Free Wheel Manual Hubs Conversion
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by 05Taco4x4, Oct 7, 2017.
  1. Nov 22, 2017 at 9:55 AM
    05Taco4x4
    05Taco4x4 [OP] ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    It's not necessary to remove the A.D.D., just pointless to retain after the conversion. Retaining it won't hurt anything.
    I use the same bearings that are on your truck now, which have the ring for the rotation pickup. The sensor is still in the steering knuckle, nothing is changed.
  2. Nov 22, 2017 at 3:17 PM
    jester_motorsports
    jester_motorsports Well-Known Member
    Josh
    Edwardsville, IL
    Black 2004 TRD Off-Road 4x4 Dcab
    So did it throw a code when you removed the actuator? Also, do you have a 2nd or 3rd gen truck?
    @awsumdc have you messed with any of the 3rd gen stuff yet as far as transfer case stuff goes?
  3. Dec 1, 2017 at 12:22 PM
    El Taco Blanco
    El Taco Blanco Well-Known Member
    2017 White Tacoma SR5 4x4 DCLB
    Stock (for now)
    Dang. I'm planning on getting, funds are just tight this time of year. How much will it be when not on sale?
  4. Dec 1, 2017 at 12:42 PM
    05Taco4x4
    2TR-FE Enthusiast
    The price will go up in the coming months, I'm practically giving these away right now.
    To give you an idea, these are the parts I have to order. These prices could be a little lower/higher but generally in the ball park.
    Then add the manufacturing/shipping costs for the custom stuff.
    You can not make this kit for the same price you can buy it from me, let alone the time/money in R&D.
    Ensemble88 likes this.
  5. Jan 13, 2018 at 3:27 PM
    05Taco4x4
    2TR-FE Enthusiast
    These two videos give a visual of the process.
    Removal
    Rebuild
    I suggest to remove the inboard joint's clamp and slide the shaft out of the housing, leaving the housing INSIDE the carrier diff. It will look like this
  6. Feb 1, 2018 at 4:21 AM
    PB FAB
    PB FAB Well-Known Member
    2017 SR DCSB 4x4 v6
    The information about removing the ADD should be updated on the first post. If the ADD is removed on a 3rd gen and unplugged from the harness the computer will not shift the transfer case into 4H or 4L. The computer checks for the position of the add, if locked, it will then shift t case.
    One could unbolt the add and do your mod but they would have to leave the add connected to the canbus system. Or someone could design a plug and play harness to trick the computer, maybe.
    Still waiting to see someone’s write up on a third gen install.
    WarFab Armor likes this.
  7. Feb 1, 2018 at 8:34 AM
    05Taco4x4
    2TR-FE Enthusiast
    You are absolutely right. This conversion makes the existence of ADD unnecessary, but does not delete it or necessarily make it possible to simply unplug it unless you have done the FJ Transfer case swap.
    It is perfectly fine for the ADD system to remain in place.
    I have requested another member to look into this, possibly make a plug'n play.
  8. Feb 18, 2018 at 11:55 PM
    05Taco4x4
    2TR-FE Enthusiast
    My 2 Lo switch :)
    bahndrvr, souvang and El Taco Blanco like this.
  9. Feb 19, 2018 at 3:01 AM
    RedBeard1
    RedBeard1 Baby Ruuuuuth!
    Red
    The Republic of Texas
    1985 Hilux Crawler(Pete), 2016 Quicksand TRD OR 6MT (Wombat), 2016 TRD Pro T4R (OVTUNE # 2403)
    Mostly stuff I built.
    Watching this.
    05Taco4x4[OP] likes this.
  10. Feb 19, 2018 at 4:19 AM
    FrontRoyalBob
    FrontRoyalBob Well-Known Member
    Bob
    Front Royal, Virginia
    New 2016 Toyota Tacoma Off-Road
    ESP Lockable Rear Seat Storage, MobTown Lockable Bed Hatches, lots of cool Mobtown products (Rear Bumper, complete set of 1/4" steel skid plates, sliders), Old Man Suspension and a bunch of other practical off-road tools to bulletproof my truck...
    Sooo, I think this is a great idea...I even started a post on November 25, 2015, titled "Locking Hubs for 2016 Tacoma?" at https://www.tacomaworld.com/threads/locking-hubs-for-2016-tacoma.402872 and a bunch of you made fun of the idea...what gives...I guess all the trolls crawled back under their rocks...
    This product is exactly the right direction...
  11. Mar 3, 2018 at 1:29 AM
    05Taco4x4
    2TR-FE Enthusiast
    Thanks.
    I wouldn't be too hard on anyone, most probably figured since it wasn't ever done on a 2nd Gen it certainly wouldn't be done on a 3rd.
    I suspect when wheel bearings start needing to be replaced at ~40-80k miles folks will seriously consider this, since those are part of the kit.
    Guys doing a PreRunner to 4x4 conversion gain the most value from this kit, followed by guys who have 4x4 but rarely use it ie Mall Rated Crawlers. Guys who actually use 4x4 know the value of it.
    tonered likes this.
  12. Mar 30, 2018 at 6:26 AM
    J A Red
    J A Red Well-Known Member
    Peachland, BC
    2021 DCSB TRD Sport 6MT WCP
    KO2s, 6112/5160,
    This is awesome. Now how do I do this and keep my warranty? None of the electrics are messed with correct?
  13. Mar 30, 2018 at 6:45 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It always depends where you take it. Typically they will only deny warranty coverage in areas that were modded. Wheel bearings and CVs are not likely fail items unless they are abused (popping it in 4Hi while spinning the rears, etc.) which wouldn't be covered anyway. Beyond that, you are extending the life of the front driveline since none of it will be turning when in 2Hi unlocked. Think about never having to worry about the needle bearing!
    As far as the electronics, it would have no idea about this. Essentially until you manually lock the hubs, 4Hi more or less equals 2Hi, but 4Lo would now equal 2Lo. That last one is the biggest reason that I want this.
    Spinning the rears in 4Hi unlocked, the TRAC system should look at this no differently than 2Hi.
  14. Mar 30, 2018 at 11:02 AM
    05Taco4x4
    2TR-FE Enthusiast
    What he said :cheers:
    tonered[QUOTED] likes this.
  15. Mar 30, 2018 at 11:05 AM
    #35
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    With a bunch of bad spelling and grammar. :annoyed:
  16. Jul 30, 2018 at 6:05 PM
    #36
    05Taco4x4
    2TR-FE Enthusiast
    So if you guys haven't noticed, the price dropped drastically because I was able to source the hubs at a reasonable price.
    tonered likes this.
  17. Jul 30, 2018 at 6:44 PM
    #37
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Hell yeah!
    I really want to push the buy button but still saving.
    Thanks for doing this!
    05Taco4x4[QUOTED][OP] likes this.
  18. Jul 30, 2018 at 6:50 PM
    #38
    souvang
    souvang Well-Known Member
    Fresno ca
    Ifs-crawler
    3gen pickup Dualcases/4.7 5.29s F n R Zip locker Longfeild axles Goodyear mtr-37s 3gen 4runner Icons coilover/ camburg arms Taco locking hubs 488s F n R rear/w Zip locker Rear LC 7wraps w/tundra fox shocks Savage full skip
    Fyi this is probably this best mod for the money! You dont need to remove any electrical or mod, but again depend on what you want to do. Just adding this hub mod benefits in 2wd mode, unless wear on cvs, abit better mpg (like anyone care lol), broken CVs on trail drive home in 2wd without removing the CVs.
    tonered and 05Taco4x4[OP] like this.
  19. Jul 30, 2018 at 6:52 PM
    #39
    05Taco4x4
    2TR-FE Enthusiast
    Good time to do this is when your front bearings start to go :thumbsup:
    tonered and souvang like this.
  20. Jul 30, 2018 at 6:53 PM
    #40
    Sep1911
    Sep1911 Well-Known Member
    2016 Taco
    Interesting... So you can spend 1k on this conversion kit, weld your front end and save your self the hassle of getting an ARB + install. Tempting..
