough
    MrCrowntown likes this.
  4. Oct 5, 2017 at 5:26 PM
    #104
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
    I saw no MPG increase from converting to manual hubs, but the other advantages still make it worthwhile.
    05Taco4x4[QUOTED][OP] likes this.
  5. Oct 7, 2017 at 1:24 AM
    #105
    05Taco4x4
    2TR-FE Enthusiast
    I'm seeing nearly same MPG as when I was a PreRunner, so I know it's worth some MPG.
  6. Oct 7, 2017 at 8:33 AM
    #106
    Rusty15Tacoma
    Rusty15Tacoma Well-Known Member
    Rusty
    San Diego
    2015 MGM TRD Offroad
    Bilstein 5100 w/ OME 886, Built Right UCA's, Dirt King LCA's, 5125 2"-2.5" lift rear shocks, Alcan HD 8pack rear, Level 8 Guardian 16" wheels, blacked out badges, 285/75R16 Hercules Trail Digger, 20% tint, BHLM Retrofit.
    Does this mean if I get put on the list, it's $1100?
  7. Oct 7, 2017 at 9:09 AM
    #107
    05Taco4x4
    2TR-FE Enthusiast
    Yep, if you’re the next
  8. Oct 7, 2017 at 9:13 AM
    #108
    05Taco4x4
    2TR-FE Enthusiast
    I’m willing to give up the profits to get a few out in the wild
  9. Oct 8, 2017 at 6:57 PM
    #109
    old55guy
    old55guy Well-Known Member
    mike
    2011 dcsb trd white
    none
    Sweet , I"m in , now I can lift my 2011 , ( to Heaven and beyond ) at least 3" and not have any vibration Issues , with all the other great benefits of the Hub kit ! woopeee
    05Taco4x4[OP] likes this.
  10. Oct 9, 2017 at 5:12 AM
    #110
    robbytaco
    robbytaco Well-Known Member
    Rob
    San Antonio
    06 DC TRD Sport
    Sub'd
  11. Oct 14, 2017 at 5:26 PM
    #111
    weldo
    weldo Well-Known Member
    Pittsburgh, pa
    2014 base ac 2.7 5-speed 4x4
    I'm very interested in this conversion as part of an old school setup. I'm envisioning the manual hubs paired up with a manual shift FJ transfer case. It would be just like the old '91 Pickup I used to have. It's a little less convenient but when you pull that lever you know for sure the truck's in 4wd. A few times past the OEM shifter servo thing left me wanting a more concrete engagement method.
    In the stock system the differential is the disconnect point to the t-case. But on a manual hub truck the disconnect is at the wheel so the diff can be constantly engaged. If such a setup were to be installed how would the ADD on the front differential be mitigated. I guess that could be accomplished with the OEM electronics?
    old55guy likes this.
  12. Oct 14, 2017 at 5:49 PM
    #112
    05Taco4x4
    2TR-FE Enthusiast
    I converted my PreRunner to 4x4, and used a FJ transfer case. I deleted the ADD. Check out my build, the link is in my signature. To delete the ADD, I welded the sleeve (which the ADD actuator moves back and forth, thus engaging/disengaging) to the hub. Removing the front diff carrier will be the hardest part for you, otherwise it’s simple and a nearly free mod. You could sell off the actuator here, if it’s in good condition.
  13. Oct 14, 2017 at 7:00 PM
    #113
    old55guy
    mike
    2011 dcsb trd white
    none
    This hub upgrade is a awesome for our Tacoma , first mod I will do when I install my hub kit ,is take out the ADD on front diff , second modification will be the FJ cruiser case , ( my electric tacoma case Sucks ) you can find a FJ case for about $400.00
  14. Oct 15, 2017 at 12:29 PM
    #114
    DJB1
    Dave
    SLC, UT
    You could also source an intermediate shaft from a manual transmission FJ Cruiser. Being full-time 4WD, they did not have an ADD front diff.
  15. Oct 15, 2017 at 3:29 PM
    #115
    weldo
    Pittsburgh, pa
    Ohh, interesting idea. All the front diffs were the same I guess, huh?
  16. Oct 15, 2017 at 7:15 PM
    #116
    old55guy
    mike
    2011 dcsb trd white
    none
    WOW !
    Lets see front cv axles not turning , spider gears not turning , ( stock tacoma turns spider gear ) can eliminate the front ADD , no vibration issues when doing a lift kit , gotta be getting a little better mileage 1 mile per gallon ??? thats 10 miles for every 100 miles driven , can use 4lo in 2wheel drive , steering ???? and the cool factor ,
    I"m a old guy , I like old school my 2 cents
  17. Oct 15, 2017 at 8:16 PM
    #117
    DJB1
    Dave
    SLC, UT
    Yes, the 2nd Gen Tacoma, 4th Gen 4Runner and FJ Cruiser share a lot of parts.
  18. Oct 18, 2017 at 2:41 PM
    #118
    CorpsmanUp
    CorpsmanUp Well-Known Member
    Gibby
    Suffolk, VA
    2013 Taco DCLWB 6in lift 35s 4.56s, air lockers AP F&R bmpers warn 10k winch Rigid fogs & floods custom pro top shell
    6in procomp stage 2 lift with PC Coilovers, 35x12.50 Nitto MTs, Moto metal 18x10 with -44 offset HID and LED's everywhere, ladder bars, rear disk brake conversion, hood struts, K&N cold air intake, Flowmaster 40 series, pro comp skid plates, train horn, pa system, all silver trim inside painted black all pro apex front bumper with full hoops warn 10k winch, all pro high clearance rear bumper with custom door hinge tag holder, pro top custom windowless camper shell. ARB onboard air compressor, rear ARB air locker, 4.56 gears front and rear, waterport pressurized water system, pop and lock tailgate.
    Sub’d
  19. Nov 5, 2017 at 3:43 PM
    #119
    05Taco4x4
    2TR-FE Enthusiast
    Now available:
    Recycled OEM Center Shaft- $90
    (makes the install MUCH easier)
  20. Nov 5, 2017 at 4:48 PM
    #120
    Muddinfun
    Muddinfun Well-Known Member
    @old55guy
    I see you're not on the list anymore.
    Update?
