Free Wheel Manual Hubs Conversion
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by 05Taco4x4, Oct 7, 2017.
  1. Aug 8, 2018 at 12:34 AM
    #61
    05Taco4x4
    05Taco4x4 [OP] ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    Running Board Man likes this.
  2. Aug 8, 2018 at 12:43 AM
    #62
    mauidogg
    mauidogg Well-Known Member
    16 DCSB TRDOR
    No grey wire mod. And wear is dependent on use and environment. I have had a solid axle for most of my driving life. I have no idea how long the cvs will last. This not the only option for 2lo but it is much cheaper less work than dual cases.
  3. Aug 8, 2018 at 1:38 AM
    #63
    fezzy
    fezzy Well-Known Member
    Hawai'i
    2017 BLACK TRD OFFROAD DCSB M/T
    yeah, if you go to hana on maui. you pay 6$ a gallon . #mauiproblems
  4. Aug 8, 2018 at 10:41 AM
    #64
    Brosefff
    Brosefff Well-Known Member
    Temecula
    2016 Taco SB 4x4
    a little something
    4lo, full droop, at full left turn. Must of got traction then I heard a pop! Long travel and I may have let my limit syraps stretch over 2 years without checking them which might of put the CV past it's limit, bound up, and popped.
    I see the outboard joint but is it genuine Toyota? I need the outboard joint anyways but why does the kit require new ones if it uses the same 2nd/3rd Gen joint? Same question for the hub/bearing, if it's is the same as the one current stock one?
    Also, which locking hub do you prefer? I tried to do some research comparing. Found one guy who said the warn was junk. I know the aisin is OEM for older yotas. I had em on my 98 for 200k miles. I'm on 35" tires now and long travel so I need beefy.
  5. Aug 8, 2018 at 10:51 AM
    #65
    Brosefff
    Temecula
    2016 Taco SB 4x4
    a little something
    Well I just snapped a CV on a trail 400 miles from home and would have made life a lot easier. Would have to disassemble away from home. Unlock hub, drive home. Also, it just sucks knowing all that gear is spinning uselessly under the truck while in 2 wheel drive. I wish I could run these on my rear axle and flat tow the taco behind the RV. Sucks not having nuetral on the transfer case.
  6. Aug 13, 2018 at 3:40 PM
    #66
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Sub'd for possible future purchase.
    tonered and 05Taco4x4[OP] like this.
  7. Sep 17, 2018 at 11:38 PM
    #67
    shiftz
    shiftz Active Member
    GTA
    '19 DCSB 6MT Sport
    Any concern about the unloaded front axles spinning while using such 2Lo?
  8. Oct 7, 2018 at 7:58 PM
    #68
    oconnor
    oconnor Where am I?
    Midwest
    '18 TRD Sport 4x4 AC 6MT/ '04 TJ Rubicon
    So if looking to move to the FJ TC and remove the TC and ADD actuators, this seems like the logical next step.
  9. Oct 7, 2018 at 8:01 PM
    #69
    oconnor
    oconnor Where am I?
    Midwest
    Rock on!:headbang:
  10. Oct 8, 2018 at 3:54 AM
    #70
    -40
    -40 Well-Known Member
    North Dakota
    01 DC Camburg LT & 17 OR OME BP-51
    1 st Gen TRD Supercharger. URD 7th Inj. Camburg 4x4 LT Kit. Tundra Brakes. 3rd Gen just get’n started, OME BP51 Dakar HD, Camburg UCA & various armor.
    Subd
  11. Nov 21, 2018 at 3:15 PM
    #71
    TACOMAFORLIFE68
    TACOMAFORLIFE68 Simple Red Toy.
    Central CT
    2023 Sport DCLB
    RC 3.5 Vertex lift 255-80-17’s on 4Runner pro wheels, rear diff breather mod/ extension, carrier bearing drop kit.
    are these available for 3rd gen's
    tonered likes this.
  12. Nov 21, 2018 at 4:58 PM
    #72
    05Taco4x4
    2TR-FE Enthusiast
    Yes, kit works on 2nd and 3rd Gen
    Running Board Man and tonered like this.
  13. Dec 11, 2018 at 9:42 AM
    #73
    Dacon
    Dacon 2017 Tacoma TRD PRO Quikrete
    Danny
    Gilbert, Arizona.
    2017 TRD PRO DCSB. DOP 02.20.2017
    TRD PRO Cement 2017 TRD CAI and AFE Magnum Flow Dry Air Filter Camburg KINETIK Series Billet UCA Icon LCA skid plates Icon Coilover extended travel shocks with 700# springs Icon 2" rear shocks Icon RXT leaf springs full pack (new rims and tires soon)
    Wait, WHAT???
    While in 2WD, the front (both) CV axles and front differential still spinning??? I thought that the front diff is disconnected in 2WD and connected in 4WD and both CV not spinning.
    In normal 2WD if both CV are spinning and also the front diff is spinning its gears, there is a lot of drag and waste of fuel. Toyota should have find a solution for front diff to be in neutral as opposed to use 0W-20 oil for fuel economy.
    If all is spinning, why do I have to engage the 4WD every month to get the gears moving???
    In that case, in 2WD what is actually spinning?
    - front/right CV spinning? Y/N
    - front/left CV spinning? Y/N
    - front differential spinning? Y/N
    If the 4WD engagement is done only on the passenger side, that means 2WD is actually 3WD?
  14. Dec 11, 2018 at 9:47 AM
    #74
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    In 2wd everything is spinning. Cv's front diff, front drive shaft, and transfer case. What happens when you switch to 4wd, is the transfer case actually engages the front diff to send power to it.
    What this kit does is allow the front wheels to free spin at the hubs, and doing so, keep the cv's stationary while the hub spins around it. Since that is stationary, the rest of the front drive line is stationary. Then when you lock the hubs, it goes back to stock and you can then engage 4wd.
    eurowner likes this.
  15. Dec 11, 2018 at 9:47 AM
    #75
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Y, Y, N.
    The ring and pinion / driveshaft do not spin. Just the diff gears.
    No about the last question. If the T case engaged and the ADD doesn't, which won't happen because of the way the 4wd ECU works, you are still RWD only since the path of least resistance is the unconnected inner right shaft.
    This is great for the MT folks since we can then have 2Lo to counteract the weirdly high reverse gear.
    oconnor and Running Board Man like this.
  16. Dec 11, 2018 at 10:28 AM
    #76
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Sorry, my background is more from the powetsports side, I forget about the stupid add thing sometimes. Either way answering his question, yes, the 4wd stuff is still spinning while in 2wd
  17. Dec 11, 2018 at 2:31 PM
    #77
    05Taco4x4
    2TR-FE Enthusiast
    Both CVs are driven by the wheels because they're mechanically connected. Passenger side is disconnected at the A.D.D.
    As mentioned, this mechanically disconnects the CVs from the wheels.
    tonered likes this.
  18. Dec 12, 2018 at 1:37 PM
    #78
    05Taco4x4
    2TR-FE Enthusiast
    "this" in the second line refers to my kit, not the A.D.D.
    As mentioned, MY KIT mechanically disconnects the CVs from the wheels.
  19. Dec 12, 2018 at 2:05 PM
    #79
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    You don't happen to need anyone with LT that actually abuses their truck to do some quality testing for you do you? I'd be a happy guinea pig for some hard abuse.
  20. Jul 16, 2019 at 6:12 AM
    #80
    Lee Bag
    Lee Bag New Member
    Heath
    2012 Tacoma
    Lift wheels tires
    How do I purchase this ASAP?
    tonered likes this.
